Question about Xerox DocuPrint N2025 Laser Printer
Paper Jam The laser printer showed the message PAPER JAM/ LIFT-EXTEND MBF/ Paper jammed in the printer yesterday and we removed all from the printer but message showing again. Our technicians opened the printer completely and checked it again and again but failed to clear the mesage. Is there any paper jam sensor ? pls advice regards Jisson Thomas jissonthomas@mm.co.in
  • Anonymous Sep 08, 2008
    i'm having a similar problem. i'm receiving a Paper Jam error notice on the printer display, but there is no paper or pieces of paper inside the printer. i've opened it from front and back and don't see any.
    Help!
    Problem Solver:
  • 17 Answers
Look into the configuration settings of the printer.. there should be something like disable message on something...
if you can't find it.. try to rest your printer.
Turnit off -- then press Go (or something similar) button while turning it back on.
Posted on Jul 20, 2008
I face a paper jam a lot, what is the right steps to release it? I keep getting a paper jam message. I have opened up the case and inspected; removed the cartridge and inspected; no paper/paper jam found....
Turn printer upside down (yes), and check that there is no small paper or foreign objects inside the printer, ensure all door are closed, unplug printer power cable for 2 minutes to reset.
Jul 29, 2008 | Konica Minolta PagePro 1350W Laser Printer
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
Where is the paper jam when the panel of our Lexmark C750 says "200 paper jam"
Primary: Paper is jammed at the printer input sensor. Open the printer left door to access the paper jam. If sheets have been accumulated to be stapled or offset when the jam occurred, the printer alternately flashes the primary and secondary messages to indicate that all accumulated sheets not be removed during the jam clearing procedure.
Secondary: When this message is displayed, do not remove accumulated sheets during the jam clearing procedure as the printer will not reprint the removed sheets. Also, if the accumulated sheets are removed, the portion of the job printed after the jam will not be stapled.
Nov 03, 2009 | Lexmark C750 Laser Printer
Network Printer 12 paper jam
In order for a jam message to reset to READY, the printer logic is looking for an "06 COVER OPEN" message. The top cover of the machine must be opened to clear the jam message. If the top cover interlock switch is stuck closed, the printer logic never clears the jam message, even after all the paper has been removed. The printer appears hung with the paper jam message and can only be made READY by powering the printer Off and back On.
Jun 16, 2009 | IBM Network Printer 12 Laser
Removed paper jam from 6450, but it still shows paper jam message went through the troublshooting steps, but ! is still blinking with paper jam message that says, "clear jam, press ok."
make sure you have all the paper out, sometimes there is a small piece that got stuck inside the printer. if you can not see it, you will probably have to take it to a service center. most likely its stuck where the sensor area is.
Apr 16, 2009 | OKI B4350 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
I get a Media Jam Message
Hey folks! This solution worked for my "media jam tray 1" problem! Just took out paper, pushed down @ back of tray, reloaded paper, and bingo! Now to use some air to blow out any dust.
Thank you
Mar 23, 2008 | Konica Minolta magicolor 2300DL Laser...
Xerox DocuPrint N2025 Laser Printer Logo
413 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
