Question about Lite On Spark Plug Lite Green LED
No spark at the spark plug
There is no spark at the spark plug and have put new coil and asd but still no spark 1994 toyota camery no spark to plugs. Engine turns over fine and everything else seems to be working. I tried replacing ignition module and still won't fire up. the distributor & coil are one unit would this be the next likely guess to replace?
    Brigadier General:
  • 3,614 Answers
Check first if your battery got a full charge, or not drained...
Let me know..
Posted on Jul 18, 2008
2001 toyota tacoma truck 4 cylinders engine shakes at all speeds
Vacuum leak if not then u burned a valve
need to check compression on all 4 cylinder
but remember to find Vacuum leak or the same thing well happen again
Dec 27, 2014 | Replacement 2001 01 Toyota Tacoma Fan...
I have a 1995 dodge ram 1500 3.9 engine two wheel drive not acceleration
Sounds like ya got a burned valve and its not letting you axlerate like normal also with a burned valve you could be doing harm to thepiston inside the block as well but you also want to check your spark plugs as well
Jul 12, 2014 | Hayden-Harnett 1994-2007 Dodge Ram 1500...
No spark
Did you check the coil wire itself? A break in it will be hard to see. Get another one, or temporarily borrow one from one of your plugs, just for long enough to see if it gets spark. If it does, you know the rest, I'm sure. I'd check all plugs and be sure that little wire under the cap is on the tab. I've had a breaker plate wire fall of on me once, took forever to figure that one out. Even an electronic ignition needs to be grounded at the distributor. You've probably just got a connection issue.
Let us know if there's still a problem.
Apr 20, 2014 | Lite On Spark Plug Lite Green LED
Loss of top end speed and loud engine noise
Well you might have loosened the exhaust or have bad compression from the pistons try some pressure tests and get the manual and read the specs Other than that it could be a minor repair
Mar 23, 2014 | Kingwin Duro Bearing Silent Series 120mm...
Car starts then stops wont run on lpg recon head justinstalled
I'm sorry, but there is just way too much going on with this to try to fix online. You need to either call a shop or get someone who knows what they are doing to look at your vehicle. The only other thing I might suggest is getting a Chilton's manual for your model of vehicle. Come back if you get it narrowed down any.
Feb 19, 2014 | Depo Auto Parts Toyota Camry New Radiator...
2000 honda crv engine
coil, stator, or wire to ground and to kill switch, it is grounding out somewhere - remove from coil to test.that.
Get inline spark tester at princess auto cheapie 6.00 can, or 10 for a good one. spark plug, timing, head gasket burn valve, hard to tell without compression test. if low put cap of oil in cylinder and if goes up is rings, if stays low (under 50lbs should be 90.) if stays low is a valve or head-gasket.
Check plug if dry when trying to start vehicle with choke on then remove spark plug and inspect it.
is carb or fuel problem if dry, is electrical if wet!
check fuses, and stuff and wires but probably a CDI unit to control the spark, or if old is a set of points and condensor and the spark must be triggered by a CDI, a lobe, or a coil CDI unit combo.
The coils on stator send 12 volt, coil to sparkplug send 20,000 volt and the gap in points or ruluctors should be set properly, typically stator to reluctor is set by a book of matches not folded but put piece carboard in between,spark plug gap say double that..
I suspect without more input fuel or spark. if the engine wont turn over the fuel to oil mixture wasnt enough, or the oil injector for fuel mixture if two stroke maybe clogged and may destroy your engine.
I don't suspect this but giving things to consider later.
Some bikes there is wires in a rubber plug as a chaijn indicator and the chain can break this connection, not sure about 4x4 though.
Nov 01, 2013 | Computers & Internet
What is the name of the spark plug on the feb 20 show
E3 Spark Plugs provides automotive spark plugs designed to increase power, improve fuel efficiency, and reduce engine emissions.
Feb 20, 2010 | Lite On Spark Plug Lite Green LED
Spark plug wire diagram 94 plymouth laser
I am not sure whether you have the 1.8L, 2.0L, or 2.0L Turbo; however I have included all below.
You Posted your Car Question under a different (non car) (Home| Lite On | Spark Plug Lite Green LED| Problem) heading.
I work on pretty much only vehicles, and found your problem today.
For the 1.8L SOHC
Firing Order:
1-3-4-2
Cylinders:
(back of engine)
4---3---2---1
(front of engine)
Distributor:
...(back)
(+)..1
2..........3
......4..(+)-screw
...(front)
For the 2.0L DOHC AND 2.0L Turbo:
Firing Order:
1-3-2-4
Cylinders:
(back of engine)
1----2-----3-----4
(front of engine)
Ignition Coil Connections:
......(back)
........3
........2
........1
........4
......(front)
Let me know if this helped or if you have additional information or questions. Feel Free to contact me at FixYa.com!
Feb 08, 2010 | Lite On Spark Plug Lite Green LED
No spark
what kind of car and engine size please
Aug 27, 2008 | Lite On Spark Plug Lite Green LED
hi i have a 1997 el ford falcon i was told it was the coil so changed it and i still have no spark
Jan 16, 2008 | Lite On Spark Plug Lite Green LED
Computers & Internet Logo
177 people viewed this question
Top Lite On Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mike McWhinney
Michael Vanidestine
Michael Vanidestine
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
