My tv says needed airflow - Televison & Video
  • 927 Answers
Good day, mxocmi;
There is a recall from the factory to correct this problem, lamp sensor.
Call an authorized service dealer and they will come to your home and repair this at no cost to you.
Good luck, big IRISH.
Posted on Jul 19, 2008
New install model ks1872 and cl1872 unit suction line frosting up proper amount of freon is in system. what can cause this indoor fan is on high speed and running
There are three things that will cause a freeze up in an a/csystem. One is low refrigerant charge, another is low airflow across theevaporator coil and the third is a restricted expansion orifice or valve.
First thing to do it check the airflow across the coil. The rule of thumbreads that you need 400 cubic feet per minute (cfm) of airflow for every oneton of cooling, or 12,000 BTU's. So if you have a 3 ton system, rated as 36,000btu's, you need to have 1200 cfm airflow in cooling mode. If the airflow is notcorrect then check the filter(s) and the evaporator coil for cleanliness. Aclogged filter or coil will cause low airflow. If your airflow is correct thenmove on to the refrigeration cycle.
To check the refrigerant cycle you need a set of service gauges hooded upto the condensing unit outside and temperature readings. The particulars arevery involved and are beyond the scope of this site and need to be performed bya qualified service technician. The service tech needs to verify that therefrigerant level is correct and the expansion orifice/valve is operatingproperly.
Jun 23, 2011 | Sanyo Heating & Cooling
Check airflow sensor turn tv off
Your TV needs the modified temp sensor installed by Mits authorized service center. It's covered under extended warranty for 3 years after date of purchase. Repair takes about 20 minutes and not too expensive if you're out of warranty period. Part #299P313010A
Bill W
integrityhomeworx.com
Mar 08, 2011 | Mitsubishi WD-57731 57" Projection HDTV
My tv monitor says "TV
YOU NEED TO REPLACE THE THERMOSTAT ON YOUR SET TO CORRECT THIS ISSUE .
Dec 14, 2010 | Mitsubishi WD-57732 Projection Television
WE have a 60" lg tv that when we turn it on it automatically turns it self off?
If the TV shuts down immediately you most likely have an electrical problem. The power supply or one of the other boards is probably going out. Make sure you have good airflow to the back of the TV. The vents should not be full of dust. If the vents are plugged vacuum the dust out. Most likely you will need to take the TV in for repair.
Feb 06, 2010 | LG 60PC1DC 60 in. Plasma HDTV
Thermodisk keeps going out
Three words for you: Airflow airflow airflow.
I estimate 95% of all (electric) dryer no heats are caused by a lack of airflow causing the thermal cut out to blow.
Clean dryer venting system (dryer vent hose all the way to the exterior vent on the building) and clean the dryer itself from lint filter to the blower wheel.
It is also possible your blower wheel may be damaged and not giving the airflow needed to keep the dryer within normal temp limits.
Oct 21, 2009 | Whirlpool LER8648P Electric Dryer
What causes my mitsubishi WD-Y65 tv to keep saying: The tv will shut down in a few seconds. Check airflow.
thermal sensor problem.... there is a service bulliteen to service shops about this.. this generally a warranty item that is covered.... you will have to get a tech to see if its covered. the thermal sensor needs replaces.not to difficult to replaced
Apr 04, 2009 | Mitsubishi Televison & Video
TV will not stay on
Sounds like you have a lamp error. Most likey there is something wrong with one of the lamps in the LCD itself, or you have a defective inverter.
Jan 21, 2008 | Sharp LC-15AV4U 15 in. LCD Television
Height,width,&length of 42 in tv
The TV itself measures 31.5 x 23.7 x 9.9 inches (WxHxD) with included stand. You want to make sure you have at least 4 inches of clearance for airflow on top of those dimensions.
Jan 17, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Mitsubishi dlp tv model number wd57732 purchased 2-20-2007
i had the same problem on 10/24/07 and i called a Mitsubishi warranty company near me and they came out and replaced the Sensor part # 1299P313010A. No problem since
Jul 30, 2007 | Mitsubishi WD-57732 Projection Television
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
