Piece of s@#t!
O.K.-I sat on my remote for about 10 minutes and fell asleep;I awoke and the screen is blue and a red lock is on the bottom of the screen.I turn it off and on; It stays that blue.When i touch any button the red lock appears again;even if i touch menu or v-chip or anything i try.I took out the batteries,unplugged it for an hour,even tried a different outlet.WHAT THE @#?K!!!! Help me please-It is a Akai ctd 1390 and it doesn't know who it's messin' with. I Ain't Afraid To Go Back To Jail,Somebody Better Tell That T.V. That Cause I Ain't Playin'!!!!!!!!!!         Seriously, if someone has the answer i seek i will kindly put the T.V. down from over my head and start goin' back to church again.  Our AKAI CTD29STR Television has the child lock stuck on. We don't know how it was turned on. Could you please tell us how to turn it off? We only have a universal remote. The original was broken. I hope you can help me. Thank you for your time.
The button at the bottom that says c lock. at first i thought it meant clock but if you look closely, press it twice. hope this helps
Posted on Sep 13, 2008
I fell asleep on my Emerson LC320EMX 32 hdtv remote; when I awoke, the tv was flashing ONLY colors (red, black,blue,white)...Now, How do I get it out of that mode....I was told its stuck in set-mode ?
I had this problem with the LC320EMX, after extensive searching on the internet, I found a solution. The TV has entered some kind of test pattern, to escape from the flashing color test pattern do the following:
While the screen is changing from red,green,Blue,White, & Black, and is Unresposive, Take your factory remote, Press the up arrow, then the down arrow, then (ON THE TV) press the power button. Turn the set back on and it should be functioning properly. (BTW: the set gets into this test pattern if you press too many buttons on the remote, or if you use a universal remote with the wrong code)
May 31, 2012 | Emerson LC320EM8 32 in. LCD TV
I fell asleep with a DVD playing, when I awoke, the TV screen was as if the DVD has been removed and nothing was in there to read. I checked it, disc was still inside... Powered off for a few minuted. Once...
1: Unplug player. Wait 10 minutes or longer. Make sure disc is clean then Plug back in and try again.
2: Do a factory reset. Should be under settings.
Oct 06, 2017 | Panasonic DVD-S27 DVD Player
I fell asleep with the tv on and when I awoke, the on/off red light just blinks and there is a "burning" odor
How many times does the light blink as thats an error code indicating which circuit has the problem. Let me know how many blinks and I will assist you with the problem.
Jun 13, 2011 | Sony KP-57WS500 57" Rear Projection...
I accidently sat on remote for centrex t.v now all i have is a blue screen and a red padlock sign, how do i unlock
pls check hideen key on remot cantrol
try digit key [- - -] preesing 3 to 5 sec. and see key lock is off than re set preesing 3 to 5 sec and see on the screen tuning lock is off
or
lock key on remot cantrol pls. press 5 to 10 sec.and see the screen red padlock is opan or green then try remot cantroll any function use normaly
Oct 26, 2009 | Televison & Video
I have accidently locked my tv
Turn off close captioning feature
Feb 21, 2009 | JVC AV-32D305 32" TV
Blue tv screen red padlock
Hold the display button down on the remote for 3 seconds.
Sep 17, 2008 | Jensen TS2050J 20" TV
Piece of s@#t!
Sounds like you  accidentally "set" the parental lock while you were sleeping.
Try this trick: (may or may not work)
aim the remote at the TV "IR sensor", hold down "display button" on the remote for 10 seconds to erase or clear the password.
"IF" this works go into the menu and "TURN OFF" parental control.
Oct 20, 2007 | Akai CTD-1390 TV
Phone is locked and wants code ???? to unlock
The master code for the LG 800 should be 0000
Aug 15, 2007 | LG KG800 Cellular Phone
Magnavox 68 cm tv model mptv68a
i have a magnavax mptv68a, the red button is on but the screen is blank, it doesn't even appear to turn on. can you advise me on what to do
Jun 11, 2007 | Philips Magnavox 27MS343S 27" TV
No power
your going to have to check out the main power supply or standby power supply. good Luck
Jul 25, 2006 | Samsung LN-S3251D 32 in. LCD HDTV
Open Questions:
Televison & Video Logo
134 people viewed this question
Top Televison & Video Experts
Electro Med Services...
