Question about Archos 704 WiFi Digital Media Player
Archos 704 stopped working
Well my archos 704 stopped working and i dont know why ( it is fully charged ) when i switched it on the green writing that says archos came up for a few seconds then the machine swithed of , so i pressed the restart button that is under the batterie and now it doesnt switch on ATALL !!!
please ! could you tell me how to fix it if you are able.
thanks.
  • domfranco Aug 23, 2008
    my archos 704wifi will not switch on, this has happened before and i remedied it by doing a soft reset, but have now forgotten, pls help
  • afarkonis Oct 21, 2008
    I have the same problem, i try the hard reset but it does't solve the problem
    How can i make reformat if the machine does't works?
    Thanks
It told me"Please format it" than "Recovery Update".How would posibal is this suggest me please.
Posted on Oct 23, 2008
    Brigadier General:
  • 6,966 Answers
A couple of things you can try:
  1. hard reset the 704 using the button under the battery right hand side;
  2. reformat the unit (but that would of course delete contents).
Just curious, did you try/did a firmware update recently? Additionally, the manual has some details on troubleshooting as well as Archos online support.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 18, 2008
MY ARCHOS 704 TURNS ON BUT JUST SAYS ARCHOS ON SCREEN AND WONT DO ANYTHING ELSE
Try pressing and holding the TV/LCD button just after switching on, you should get a recovery mode screen. Select repair disk.
Jul 04, 2009 | Archos 704 WiFi Digital Media Player
Archos 704 wont turn on or charge
First, start with the easy stuff - remove the battery and press the reset button - hold down for about 10 seconds. replace the battery, attach your AC adapter and attempt to start the player. If it still won't start, you may have a damaged DC-In connector OR the charge circuit may be bad - a TI Chip on your main board sometimes goes bad - it can be replaced. Also, if the battery is absolutely dead - no charge left at all, the player will not start even with an AC adapter
Jul 03, 2009 | Archos 704 WiFi Digital Media Player
My Archos 705 is not turing on.
704/705 will not power up at all without a bettery that has a little charge. If these batteries are not used they have a tendancy to die. you could try charging it on a DVR for a few days. then when you disconnect it from the DVR immediatly connect it to a DC charger and your lights should then work. Either way I would consider id a warranty claim.
Jan 20, 2009 | Archos 704 WiFi Digital Media Player
Change my program in archos 704
You can copy files via USB to the 704 using media player in sync mode or drag and drop in windows explorer. Which mode you use depends on what mode the 704 is set.
Oct 26, 2008 | Archos 704 WiFi Digital Media Player
704wifi charging problems
Return It.
Did the Other Charger actually work?
Oct 10, 2008 | Archos 704 WiFi Digital Media Player
New Hard drive for 704 WiFi
No. Period. End of Story. I know that's not the answer you want, but that's the truth.
Sep 04, 2008 | Archos 704 WiFi Digital Media Player
Archos 704 wifi not starting up
If you enter recovery mode then connect to a computer, you can then use windows drive checker to verify the drive. If all is OK, copy firmware to the root then disconnect and reboot
Apr 09, 2008 | Archos 704 WiFi Digital Media Player
Archos 704 WiFi Digital Media Player Logo
288 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
