I was experiencing f02 & SUD error. The first thing I would check is to dthe hose where float ball is located underneath tub. .Mine had a total of 4 small socks stuck. 1 sock was underneath tub right before float ball. 2 socks were stuck in between float ball and water pump. The last one was located in pump filter. Thanks for the tutorial! Saved me some$$$$$.
Susds error is a an fault error ....the machine has detected excessive tub pressure could be from not using "HE Soap ....if your are good but you might be using to much.... whens the last clean cycle you have ran to clean excess inner tub buildup on your washer .....
1 #drain all water out of filter sump behind lower front axcess panel make sure washer is unpluged
2# reinsert filter sump and and leave axcess panel off u make have to do this several times...
3# now check black rubber hose that goes from pump to bottom of tub remove clamp check for any obstructions in bottom of tub clean float ball of debris and reinstall and reconnect clamp to buttom of tub..
4# now pour 1 cup of vinegar directly in the tub where your clothes go and shut door( dosent mater what kind of vinegar or an affresh tablet
5# plug washer back in now lets run a clean cycle or any cycle that usues hot water ....
6# if unit suds code again this could happen a few times we need to flush out the buildup you may have to repeat steps 1-6 a couple of times....
