Question about HP Computers & Internet
Hello; I have just bought the 20" HPw2007v monitor which is excellent, but I have a small screen that pops up when I turn on which says `recommended settings 1680 x 1050-60Hz; current settings, 1024 x 768-60Hz: I have changed from my old 17" screen and the picture is therefore stretched and not in true perspective; can this all be corrected ? Thankyou, Martin Hadleigh
    Novelist:
    Scholar:
  • 160 Answers
It's asking you to change the display settings to match the capability of the new monitor. You're seeing distortion because the monitor settings don't match what your video card is putting out.
Go to Start/Control Panel/Display then choose the Settings Tab.
Change the screen resolution to 1680x1050 by moving the slider to the right. Press OK and the screen will change. When it asks if you want to keep the settings, you have 15 seconds to accept them.
It's possible that your video card does not support the higher settings of your new monitor.
Your user manual's Chapter 4 discusses adjustments to the display properties by using the front panel buttons or the "My Display" software from your installation CD.
If you don't have the manual, you can download it here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&cc=dk&dlc=da&product=3412626&lang=da&
Posted on Jul 18, 2008
After turning on the computer (Apple CUBE MacOS 9.1) the vision of the monitor is normal but after a few seconds a screen with a window countdown will start automatically and reads "signal ing"...
you may try this came from manual.
Power Management" "countdown 20 sec
INPUT SIGNAL OUT OF RANGE
This OSD may appear to inform you that the signal being sent to the display is not within its frequency range. In this case, you would need to check the resolution and refresh rate you have your video card set to, and adjust to be within the range of the display
Sep 09, 2011 | LG Flatron L1510S 15" LCD Monitor
Fender passport 150 pro- Bought to uses for "Bike Nights" Plaing cd palyer in small retail parking lots. Volume is too low, when ever I try to put input level beyond halfway,,, I get...
You are in danger of popping the amp. The Fender passport 150 would be capable of covering about only a 20 foot by 20 foot area. If your area is bigger than that, you need more power and certainly bigger speakers. I would NOT recommend the larger Passport systems as the speakers are too directive for what sounds like your use... also there are reliability issues.
Aug 05, 2011 | Fender Passport Deluxe 500watt Sound...
Hello, my monitor (philips 170S) is going in "AGING . . ." when i turn ofg the pc..when its open the monitor keeps switching off and on constantly..none of the front panel buttons works while...
Open the monitor and chek with multimeter all buttons on the small PCB. (Front pannel buttons). On my Philips 170S the seccond button from left to right was defekt. Change the button and enjoy.
Jan 02, 2011 | Computers & Internet
Hello I have a samsung sync master 732n monitor. The power button just blinks but the monitor doesn't turn on it's properly plugged in to my computer. This has happened quit a few times already. When...
Hi your monitor is working ok but your pc display is the problem.
1.-take out the Memory and clean with eraser the gold part of the memory and your problem will be finish .
if still same means maybe your video card or board .
if your board have a video card build in take your video card and use only built in video
last press the keyboard Num Lock and look if ther is a light green
Nov 03, 2010 | Samsung Computers & Internet
With windows7 screen is small@1024/768 is ok if you use 1440/768 how can i use 1024/768 and get full screen 20 ' wide screen
Hello.
If you have a Wide screen monitor it can only (look good) in a Wide screen resolution such as 1440x768.
1024X768 is the lower resolution, and it is for normal screen (square) monitors, not for wide screen monitors.
You cannot get a full screen at 1024X768 resolution with a Wide Screen Monitor.
Hope that Helps.
Jan 29, 2010 | Evga N350 NVIDA 6600GT 128MB 128bit AGP8X...
Heard pop and had burnt smell from DELLE207WFP.
Hello
The pop you heard was probably a capasitor. If i am correct the smell will get more prominet how longer the screen is on.
If it is a capasitor, which i believe it is, it will not be expensive at all to repair. Just take it to an electronic repair shop and let them just put in a new capasitor. The vapours of the smell is not deadly fo the small amounts of time and the concentration you are inhaling, but it gives me headaches.
Please rate this.
Best regards
Sep 25, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
Computers & Internet Logo
98 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
