Question about Belkin Computers & Internet
I have a belkin router without a integral modem, if i connect the telephone line straight into the computer then connect the ethernet cable into the input plug on the router how do i connect the computer to the router
  • victoria bennett
    victoria bennett May 11, 2010
    welcome to fixya
    what type of internet do you have? cable ,dsl or dail up?
    we will need this information to help you
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Hi
First you have to connect the telephone line to the integral modem and then using straight through cable to connect the computer to the modem.
Jyothish
Posted on Jul 18, 2008
I have a belkin router i am having trouble connecting it. i dont know where to connect the ethernet cable. Does it go the computer or the modem?
the ethernet cable should be connected to the ethernet port of the router to the ethernet/network port of the computer. you will also need to connect a cable through the router and the modem, then a phone cable from the modem to the phone line.
Aug 31, 2010 | Computers & Internet
Belkin router can't connect to internet
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
May 05, 2010 | Belkin (F5D8231-4) Wireless Router...
I have this router Belkin G Router Model :
belkin routers are compatible with all ISPs.... all that it requires is an ethernet cable that should come from ISP, either directly or through modem... so if your virgin connection gives you an ethernet port in their modem, you can configure the belkin router accordingly...
Apr 07, 2010 | Belkin Wireless G Router
Hi I cannot connect a NETLINK 2wire modem to my linkeye g router. What do I need to set so I can get the modem and router to connect
The 2WIRE modem will have at least 3 ports:
* AC power,
* 4-pin telephone-cable, connecting to a telephone-jack in a wall-port,
* 8-pin Ethernet-cable, connecting to the 'WAN' port on the LINKSYS router.
Look at both ends of the Ethernet cable. It's necessary that the colour-arrangement of the 8-wires is _IDENTICAL_ at both ends, i.e., a "straight-through" cable, NOT a "cross-over" cable.
With another "straight-through" Ethernet-cable, connect one of the LAN ports on the router to the network-adapter port on your computer.
Turn on the 2WIRE modem. Wait for the lamps on it to settle down to a repeating pattern.
Turn on the router. Wait for the lamps on it to settle down to a repeating pattern.
Turn on your computer. When Windows finishes booting, you should have a connection to the Internet.
Nov 27, 2009 | Patton Electric Patton NetLink MDSL Rocket...
My belkin router won't connect to internet, I set it up as the install wizard tells me but when it tries to connect to internet, it takes 10 tries and there is an error, it was a used router we bought so...
First, turn-off the DSL-modem (or the cable-modem).
Then, turn it on.
Check that you have a "straight-through" Ethernet cable -- all 8 coloured wires at one end must be in the SAME order at the other end. Do not use a "cross-over" Ethernet cable.
Check that the Ethernet cable from the modem is connected to the 'WAN' port on the router, not to one of the 'LAN' ports.
Turn the router off.
Turn the router on.
Reconnect to the router's web-interface, and see if the 'WAN' side of the router has obtained an IP-address from your ISP (Internet Service Provider).
Some ISPs require that you "register" the MAC (Media Acquisition Control) Address of each device that you connect to their service. So, browse through the router's web-interface, and find the "MAC-address" of the router, which will be different than the MAC-address of the network-adapter inside your computer, and telephone the ISP, and get them to "authorize" the MAC-address of the router.
Telephone your ISP -- they can "troubleshoot" your cable-modem from their end.
Nov 26, 2009 | Belkin (F5D7230-4) Router (587009)
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
How do i connect my router to my telephone line
The telephone line doesn't connect to the router. The telephone line goes to the modem which is provided to you by your internet provider. Then an ethernet cable is connected from the modem to the router.
The modem allows the internet connection to be active, The router is used to distribute the Internet to create a network.
Sep 16, 2009 | Belkin (F5D8231-4) Wireless Router...
Belkin FSD7230-4 Router
This is just a WAN router with wireless and 4 port switch.
It is not a DSL Modem.
In order to use this you need to use a Ethernet based CPE and connect the saem to this device.
Please find more information at the following URL under specification.
http://catalog.belkin.com/IWCatProductPage.process?Product_Id=136493#
Jan 27, 2008 | Belkin (F5D7230-4) Router (587009)
Modem connection
Your modem should have a RJ11 (phone) jack and a RJ45 (ethernet) jack. Phone line-in to modem RJ11. Ethernet cable from RJ45 to modem to router; maybe labeled WAN or modem port . Ethernet from any of the switch ports (or the only one avail, depending on your model) to you pc if it has a ethernet card in it. After that it's all up to the configuration.
Jan 04, 2008 | Computers & Internet
Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
Nov 09, 2007 | Belkin (F5D8231-4) Wireless Router...
Computers & Internet Logo
56 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
