Question about Jenn-Air JJW8430D Electric Double Oven
Oven door locked - jenn air
Oven door remains locked after self cleaning
  • 4 more comments
  • goldenbearnw Nov 16, 2008
    I cleaned my oven & now it won't unlock
  • wolala1 Jan 12, 2009
    aaaaaahhhhhhhhhhhhh
    can't open the door
  • Heather Jones Apr 20, 2009
    ran a self cleaning cycle. Haven't been able to unlock or open oven since.
    How do I fix it?
    oven is stuck in lock mode from the self cleaning cycle.
    How do I unlock it?
  • Anonymous Mar 30, 2014
    Not locking
    will not begin cleaning cycle
My Jenn-Air double oven locked after a clean cycle. My model (JJW8630) has a series of slots cut in the top of the door. Take a piece of stiff wire, coat hanger, and bend a right angle about 1/2 inch at the end, feed the wire into the 3rd or 4th slot from the center on the right hand side. Turn the wire so that the bent piece is on the top and push the wire so it engages the lever which latches the door shut, it is spring loaded and moves easily.
Once the door was opened, I removed the temperature sensor, held by 2 screws, from the top of the oven and eased the wire out to get to the connector. The faulty sensor was reading 4.2 k, at room temperature it should be just over 1k, while waiting for a new sensor to arrive I stuck in a 1k resistor, ex Radio Shack, so the fan stops running and the door latch can be retracted by closing the oven door, or press the switch on the top right of the door opening.
My replacement part was ordered on line for less than 1/2 the official quoted price.
Hope this helps.
Posted on Dec 05, 2008
The door won't lock when I put it in the self cleaning mode.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 16, 2011 | Jenn-Air Ovens
I tired setting the bottom oven to the clean cycle, it switched on for a few minutes, then locked. It didn't finish the clean cycle and the door remained locked. I have tried setting the clean cycle...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 29, 2010 | Jenn-Air Electric Double Oven
Model SVE 47600 - oven door remains locked after self cleaning
Called an appliance repair serviceman....after checking it out...turned out to be a sensor that actually burned up (first time using cleaning feature!!). The oven got so hot it actually burned the wiring going to this sensor. Pretty scary! The repairman said he doesn't trust the self cleaning feature...recommended doing it the old fashion way! He's had to repair many ovens due to the lock remaining locked. IF you do use the feature, he said to absolutely remove the racks first because they will slowly warp and you'll end up replacing them due to uneven cooking (i.e. lopsided cakes). It cost me nearly $200.00 to clean my oven! Could have had my entire house cleaned for that amount!!
Jan 27, 2009 | Jenn-Air JJW8430D Electric Double Oven
Jenn-Air stove locked
After the lock indicator light goes out, move the door lock lever to the left. The oven door can now be opened. Turn the selector and temperature knobs from clean to off AFTER THE DOOR IS UNLOCKED. If the temperature knob is turned to off BEFORE the door is unlocked, the door will not open. Forcing the lock will damage the lock mechanism. If this should happen, return the temperature knob back to CLEAN, unlock the door, THEN turn the temperature knob off. Source(s): Jenn-Air Grill Range with Self Cleaning Radiant Bake and Convection Oven models S136, S156, S161
Dec 10, 2008 | Ovens
Jenn Aire lock for self clean in locked position
The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
Do NOT force the door.
Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
Lever open, set the knobs to OFF and away you go
Oct 26, 2008 | Jenn-Air Ovens
Need help unlock oven after self cleaning jenn air jjw9527
The temperature setting must be set on "Cleaning" and the oven cooking dial to "Clean"; otherwise the door will not open and forcing will damage the mechanism. Also, before the door will open, the internal temperature must drop to a safe level and a red "cleaning" light must go off, after the temperature drops inside the oven.
Aug 23, 2008 | Jenn-Air Ovens
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Jenn-Air Oven - Model W46 - Door Lock Lever came loose
you have to turn the breaker off then pull the oven out from the wall till you can get the top off the motor is at the front you will see how it goes
Jan 30, 2008 | Jenn-Air JJW8530C Expressions Collection...
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn-Air JJW8430D Electric Double Oven Logo
931 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
