Question about Panasonic DMR-E55 DVD Recorder
Stays in self check mode
Keeps coming up self check and i cannot get the disk out
  • 2 more comments
  • Anonymous Sep 03, 2008
    Mijn recorder blijft een hele tijd een self check uitvoeren.
  • vinlaw Oct 04, 2008
    stays in self check
  • dallinas Oct 11, 2008
    My Panasonic DMT-E55 also gets stuck in self check mode and keeps rebooting
  • shepp_26 Oct 18, 2008
    ive removed the disk and tried another 1, but same fault happens but when trying to load the disk the unit just reboots, any ideas??
  • 98 Answers
If self check keeps going after 1 minute unplug machine and open top cover remove 4 screws that hold the recorder top cover remove disk reinsert screws and plug in see what happens.
Most of the time a small scratch or fingerprint on recorded disk cause these units to lock up
Posted on Oct 13, 2008
Why doesn't oven work after using the self- cleaning mode?
Check for incoming power; you may need to change the heater element.
Sep 11, 2015 | Whirlpool GBS307PD Electric Single Oven
Can not play dvd keeps self-checking what do i do
Sounds very much like a power supply issue. If the machine stays in self-check mode or shuts down without allowing a single disc to load and record/play, then you can suspect IC1 in the PSU (STRG6353 or similar). The easiest way to confirm this is by measuring the closest voltage rail (around 12V) to this device with a oscilloscope (a digital voltmeter is too slow). If it is too low or varies, then IC1 is the prime candidate. Check other components in the PSU as well, just to be sure there are no leaky components which may cause further trouble later on.
You can also update the firmware for this model, unless it has already been done.
Feb 08, 2011 | Panasonic DMR-E55 DVD Recorder
I have a Manitowoc s-450 with a AuCS-SI installed and it is set to not clean at this time. The machine is stuck in cleaning mode and is partially refrigerating. I disconnected the AuCS and it works fine....
When a Manitowoc goes into clean mode,It stays in clean mode until it finishes.If you turn it off and then on again,it just keeps cleaning.Let it run in cleaning mode until it finishes
Aug 24, 2010 | Manitowoc 450 Lb Ice Cube Machine Self...
Our copier keeps turning itself off by its self
This code deals with the fuser unit. This is the section that heats up. To be safe you need to call a local canon dealer to come by and check the copier. Once the copier gives this code you can not reset it unless you go into the service mode to reset it.
May 14, 2010 | Canon imageRUNNER 5000 Copier
My ipod keeps showing me the red x
you have to set it to disk mode in itunes first then you should be able to acssess disk mode
Restore iPod from Disk Mode
  1. Disconnect iPod from your computer.
  2. Manually put iPod into Disk Mode as explained in support document 93651.
  3. Open the latest version of iTunes and connect iPod.
  4. Restore iPod as explained in support document 60983.
Mar 29, 2009 | Apple iPod classic MP3 Player
Hard Disk Failure
this error comes when the hard disk is not getting detected you need to follow following steps to trouble shoot
  1. check the power to hardisk
  2. check the interface cable ide/sata
  3. replace the cables & check if necessary
  4. check the boot sequence in bios
  5. check if there is a floppy od cd in the drive & remove it
Feb 24, 2009 | Office Equipment & Supplies
Just connected monitor won't come out of self check
Make sure your cable is the right one, and that it's truly well-connected to the monitor. My monitor stays in self-check when it's not receiving a signal from the ol' computer.
Jan 13, 2009 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Oven stays in locked door mode cant use oven
locked door is flashing and oven will not go on, help need to disconnect dorr latch if anyone knows how
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Panasonic DMR-E55 DVD Recorder Logo
388 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
