Acer Aspire One  PC Notebook Logo
Posted on Jan 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Touchpad of my acer aspire notbook is not working. i checked through device manager and it says it is working properly and no hardware conflict. What is the solution?
Anonymous
Level 3:
  • Master 394 Answers
  • Posted on Jan 26, 2011
Anonymous
Master
Level 3:
Answers
394
Questions
0
Helped
96776
Points
1209
Hi, I am Steve, lets get you some help
The most likely reason is because it is disabled. Usually fn + f7
2answers
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
My acer laptop 5742G not working scorlling
Check the touchpad driver in device manager: control panel>hardware and sound>device manager. Look for; mice and other pointing devices and expand the menu. You should see the touchpad driver here (synaptics or elantech) right click on it and click properties and check that its working properly in the general tab. On the drivers tab, click update driver and search automatically for updated software. If the driver is not installed or has become corrupted, you can follow this link to download and install a new driver: http://support.acer.com/product/default.aspx?modelId=3278
Acer 5532 Touch Pad Not Working
Here are a couple of ideas from a Google Search:
Press the key to the left of the On/Off button. The key has a picture of a finger pressing the touchpad. So simple, so elegant, so little information out there about it.
https://answers.microsoft.com/en-us/windows/forum/windows_7-hardware/my-touchpad-on-my-acer-aspire-5532-laptop-isnt/51f5de30-b465-e011-8dfc-68b599b31bf5?auth=1
Dead keyboard and touchpad at login prompt
Try downloading ubuntu linux live cd. You can boot directly into linux without installing it. See if your keyboard and touchpad work in there. If not then it is a hardware problem. If it does work you may want to consider backing up your files and reinstalling windows.
2answers
Keyboard/touchpad intermittent don't work
Try updating the drivers for the board/touchpad.
You can go to device manager and see if there is any noted problems and also update drivers and check other settings from here.
To get to device manager, go to control panel, performance & maintenance, system, hardware, device manager.
My left touchpad button on my Acer Aspire 5630 stopped working. I can hear click, but nothing happens. Any suggestions?
go to control panel, mouse &pointing devices check advavced settings if all are ok go to system, hardware, device manager,mice & other pointing devices check that there no conflicts click on troubleshoot if you still have a problem buy a corded or cordless mouse that will connect to usb
My daughters boyfriend tried to down load something to his phone from my daughters acer extensa 5420. Now the key board and touchpad will not work. I can get to f2, and the keyboard works there. Help...
if you have a usb keyboard and mouse this isn't too difficult to troubleshoot, plug them in, boot the computer and you can manipulate the pc like normal. then go to control panel>system>device manager, and check and see if there is a conflict with the drivers, and you can visit the acer website and download the proper ones.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
1helpful
2answers
Toch pad locks up at startup, but work fine in safe mode on acer Aspire 3000
Try pressing Fn+ F9 to unlock the Touchpad
If that doesn't work try reinstalling touchpad as new hardware.
Start-
Control Panel-
System-
Hardware-
Device Manager-
Mice and other pointing devices
click +
right click and delete touchpad-
Reboot
5helpful
2answers
Touch pad inactive
press the Fn+F7. Fn is between the ctrl and window key.
4helpful
4answers
Acer Aspire 3004 keyboard and touchpad error
Just resolved same problem on Acer Aspire 5000 by removing the battery, then goto device manager and disable "Microsoft ACPI-Compliant Control Method Battery" you can then put your existing battery back into the latop with any problems with the keyboard and touchpad. Mad solution I know but it worked for me
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
