Question about LG WFT1071TP Top Load Washer
Water flow very very slow though the pressure from main tap is fine
I have LG 5kg top loader. The incoming water flow to the machine is very very slow though the water pressure from the main tap is fine and in good pressure. What could be the problem? please advice
    President:
  • 1,462 Answers
Almost certainly not a fault with washer. check small filters in the fill hose and make sure hose not kinked
Posted on Jul 18, 2008
LG 5kg fuzzy logic model WFT5005T Top Load and it keeps screening PE and I don't know what it means.
PE stands for Pressure Error. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Apr 23, 2017 | LG Washing Machines
My LG Top loader is taking in water very slowly. The water pressure is fine and I have cleaned the filter.
check for a problem in the tap ( tap washer blocking the flow)check for a problem in the diaphragm in the solenoid control
Jan 30, 2017 | LG Washing Machines
LG Top loader WF-T7016PP Won't take in cold water? Help please
turn tap on at the wall
check that the water in solenoid is operational
check that the stop washer in the tap is allowing water in to the machine
check that the water level is set correctly
call a technician does water flow if hot water is selected
Jul 10, 2016 | LG Washing Machines
My top load washer takes very long to fill with good water pressure
Hi Miguel, I am happy to assist you!
I understand your washing machine is taking a long time to fill. Is the incoming water flow normal? If it is, does the fill water continue to enter your washer? If yes, disconnect power from your appliance. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Dec 07, 2013 | Frigidaire FWS833A Top Load Washer
Frigidaire front loader was leaking a little fromt he front center underneath. I cleaned the machine and now the sysles start as usual but when time for water to enter the lights all blink and the mac
Good Morning Kellee - Based on the symptoms you are describing, here are a few troubleshooting tips that may help you get to the root cause:
· Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from the unit. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
· If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
· If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Jun 04, 2013 | Frigidaire Washing Machines
The cold water pressure is very poor into our LG top loader washing machine. There are no blckages and the water comes out of the tap fine. The hot water is ok.
remove the hose from the water machine. there is a iron mesh that traps foreign objects from the water tap. Perhaps it is quite dirty.
May 03, 2010 | Washing Machines
Water fills drum (top loader) even when off
Your problem is a jammed water solenoid, If you take the top off the machine it is possible to remove and either strip it down to see if it is dirty or replace it. your washer hose usually connects directly to it.
Apr 11, 2009 | LG Washing Machines
Water Flow
disconnect your hoses and check for pressure without connected o machine, then check with int he water inlet valce for a clogged screeen slowing the pressure
Jan 25, 2009 | Roper RTW4300SQ Top Load Washer
Whirlpool top loader
You either have a defective pressure switch or water inlet valve. Start to fill the machine with warm water so that both solenoids on the water inlet valve (hot and cold) are activated. After about 30-60 seconds, push the timer knob in to stop water flow. If the water continues to flow, replace the water inlet valve. If this is the case, it may take a few times of starting and stopping water flow to allow solenoid to heat up and become symptomatic. If water flow stops abruptly each time knob is pushed in, you most likely have a defective pressure switch (water level switch).
May 09, 2008 | Whirlpool LXR9445JT Top Load Washer
Kenmore wash macine
its in your cold water line valve to the washer if it works good with hot water the valve are incoming line being blocked when you turn it on the pressure comes in fast then when pressure is gone water slows down so when its off the pressure builds back up it runs fast then slow
Feb 27, 2008 | Washing Machines
LG WFT1071TP Top Load Washer Logo
191 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
