Question about Yamaha YHT-160 System
Power problem if the reciever was blow by overheat,what parts needed to charge so it work?
  • Dave DeGain
    Dave DeGain May 11, 2010
    I have no idea what you are talking about. If there is a problem with your receiver and it overheats, there could be many different problems causing it. You need a mult-meter to be able to check the parts that must be replaced, and some parts may even check good, but still be bad. Electronics are not like a car, when you have a certain symptom you replace a certain part. With electronics you can have one symptom and then have 10 different things that cause the one symptom.
    You also need very good soldering skills, a schematic helps a lot, and then you must understand how the components work together so you can find all the bad parts by measuring voltages and knowing what those voltages mean.
    If you miss one part that needed to be replaced, then turn the unit on, you most likely will destroy the parts you just put in.
    I have seen many people try to fix their own electronics over the last 18 years who did not know what they were doing, and only a couple of times did they not cause more damage than they started with. Do yourself a favor and get it looked at by a professional technician. But if you insist on checking it yourself, and you have at least a multimeter, I can direct you to the most likely compnents that are bad.
    President:
  • 624 Answers
Have you read my clarification request? If you have a multimeter and know how to use it I can guide you thru finding out which parts need to be replaced.
Posted on Oct 16, 2008
Hi the garage has just charged the alternator on our 2004 Mini Cooper as the battery light was coming on. The heater was working fine and blew hot air prior to this. The heater is now blowing only cold air...
Ask garage if they removed and water hoses to swap alternator.Needs proper bleeding after draining. Minis prone to water loss and overheats...dont drive till sorted...got a 59 plate cooper in workshop now...needing full engine due to overheats. Very important to bleed properly and pressure test to ensure no leake ( usually fron thermostat housing.
Oct 27, 2013 | 2003 Mini Cooper
Macbook 7.1 overheats
Take it to a trusted computer dealer and have them replace the thermal paste between your heatsink and your processor. Also, make sure to blow out your fins that blow the hot air out and pull the cool air in. This should resolve the overheating issue.
Apr 25, 2017 | Harman Kardon Computers & Internet
I have a 2002 Olds Alero GL my heater is not working and car overheats peoriodically losing antifreeze, please help freezing in Montana
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----
Engine Overheats and heater blowing cold? http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Jan 20, 2012 | 2002 Oldsmobile Alero
I think I need to replace a fuse in my Whirlpool Microwave oven, but I can't find where the fuse is located?! Help!
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. If the model number you listed this question under is correct, you have THREE possibilties that may cause a complete loss of power: 1. Line fuse 2. The Oven Cavity Thermostat. 3. Thermal Cut-Out (Thermostat) for the Magnetron. The line fuse is connected in line with the power cord inside the unit and is listed as part of item 28 under the "Interior and Ventilation" parts heading. The thermostat for the oven cavity is listed as item 29 (part number 8183703) under the same parts heading. The thermostat for the Magnetron is listed as item 15 under the "Magnetron and Turntable Parts" heading. The part number is 8183698.
I would recommend you check the fuse, first. This the easiest and least expensive repair. It is also the most common. If you managed to overheat the oven any time recently, you may want to check the thermostat(s) to see if it is still good, next. They should read 0 ohms when measured out of the circuit across the terminals.
If the line fuse is blown, you can usually purchase a box of fuses at a hardware store for just a little more than what the manufacturer charges for a single fuse. 125V, 20AMP Ceramic Slow Blow fuses are recommended.
If you have any questions, or need additional assistance troubleshooting, please post back and let me know. I hope you find this information helpful. NOTE: Baked potatoes, steamed vegetables and popcorn are notrious for causing high humidity and/or overheat conditions in an oven cavity. If you find any of the thermostats tripped or blown, remember to allow the oven cavity to cool by leaving the door open between cooking items. This should only take a few minutes. Repeatedly heating items one after the other can cause high humidity and heat which may cause the thermostats to trip. Some of these thermostats reset themselves, others you need to replace.
NOTE: Make sure you take any resistance readings with the microwave UNPLUGGED and the component under test isolated (removed) from the circuit. These ovens can blow a fuse by simply sitting idle. This can occur from any power fluctuations, brown outs, voltage spikes, etc. Or, it could be the symptom of a component that may have failed. If you find the internal fuse blown and replace it, only to have it blow again, you have a more significant problem than a simple blown fuse.
Jul 12, 2010 | Whirlpool MH7155XM Microwave Oven
Nothing works at all. It's plugged in and the breaker is fine.
There is usually a 125V, 20 AMP line fuse inside the microwave, mounted at the point where the power cord enters the back of the unit. Unfortunately, you will need to uninstall the oven (if this is an over the range model), UNPLUG it and remove the exterior case to access. The case comes off in various ways depending on manufacture and model. If the model number you listed this question under is correct, you have THREE potential causes for a complete loss of power. 1. Line fuse 2. Line filter/noise filter circuit board 3. Thermal Cut-Out (Thermostat) for the Magnetron. The line fuse is connected in line with the power cord inside the unit and is listed as part of item 11 under the "Blower-Motor" parts heading. The line filter printed circuitboard is listed as item 19 (part number: R9800472) under the "Blower-Motor" heading. The Thermostat for the Magnetron is listed as item 8 (W10254040) under the "Cavity" parts heading. The most expensive part is the line filter board, which runs about $25.
I would recommend you check the fuse, first. This the easiest and least expensive repair. It is also the most common. If you managed to overheat the oven any time recently, you may want to check the thermostat to see if it is still good, next. It should read 0 ohms when measured out of the circuit across the terminals.
Jul 01, 2010 | Amana AMV5206 Microwave Oven
What could make my 03 civic ex overheat and cool down then overheat again while losing heat inside??? Already replaced radiator, water pump, thermostat.... motor
your heater has apparently restricted the coolant flow....hopefully a good system back flushing will cure the problem....use a flush obtained from a parts house....I would buy the hose kit for flushing as well...good luck to you
Mar 04, 2010 | 2003 Honda Civic
Philips 42fd9954-175 Plasma won't power up
Failing capacitors in the power supply have now failed completely.
Had never tried blow-drier as a TV service tool.
Heat changes the resistance of many parts, especially dying capacitors. Heat also causes parts to expand, such that cracked solder connections are closed up.
Oct 21, 2009 | Philips 42FD9954 42 in. Plasma HDTV
Vector vec 051D 3000 watt fan won't run anymore, unit overheats
your inverter needs to cool at all times , if the fan does not work,try buying a small standing fan to blow cool air to you machine, it is possible that your heater is making the inverter to over heat please avoid using the heater on the inverter
Feb 26, 2009 | Vector VEC056 MAXX Power Inverter
Yamaha YHT-160 System Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
