Air conditioner Unit turns on. Fan blows cold air, but the compressor does not turn on
  • shanesligo Oct 06, 2008
    My FOMA(Norwegian) A/C system blows cold air when I turn it on to heat. Frost forms on the outside pipes very quickly.
My window unit makes a noise from the compressor and the compressor shuts off after it gets hot
Posted on Jun 22, 2009
  • 828 Answers
If the fan blows cold air the compressor is already on.
Posted on Jul 18, 2008
4 Suggested Answers
  • 400 Answers
SOURCE: Compressor not turning on, no cold air
you need new capcitor in your A/C and do also use , if can the (Stabilizer) for coolest performance.... thank you
Posted on Jun 30, 2009
  • 54 Answers
SOURCE: Danby DAC5020 Air Conditioner fan works but not compressor
It could be as simple as being low on refrigerant. Depends on how expensive the unit is if its worth recharging and how big the unit is. Some small units will need to have a recharge point fitted which cost more of course.
Posted on Jul 02, 2009
  • 93 Answers
SOURCE: Compressor hums but fan not turning. Pushed fan to
cap most likley
Posted on Jul 16, 2009
I just replaced the fan and the capastitor on an outside air conditioner unit yesterday. Today it was blowing so cold I increased the temp. on the thermostat. Now it is blowing 77 degrees air instead of...
The air being blown at the condensing unit isn't the air that blows inside. I seriously doubt what you said about it getting so cold. I believe that the wires to the capacitor were improperly installed, and your compressor isn't operating. Don't confuse the outdoor fan operation with compressor operation (they both share the same contactor as a switch). On the capacitor, the brown wire connects to fan, compressor attaches to "HERM" common attaches to the contactor. I didn't mention the colors of the common or compressor wires because they differ among manufacturers.
Aug 27, 2013 | Goldstar R1003 Air Conditioner
Amana Prestige II air conditioner. The fan unit on the top of the ouside unit stopped spinning. I gave the fan a good push and it started spinning (and continues to spin) however the air now blowing into...
You need to replace the fan capacitor. Your compressor is probably in thermal overload you can cure this by turning off the disconnect your ac voltage and taking a cool water hose and running over the top of the compressor for a while. Then turn your disconnect back on and listen and feel of the big copper line to see if it gets cold and also listen to see if the compressor kicks on.
Aug 08, 2011 | Heating & Cooling
How do I know if compressor of my house air conditioner is turning on when I start my air conditioner? When I start my air conditioner the fan outside the house turns on, the air is blowing from the vents...
if the compressor is starting there will be a very small dimming in the house lights,if you go outside to the unit and start it from the outside disconnect when the compressor starts you will hear a whine type noise coming from the outside condenser unit that is the hermetic compressor motor operating,no cold air can be a number of issues,low on refrigerant(not likely on the new sealed systems) a bad motor start/run capacitor(quite likely) a bad contactor on the outside unit that supplies power to the compressor,one leg of the 240volts that supplies the compressor power,the fan will run on 120 volts,but the compressor needs 240 volts check the fuses.breaker in the power panel
Apr 02, 2010 | Heating & Cooling
Is the outside unit running? if so can you feel warmer than outside air blowing from outside fan? If not your system may have a leak and pressures low. You can also check the piping to and from the unit larger one should be cold small one should be warm
Jul 03, 2009 | Whirlwind FH-778 Air Conditioner
Uotside unit blowing cool air but hot on the inside
It sounds like you have a unit called a heat pump. When a heat pump unit is in cooling mode the outside unit blows hot air and the inside unit blows cold air. If the outside unit is blowing cold then the indoor unit is most likely blowing room temperature or warm air. It sounds like the thermostat could be controlling incorrectly or you could have a failed reversing valve which is the device that switches the unit from heating to cooling mode.
May 31, 2009 | Ruud UBHC Air Conditioner
No cold air
if unit is more than 5 yrs old dump it!!! most frigidaire models just dont last...that is why they are so cheap...get it???
Jun 09, 2008 | Frigidaire FAH085N1T Air Conditioner
Comp shuts off
Coils could be dirty. Compressor could be getting too hot and cutting off. Will have one fan motor that turns condenser fan and evaporator blower.
May 30, 2008 | Fedders D Chassis A6D24E7A Air Conditioner
Air conditioner problem
You may have an extremely intolerant cold control, a weak gaurdette on the compressor, a compressor motor winding issue, or maybe an oversized unit for the area you are trying to cool.
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
310 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
