Question about Ezonics EZCam Webcam
Webcam plugged in my wecam an its not working ..the computer cannot find any software for it to work
  • 515 Answers
Make sure to install the drivers first, then plug in the camera.
Posted on Jul 18, 2008
Acer crytal webcam will not work 4339 series
try installing the drivers from the disc first then plug in your wecam in ,if you dont have disc then plug in the webcam and see if your laptop says,,found new hardware if it does let the windows go and find the drivers.
May 29, 2014 | Acer Aspire 5610-4648 Notebook
I don't arrive to access my webcam
Download the latest driver on your webcam.
Nov 25, 2013 | MSI U130416US Netbook
Im getting "camera no found"
The error message "Webcam Not Found, Connect USB Device Message" or a message stating to plug in a webcam, indicates that there is an issue with thewebcam hardware.
The system will need to be serviced to correct this issue.
If the error is just regarding webcam not found, the drivers and the Application has to be installed.
Oct 25, 2010 | Acer Computers & Internet
I installed my wecam but when i try to go on a coversasion on windows it wont work
Set your webcam mic (if it has one) as default
If you have an earlier OS than Vista, you may have to access your hardware from the Control Panel and set the default mic from there - make sure its plugged in.
VISTA
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in, after a few seconds, to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
Aug 23, 2010 | Logitech QuickCam Express Web Camera
My hp deluxe wecam freeze every time i turn it on! my window vista says it doen't recognize it! how can i fix this problem so that my wecam stays on?
Go to the HP.com website, Support section, and download the driver for XP. Then go to Control Panel, Hardware, Devices and look for your webcam. Go through the tabs to make sure it is Enabled. Be sure your webcam is plugged directly into the computer and not through a hub or cable. You can also test your webcam on the free webcam test tool.
May 14, 2010 | HP Webcam
Sony Vaio webcam does not work on MSN
did you run the webcam configuration on messenger?
if you did then i would contact microsoft to see if it is compatible with your webcam.
Aug 15, 2009 | Xirlink Promax Webcam
How to activate wecam in hpcompaq laptop
install a quickplay software. its really easy to use webcam through quickplay.
Jul 26, 2009 | Compaq Computers & Internet
My Logitec Webcam Pro 4000 does not work.
i have lost my cd that came with my webcam could u please tell me the site where i can download the software
Jan 07, 2009 | Logitech QuickCam Pro 4000 Webcam
Wecam will not work
are you refering to a webcam? if its a webcam, make sure that its properly plug-in and the proper drivers are installed in your computer.
Aug 21, 2008 | Cameras
Sakar 49152n webcam
your computer might not recognize the sakar 49152N wecam if you connect it to your PC through a USB 2.0 hub if the hub also has slower USB 1.1 devices connected to it. This is a problem with the sakar 49152N wecam firmware, and downloading a firmware upgrade.
As a general word of caution, upgrading a device’s firmware is similar to editing your PC’s registry. Be absolutely certain you know how to perform the necessary steps before actually carrying them out. A botched firmware upgrade can irrevocably damage your hardware.
Mar 08, 2008 | Cameras
Ezonics EZCam Webcam Logo
46 people viewed this question
Top Ezonics Computers & Internet Experts
micky dee
Larry Maranto
Mark Gough
Are you an Ezonics Computer and Internet Expert? Answer questions, earn points and help others
