Question about Acer Computers & Internet
I am trying to connect my Acer Aspire 7720-6155 to my Panasonic television model number TH-42PX600U. Can you please help
  • 160 Answers
You have 2 outputs on the Acer - S-Video, and VGA.
The TV has both inputs as well. Choose one (I prefer S-Video of the two), and get a cable for that type of connection.
On your TV, select the appropriate input source. You may have to cycle thru all the choices until you find it.
On the laptop, the S-Video should activate automatically, for the VGA, you may have to use the Fn Key plus one of the Functions keys for "Dual Monitor" mode.
By the way, Panasonic has free help for you lucky Viera series owners, try this web page:
Posted on Jul 18, 2008
Service menu tv 42px75u
Sounds like an issue with the remote. Try other functions, too. You may need new batteries.
Nov 30, 2013 | Panasonic TH-42PX600U 42 in. Plasma HDTV
I have a TH-42px600u & there is no power going to it, the power cord is working, but the Tv is getting now power. Is there a fuse I should replace or a reset button? Help PLXX!
Of Course there is a fuse at its main power regulator board. but, you must have sound knowledge in electronics, to replace it, especially to Plasma displays. If you wish to get more details, check the site linked here. If you have confidence, follow.
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 14, 2013 | Panasonic TH-42PX600U 42 in. Plasma HDTV
Panasonic th-42px600u high pitch sound
likely a coil or small transformer in the set is vibrating hard enough to make it squeel, it would have to be located with back off by listening to see where it comes from.
cure would be to replace the entire board it is on or hot glue the part that is causing this to dampen the sound.
If it is coming from the front screen unit that is a more serious issue.
Dec 23, 2012 | Panasonic TH-42PX600U 42 in. Plasma HDTV
I turn on my Panasonic TH-42PD60U Television - red LED blinks and there is a clicking noise but TV doesn't turn on.
Panasonic plasmas are notorious for their power board problems.
I can't know which one of the few possibilities yours might have, but at the very least it is worth checking against the most common ones(s):
Read the listing, get a multimeter and check the described components for short or open (in case of a fuse) and if it matches then that's the problem and that's the solution.
For in-depth troubleshooting help consider using - it's free to ask, but we may not always be able or willing to help and when we do we'll typically put a price on a consultation.
Sep 30, 2012 | Panasonic TH-42PD60U Television
I have a Panasonic TH-42PX600U and the RF board displays a red light and the screen says no channel found. Can I change the board myself, does it just snap into place
if you have the right tools then you can do it, make sure unplug the tv unit first while replacing the board. then mark or put a label to the connector that you were disconnect not to interchange that can cause of damage to the other board.
Sep 17, 2012 | Panasonic TH-42PX600U 42 in. Plasma HDTV
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
I need a manual for the panasonic t.v. th 42px600e
user manuals here
direct link to the manuals
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 03, 2010 | Panasonic TH-42PX600E 42 in. Plasma...
No power
I would guess it's the power unit for the TV itself.
If it's still under guarantee I would have thought you should be able to get it replaced.
Feb 19, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Does model th-c42hd18 require only a panasocin wall mount bracket. Seems others do not work
I am not familar with your exact model but my Panasonic TH-42PX600U 42 in. Plasma uses a generic brand wall mount. The first mount I bought would not fit so I returned it and bought a different brand which worked well. Start shopping your local stores (even walmart has a couple of different types to choose from), carefully open the packaging in case you need to return it and see if it will fit the mounting holes on the back of your TV. If it fits on the back of the TV then you should be good to go.
Jan 11, 2009 | Panasonic TH-42PX600U 42 in. Plasma HDTV
Computers & Internet Logo
226 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
