Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Hitachi cmp 4121
This is dead, just turned off one day and would not turn back on, have checked fuse etc, any ideas?
    Genius:
  • 1,139 Answers
Hello naomi1972,
If you checked the fuse, and it is good but the set remains off, this is an indication that you primary power supply has a problem. At this point you will need to have the schematic diagram to check the voltages on the power supply board. If you have a background in electronics you can do this with no problem, however if you do not have a background in electronics, I would suggest that you have a qualified TV repair person fix this TV for you.
My diagnosis of this TV is that the power supply board may be defective. This is the best I can offer with the information given.
I hope this helps,
Thank you,
Shuttle83
Posted on Jul 18, 2008
On a very intermittent basis my car won't turn over and it appears as if you have a completely dead battery but it's not. Any ideas?
Please check the following:
- Check the specific gravity of the battery.
- Perform the battery test.
- Perform the voltage drop test.
- Check the battery terminals for corrosion, sulfate deposits and looseness. (Remove the battery terminals, wash them with Luke warm water, dry them, spray wet type contact cleaner and fix them back).
- Perform alternator test with and without load.
- Check the main fuses, battery cables and connectors in the fuse and relay box under the hood.
Hope that works.
Jun 12, 2014 | 2005 Honda Odyssey
HP Designet 500 power supply Astec AA20850 dead
Go right to HP dot com and they will have a circuit diagram and parts, service manuals etc.
Jun 02, 2014 | HP DESIGNJET 500 InkJet Plotter Printer
Battery dies every few days - rebuilt alternator
Check your fusible links by the positive battery cable.Here's a link to it.
Nov 26, 2013 | Nissan Maxima Cars & Trucks
Hitachi hd1080
Model? what if any lights on front of set come on? If total dead unplug and look for fuse connected where power cord enters set, as much as I can suggest without more info.
Jul 20, 2013 | Televison & Video
My hitachi 60v710 wont turn on
Have you checked the main fuse to see if its blown? If thts blown its indicating a short if its not blown then cahnces are its the power supply causing the issue since no power indicator is lit. If you need further assistance let me know.
Oct 19, 2011 | Hitachi 60V710 60" Rear Projection HDTV
I have a 32inch hitachi and was working fine turned it off and when i went to turned it on nothing happened not even the red light came on have tried changing the fuse and still nothing only had it 18...
Check ur house power outlet source?Yes.Than the tv whole power supply board it is dead,modern electronic equipments rarely have dead fuses alone or only.Tries websites like Shopjimmy.com Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 30, 2011 | Hitachi 32LD8700 32 in. LCD Television
Have an alpine radio. twice, it has gone dead, will not turn on, power up,etc first time, battery went dead few days later and when recharged radio came back. have has some electrical troubles with...
sounds to be a drain of sorts. Do you have a good ground to the radio? If so the radio may be sticking open in the switch circuit and blows the relay buzz fuse and then after the power is removed the ciruit resets itself. If this is the case there is a dead short inside the radio
Mar 07, 2010 | Car Audio & Video
42hdt79 Hitachi TV will not power up. Cord is good TV is dead ??
Try the button on the front bottom, under the power button on the front.
Apr 05, 2009 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi 53SBX10B RP TV won't turn back on.
there is a fuse in the tv that must be at the end of its life so it gets automatically off.and now that fuse is completely blown off.so it is now not turning on again.
Jun 05, 2008 | Hitachi 53SBX01B 53" Rear Projection...
Fuses check ok, dead no power
it could be high voltage cap located by flyback,if you have back off of tv and turn tv on,you will see green led's turn on,(on the board)if they turn off there is a small blue high voltage cap hidden under glue(i believe it's a 102 cap)that would be the one change,99% of time that is what will fix problem
Sep 22, 2007 | Televison & Video
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
88 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
