Question about Apple iPod shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A)
Ipod is not powering on
My ipod shuffle 1st generation is not turning on.it is synchronizing with my pc but is not switching on.it also get charged.the problem begins when bettry was low n i was still listning to some songs.it suddenly get of n knw its not swithing on.i tried the restore factory settings but its still not powering on.what is the suggestion plllllzzzzzzzzzzzzzzzzz help
  • 1 more comment
  • allahoakbar_ Sep 12, 2008
    sir can u plz tell a further and explained solution.thank u sir
  • Anonymous Oct 17, 2008
    my ipod
  • mizzymissy Oct 17, 2008
    my ipod wont charge and the screan stays on the same song but i cant hear anything it says it needs to be restore but that thing wont pop up anymore
  • 8,596 Answers
Do the 5 R's - any mp3 player - not just iPod - is prone to acting goofy on low batt
http://www.apple.com/support/ if you need further explanation
Posted on Sep 05, 2008
NEED INSTRUCTION FOR Apple iPod shuffle 3rd Generation Silver
Connect the iPod shuffle USB cable connector into a high-power USB port on your computer.
Note: To charge an iPod shuffle battery, connect the device to a high-power USB port.
Please be aware that USB keyboards and non-powered USB hubs generally do not have high-power USB ports.
If you connect to a low or non-powered port, iPod shuffle will not charge.
The computer must be turned on and set to not go to sleep.
Plug the other end of the iPod shuffle USB Cable into the headphone port on the iPod shuffle.
Verify the iPod shuffle is connected securely.
Once the iPod shuffle is plugged in, it will take about 2 hours to charge the battery to 80% capacity and about 3 hours to charge it to 100%.
Find out how to check the battery charge here
hope this helps
Sep 18, 2012 | Apple iPod shuffle 3rd Generation MP3...
I was given an i pod shuffle as a gift from a friend but when i went to apple support the i pod had been disabled. how do i fix it so that i can put my own apple itunes on. thanks anne marie
To reset iPod shuffle:
  1. Disconnect iPod shuffle from the computer (if connected).
  2. Move the switch on the iPod shuffle to the OFF position. Note that when iPod shuffle is off, the green stripe by the switch is not visible. ht1655_1.gif ht1655_2.gif ht1655b_3.gif ht1655--4th_shuffle-001-en.png
    1st generation 2nd generation 3rd generation 4th generation
  3. Wait five seconds. For iPod shuffle (3rd and 4th generation), wait ten seconds.
  4. Move the switch to the play in order or the shuffle position. The green stripe will be visible in either position. For iPod shuffle (2nd and 4th generation), slide the power switch on (and you can see the green stripe).
Feb 24, 2011 | Apple iPod touch
How to use an ipod shuffle charge
Use iPod Reset Utility to restore the following iPod models back to their factory settings when iTunes is unable to do so. The process completely erases all music and data and reinstalls the iPod software version listed below:
  • iPod shuffle (1st generation) - iPod Software version 1.1.5
  • iPod shuffle (2nd generation) - iPod Software version 1.0.4
download here
http://support.apple.com/downloads/iPod_Reset_Utility_1_0_4_for_Windows
then install..
follow these instructions..
Using iPod Reset Utility
  1. Quit all running applications on your computer.
  2. Open iPod Reset Utility.
  3. Connect iPod to a USB port on your computer. Do not connect iPod to a USB port on your keyboard, or other non-powered USB hub.
  4. Click the Reset button.
  5. If prompted, enter an administrator name and password. Notice: Do not disconnect iPod during the reset process.
  6. When complete, quit iPod Reset Utility and open iTunes to load music onto iPod.
Jun 05, 2010 | Apple iPod shuffle MP3 Player
1st series ipod shuffle...working fine did latest install from itunes and now ipod will sync but won't play...does repeating of green and orange lights. Tried the restore and resetting but still not...
Here's simple steps to cure the problem if your iPod shuffle won't play and does that green-yellow-green-yellow-green-yellow blinking thing:
  1. Plug in iPod shuffle
  2. You'll notice the "Podcasts" play list under your iPod volume.
  3. Delete the "Podcasts" playlist.
  4. ITunes will re-sync
  5. Unmount the iPod Shuffle and everything should be fine.
If that doesn't work try the link below. It's for the iPod Shuffle (1st generation) restore utility.
Hope it helps.
http://support.apple.com/kb/HT1238
Oct 24, 2009 | Apple iPod shuffle MP3 Player
1st generation shuffle ....dead battery can it be replaced ?
Yes. The battery's can be replaced, assuming Apple still has them in stock.  I *believe* they use the same batteries as the newer versions.
However, the cost of the battery and the work to replace it, you're probably better off just getting a new shuffle.
Mar 19, 2009 | Apple iPod shuffle MP3 Player
My ipod shuffle (1st gen) is not working!
did u try pluging it in 2 a wall charger
Mar 14, 2009 | Apple iPod shuffle MP3 Player
Ipod using too much battery power
To turn off shuffle, enter the "Setting" menu, then select "Shuffle" use the forward/back buttons to change the value to "off". To turn off the "Shake" feature, again, enter the "Setting" menu then scroll down and enter the "Playback" menu. switch it to "off".
Mar 05, 2009 | Apple iPod nano 4th Generation
Cant get shuffle to work when not conected to pc
How long have you had the unit? If it's been a year and a half or 2 years your battery needs to be replaced. They loose their ability to retain a charge in that time frame, and when you test a good battery or a bad battery they will both read 3.6v as a tester does not put a load on the battery, meaning you have 3.6v when the unit is off but when it turns on (load) it drops to zero. You could also try resseting the unit, to do so follow these instructions. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. To reset iPod shuffle: Disconnect iPod shuffle from the computer (if connected). Move the switch on the back of iPod shuffle to the off position. Tip: When iPod shuffle is off, the green stripe by the switch is not visible. 1st generation 2nd generation Wait 5 seconds. Move the switch on the back to the play in order or the shuffle position. The green stripe will be visible in either position. iPod shuffle is now reset. If after resetting iPod shuffle you are going to attach it to your computer, be sure to place the switch in the off position. If you were resetting as part of some troubleshooting steps, continue with those steps now. For general troubleshooting steps see the iPod shuffle troubleshooting and service FAQ. http://docs.info.apple.com/article.html?artnum=302110 Hope this helps.
Sep 15, 2007 | Apple iPod shuffle MP3 Player
Apple iPod  shuffle Second Gen. Silver (1 GB) MP3 Player (MA564LL/A) Logo
41 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
