Water wont go into drum, it goes straight out the drain and the some lights start flashing
    President:
  • 1,462 Answers
Suspect you have the drain down at floor level. drain hose should go upwards to about the height of the worktop before going down to drain. if you are draining into a standpipe, put drain hose only a few inches into the standpipe, not right down to the bottom or a syphon will form
Posted on Jul 18, 2008
Hi Machine will no start..At first all lights flashing and now just start and reset button flashing.. Start button flashes 3 times reset button flashes 5 times. Can you help. Cheers
I have a zanussi zwf1432w aquacycle.
Hi Machine will no start.Starts to fill,Stops and goes straight to drain.There is no blockages in filter or pipes,Have checked all,Even pipe from drum to filter.
Can you help.
Cheers
Apr 05, 2011 | Washing Machines
Gmail.com I have just moved, my LG Turbo drum was working fine but i have set it up and now it wont hold the water, straight in straight out, can you help?????
The drain hose can not be sealed to the drain pipe, and it can not be shoved so far down the drain pipe that the end of the hose reaches the water level in the drain trap.
Mar 03, 2011 | LG Washing Machines
Wil163 3 lights flash mid wash
My machine starts filling with water, then the power button and the two next to it start to flash, and the water starts to drain from the machine.
Apr 12, 2009 | Indesit WA 115 Front Load Washer
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
L63 Salt light is flashing
goes for short time and 2 ljghts flash the red salt light wont go on
May 16, 2008 | Ariston Technologies L63 Free-Standing...
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
