Question about Maytag Washing Machines
Neptune MAH3000AWW Problems
I am having a problem with my Neptune front-loading washer. The washer made a groaning noise when engaging the motor to either agitate cloths or spin. I thought this was due to a worn out motor, so I purchased a used replacement motor. The washer still made the noise. I replaced the bearings in the outer washer-tub which were in pretty bad shape. I thought I found the problem, but the washer still groans when the motor engages and the motor labors to turn the tub under a full load, although I can turn the tub by hand. I unhooked the belt and the motor is making the noise. I either purchased a bad motor (it was a used motor off of ebay) or this motor is starting to go bad. It does turn back and forth, but it makes a groaning noise. I am trying to decide whether or not to throw in the towel or purchase a new motor upgrade that comes with a new control board ($200). Does this problem sound like a bad motor, or could I have something else wrong that is causing the motors go bad? I am mainly concerned that this is electrical. Replacing a bearing or motor is one thing, but diagnosing a problem with the control board is over my head.
  • dbindy Jul 18, 2008
    When I replaced the bearings on the tub, I removed the inner tub and cleaned both the inner and outer tub. The tub spins freely by hand, but when under full load the motor strains to turn the tub and makes that moaning sound.
  • dbindy Jul 19, 2008
    There is nothing trapped in the tub that is obstructing the turning of the basket. When I replaced the bearings on the tub, I removed the inner tub and cleaned both the inner and outer tub. The tub has always spun freely by hand, although there is some resistance and some sloshing from the fluid in the inner tub balance ring (CaCl2).
    Brigadier General:
  • 6,966 Answers
If your washer motor has a starting capacitor, that might be the culprit. Starting capacitors are used to provide the initial push to kick start the motor.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 19, 2008
  • 304 Answers
The likelyness of two motors dieing leads me to believe It's a problem with the transmision. With the belt off How does it feel when you turn the input pulley by hand?(the pulley on the transmision not the motor). If I were you I would check out all the bearings and bushings in the tranny as you have stated you already found no obstructions. Hope this helps you out in your diagnosis.
George
    Sergeant:
    Champion:
  • 230 Answers
There may be some obstacles that struck in the tub,without seeing we cannot analyse the problem and we cannot do trial and error method ,so better give it for service to the service center nearby .If you have warranty then go for because repairing by own may void warranty
Posted on Jul 18, 2008
    Master:
  • 726 Answers
Yes ginko is right something like money might be traped in the tub
  • 813 Answers
Most lickely a foreign object stuck in the tub.
  • sandip panchal
    sandip panchal Jul 19, 2008
    A drain system for adapting the drain/extraction plumbing of a front-loading washing machine which includes an agitator drum mounted for rotation about a generally horizontal axis, means for driving the drum in rotation about the axis during the various cycles of the machine, and a drain pipe extending downward from the agitator drum and disposed to convey a water/suds mixture vacated from the agitator drum away from the drum. The system includes a conduit into which the water/suds mixture is conveyed from the drain pipe. The conduit is oriented generally horizontally with a first end of the conduit intersecting, and being in fluid communication with, the distal end of the drain pipe. The water/suds mixture, as it is channeled through the conduit, separates into a water component and a suds component floating on the water component. The system includes a water scavenger line and a suds duct, both of which diverge and extend from the second end of the conduit. A baffle is interposed in the system to occlude an upper portion of the water scavenger line so as to permit the water component of the mixture to enter the water scavenger line yet divert the suds component of the mixture into the suds duct.
  • Maytag Master
  • 19,396 Answers
It is most lickely a foreign object stuck in the tub.
  • Ginko
    Ginko Jul 18, 2008
    It is not the motor, it is something stuck in the tub object trap, between the tub and the basket, usually the trap access is in the central lower part of the tub, you access from the back of the WM.
  • Ginko
    Ginko Jul 18, 2008
    Coins and small objects get stuck in the drain pipe before they reach the button trap. Machine needs to be disassembled to remove them. Check the drain pipe, the button trap, and check for objects between tub and basket.
My washer makes a groaning noise when spinning. any advice on what the problem might be?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Jan 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer wiring diagram
machine start when you push the start button but stops 3 or 4 seconds after the button is released help me dennis montgomery maytag neptune model #mah3000aww
Aug 27, 2010 | Maytag MAH8700AWM Neptune Front Load...
Will not spin, lock light out
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
My Neptune washer model # MAH3000AWW has developed an excessively loud noise during spin cycle--what is wrong and how much to fix??
It sounds like the bearings in the rear outer tub have gone out. This is caused from using powder soap. ( It also happens with liquid sometimes) This is a common problem with front load washers. This is a also a very costly fix. You have to replace the whole outer tub assembly. To get an exact cost just call your local service tech and tell them what your problem is and they can give an idea how much it will be.
Jun 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer MAH3000AWW
This is out in cyberspace Cant remember what or where. Do a search for "Maytag Neptune shuts off"
Sep 17, 2008 | Maytag Neptune Washer
Kenmore HE2 Elite is making groaning noises and then error messages 5D and/or F
did you clean pump out by removing acess port on front end of pump? also you can ckd pump impeller by removing screws around pump body impeller will free wheel but should have some resistance to turning by hand if no water in tub reinstall pump put in drain spin to see if drum will spin if it does forget main motor ..motor is most reliable par on those washers
Aug 06, 2008 | Kenmore Elite 45986 Front Load Washer
Groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Feb 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
169 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
