Question about ASUS M2N-MX Motherboard
Pci express slot
I try to install a XFX 256 mb graphics card but display not coming and the board getting over heat.. but windows loading and the logon sound coming.., display only not coming from the graphics card.. plz help to install that
    President:
  • 2,351 Answers
Hi dineshcs.
When adding a new graphics card (Your's being a PCI-Express), you must change a bios setting under the title " Advanced " section. Open you're M2N-MX manual & turn to page 2-21. You need to change the boot order for you're graphics to list,
[PEG/PCI]. Change Initiate Graphic Mode Select to [Disable].
These changes stop the onboard graphics card from loading & allow the PCI-Express card to load. The issue of possible motherboard overheating can be caused by many things. Here is a list of things to check.
1). Check the CPU heat-sink fan. Make sure the fan blades are
free from dust build up. Check fan speed in bios (Its RPM will be listed). It should be running a min of 2300 RPM.
2). Also in the bios is Hardware monitor. By booting into the bios go to this & watch the temp of CPU & motherboard. If either is getting too hot suggest you add a side case 3" fan to the system to help lower the CPU & motherboard temp.
Good Luck!
Mike
Posted on Jul 18, 2008
What cheap but good video card should i get to run modern warfare 2 on my dell desktop computer
From what I can determine, for you to have the permornace you need for Modern Warfare 2, the following are the recommended computer requirements:
A CPU: 2.4 GHz dual core or better, RAM: 1 GB on XP / 2 GB on Vista and Windows 7 and a
GeForce 9500 GT 1GB memory Graphics board. (this is a PCI Express slot board).
Make sure your Dell has the slot required for the graphics board, if no slot then there is an AGP board, but with 512MB memory that would work good.
Either graphice baord would cost about them same
Recommend, EVGA @ Negeeg.com or Tiger Direct.
Good Luck
Sep 04, 2011 | Nvidia GeForce FX 5500 256 MB, (256 MB)...
After i install a driver for this device my computer loads but only to the point where i should see my desktop and it says no signal i go in safe mode i unninstall the ati drivers and restart and it works...
Hi!
Try to "clean" your PCI Express PC slot, it may be dusted - just disconnect your graphic card, then blow to PCI Ex slot and insert card back.
Also try to download latest drivers from here and install it after your PCI Ex de-dusted:
http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_xp.aspx?type=2.4.1&product=2.4.1.3.13&lang=English
(for Windows XP)
and http://support.amd.com/us/gpudownload/windows/Legacy/Pages/radeonaiw_vista32.aspx?type=2.4.1&product=2.4.1.3.13&lang=English
(for Windows 7)
Jul 02, 2010 | Gigabyte ATI RADEON X550 , (256 MB) PCI...
I am thinking about buying a 9800gtx+ video card
That board has PCI, PCI Express and PCIx16 interfaces. So if the video card has any of those interfaces, it should work.
Mar 20, 2010 | XFX GeForce 6800 GT, (256 MB) Graphic Card
XFX 8500 GT driver for Windows Server 2003 32 bit
Try...
www.Nvidia.com then drivers and downloads
If there isnt a driver for server 2k3 try it for Vista first if not try an XP driver... make sure there 32-Bit drivers...
Let me know...
Matt
Jan 21, 2009 | Pine Technology XFX GeForce 8400 GS /...
Thw difference between agp and pci slot
sir, you cant replace it with PCI E from AGP, unless your motherboard can handle either PCIE or AGP. cause there is a motherboard which is compatible with the two interface video cards slots but in your case i dont think so. Better to check your motherboards manual for this.
thank you for using fixya
CHARCOIS
Nov 25, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Confirmation
you have both, 3 pci and one agp 4x.
Nov 20, 2008 | XFX GeForce 6800 GT, (256 MB) Graphic Card
Installing NVidia 8500GT XFX 256MB graphics to A8N-VM Motherboard
The chances are that you have an old motherboard which is not compatable with the new graphic card. Or you may be running windows 98 and are downloading the driver for xp or visa versa. The probable solution, will be to sell the new card on ebay and buy the best old card you can off ebay. Or just make do with the card you already had in your computer. If you are determined to have a better graphics card. A motherboard upgrade with better graphic card may be the best answer or buy a better spec pc second hand if you don't have much money. You'll probably waiste a lot of time trying to get the new card to work and it probably never will.
Jan 28, 2008 | ASUS A8N-VM Motherboard
ASUS M2N-MX Motherboard Logo
135 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
