You were thinking about the buffer circuits - those can be found only on LCD screens. In a plasma the pixels are commanded directly by the Y and Z -sus boards. so if you have horizontal lines on the screen that are badly controlled then it's surely the Y-sus board's fault - it has failed and you will have to replace it.
Unfortunately finding an Y-sus replacement board for your model of tv will be very difficult - i couldn't find one online. Try searching thru auction and other sites that deal in second hand stuff, in repair shops (some of them by tv's for parts), but a repair shop of a dealer would be my best bet.
If they are vertical then you should replace the Z-sus board. Yes, you must also match the board to the screen - there will be a small semi-adjustable resistor, clearly labeled for that; see here
http://blog.coppelltvrepair.com/2010/04/...
Yes, i was referring to your NEC PlasmaSync 42MP4.
Follow the top and bottom connecting ribbons, they plug in it - it should be about middle right. Yes, that is all - the resistor is clearly marked on the board, look for it.
You need to pull the plastic casing in which they plug in, a little out to unlock the cable , then they will just slide out.
no, it needs a good cooling. it looks like that http://cgi.ebay.ie/ws/eBayISAPI.dll?VISu...
sorry, the address got chopped
http://cgi.ebay.ie/Scan-Driver-Board-NEC...
Yes, that should be it , but i'm not sure: check it yourself if the ribbons from the plasma panel plug, in your tv, in an identical looking one.
OK.
ok so does y-sus board control the pixels horizontally, and the z-sus board control the pixels vertically, becasue the lines on my tv run vertically. if i brought a new board would i need to do anything else apart from plugging it in??
plus my tv isnt a samsung as it says in the title
ok, which board is the z-sus board in my nec? would u also know where the small semi resistor is located on this board? so apart from this resistor there is nothing else?
ok thanks, one last thing, how do i unplug the ribbons?? i tried and i couldnt pull them out and i didnt want to force them??
i forgot to ask, is the z-sus board underneath the main motherboards
so ive just gotta replace this board and it should work fine? just to make sure, was that product on ebay the board i have to replace in my tv? is it the board which needs cooling cause i cant see my last comment, and i forgot exactly what i said. sorry about all the trouble mate, i just wanna be 100% sure on what i need to replace so i dont spend heaps of money on the wrong board, especially when im in year 12
ok thanks for your help mate
