Question about HP Pavilion dv6000z Notebook
Battery is not charging
I have a ZD8350LA ,some days ago the battery stopped charging and the indicator led blinks every time the battery is in the device, my computer is only 10 months old, can it be a configuration problem on the motherboard? or the battery has broke down? my battery is at 84 percent.It says its charging but it is not.It is still at 84 percent.
  • 3,940 Answers
Portable batteries are a consumable item and have an average lifespan of 300 to 500 recharge/discharge cycles.
If the computer is only 10 months old, contact HP for a replacement after following the instructions for the HP Battery Check HERE
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&dlc=en&product=1149451&docname=c00625471#N859
Posted on Jul 18, 2008
My Brand new Ryobi 18v lithium-ion battery P104, I bought this three years ago and just now needed it. I opened it from the blister pack it was in and I tried to charge it. When in the charger the red...
get the new charger; and consider returning to store or manufacturer.
if you have the black charger, throw it out
you need the green/two-tone charger for ryobi one 18v
Mar 18, 2017 | Drills
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
Can't charge the battery
I didn't have the time to find out what was the problem cause i needed the camera immediately so i bought a new battery and a new charger.Thanks for the help!!
Aug 07, 2009 | Olympus FE-220 Digital Camera
Digimax i5 problem charging battery
■ Charging LED
Charging LED
Red LED is on = Being charged
Red LED is blinking = Charging error
 Green LED is on = Charging is complete
● If the charge indicator blinks as red, it indicates a battery charging error.
- The battery is not properly inserted
- The terminals of battery are dirty or damaged
If the battery is inserted properly and the charge indicator continues to blink, contact the
nearest Samsung Camera Service Center.
If the charging LED doesn't turn to green could mean a signal that the battery is bad or can't charge 100% anymore = too old, needs a new battery. Hope this helps.
Jul 06, 2008 | Samsung Digimax i5 Digital Camera
it is not your battery that is the problem but the charger so you will need to go somewere like officemax and buy a universal charger and if you still have problems then call HP tech support there friendly people
Jun 23, 2008 | HP Pavilion dv6000z Notebook
Charger red lite flashing. Camera comes on for one second and shuts off
Here's a copy from the owners manual:
■ Charging LED
Green LED is on = Carging is complete
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
Jun 10, 2008 | Samsung Digimax i5 Digital Camera
Same Problem
Hello, it was:
■ Charging LEDCharging LED
Or if the red LED remains on without turning green could mean a bad battery that no longer charges to 100% - get a new battery. Hope this helps
Jun 05, 2008 | Samsung Digimax i5 Digital Camera
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Let the battery go all the way dead. You may have to adjust the settings in your bios so that the laptop will stay on until the battery goes completely dead. Then charge the battery. Do this a few times if it does not fix the problem you do need a new battery.
Jan 21, 2008 | Compaq tc4200 Tablet PC
From HP website- worked immediately for me.
This document pertains to HP Notebook PCs with Windows Vista. Understanding battery charging issues If the notebook battery is not charging or the notebook does not indicate that the battery is charging, the most likely scenario is that the battery itself is operating correctly, but its power management software may have become corrupt. In order to correct the problem, you will need to uninstall and reinstall the power management software by using the Device Manager. This document will explain how to uninstall and reinstall the ACPI Battery listings in Windows Vista, as well as how to obtain and install updated BIOS files, if needed to correct other battery issues. Uninstalling and reinstalling power management software in Windows Vista In order to correct problems with the battery's power management software, follow the steps below.
  1. Click Start and type device in the search field, then select Device Manager .
  2. Expand the Batteries category.
  3. Under the Batteries category, right-click the Microsoft ACPI Compliant Control Method Battery listing, and select Uninstall . WARNING: Do not remove the Microsoft AC Adapter driver or any other ACPI compliant driver.
  4. On the Device Manager taskbar, click Scan for hardware changes c01176420.gif . Alternately, select Action > Scan for hardware changes .
Windows will scan your computer for hardware that doesn't have drivers installed, and will install the drivers needed to manage your battery's power. The notebook should now indicate that the battery is charging.
Oct 19, 2006 | HP Pavilion zd8000 Notebook
HP Pavilion dv6000z Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
