Question about Zebra Eltron LP 2824 Thermal Printer
Printer keeps becoming the Default printer
We have over 50 of these printers connected as a second printer via USB top PC's running Windows 2000. On all of the PC's the other printer is set as the default printer but lots of different staff log on to these PCs and every so often the Zebra suddenly becomes the default printer and the users end up printing all of their work on the labels. Has anyone go any ideas?
Thank you
Andrew
  • 36 Answers
You could try checking in control panel -> printers -> right click each printer and choose set as deafualt -> Only thing is You will probably have to log in as each user (staff) that it occurs with and check these settings.
Also check any printer settings for the application that You use to do labels etc.
Check with each users log on that it doesnt work with
Posted on Jul 20, 2008
How to reset canon ip2700
WindowsThe printer driver you no longer use can be deleted.When deleting the printer driver, first exit all programs that are running. The procedure to delete the unnecessary printer driver is as follows:
  • When There is an Uninstaller
1. Start the uninstaller - If you are using Windows 7, Windows Vista, select the Start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller.- If you are using Windows XP, select the start menu -> All Programs -> "Your model name" -> Printer Driver Uninstaller. - If you are using Windows 2000, select the Start menu -> Programs -> "Your model name" -> Printer Driver Uninstaller.
Restart the Computer and perform the following:Windows
  • If you connect the printer via USB cable before installing the software:
For Windows 7:(1) Remove the USB cable connected to your computer.(2) Proceed to 1.
For Windows Vista/Windows XP/Windows 2000:The above dialog box may appear.(1) Remove the USB cable connected to your computer.If the dialog box closes, proceed to 1.(2) Click Cancel.(3) Proceed to 1.
  • Easy-WebPrint EX:
If you are using Internet Explorer 7 or later, you can use the Web print software Easy-WebPrint EX. An internet connection is required for installation.
1. g0069739.pngPress the ON button (A) to TURN OFF THE PRINTER.Operating noise may continue for up to 25 seconds until the printer turns off.
2. g0069740.pngTurn on the computer, then insert the Setup CD-ROM into the CD-ROM drive.If you are using Windows, the setup program starts automatically.
Mar 31, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Trying to connect 4 MACs to all in one Kodak 5250 printer and will not connect via wireless. I had to set up so that the other pc's have to print from one location via hardwire. I tried installing...
If you have one PC connected to the printer via USB you can share the printer to your Mac computers easily:
If the printer is connected to a Macintosh computer via USB:
1) Open System Preferences
2) Click on Print and Fax
3) Highlight the Printer and Check the box Marked "Share This Printer On The Network"
If the printer is connected to a windows computer via USB:
1) Download "Bonjour Print Services for Windows" from Apple's website
http://support.apple.com/kb/dl999
2) Install it on the PC connected to the Printer.
3) After Installing the Above, Run the Bonjour Printer Configuration Utility and select the Printer you want to share and it will share it over the network to all your apple devices.
Mar 02, 2011 | Kodak ESP5250 All-In-One InkJet Printer
Installer of hp 1410
The 1410 drivers are available on the HP website, (www.hp.com) http://h10025.www1.hp.com/ewfrf/wc/product?product=458978&lc=en&cc=us&dlc=en&submit.y=0&submit.x=0&lang=en&cc=us
Drivers are available for all Operating Systems, Windows 2000 up to Windows 7, Mac OSx and Linux (although I'm pretty sure that the right drivers will be available in Linux via the CuPs system)
General rule of thumb. Install the drivers BEFORE you plug the printer into the computer (via usb).
If you've already connected it and windows has installed the default windows drivers - this may be enough for your needs, but if you're having problems, you'll have to disconnect the printer from the computer and uninstall the drivers.
Go to to start -> Control Panel and then: Add or remove programs (for XP, windows 2000) or Programs (if you're using Windows 7) Find the HP Printer driver in the list of installed programs and select uninstall.
If the driver isn't listed, don't worry, simply download the drivers from the Hp site, double click on the program to start the install process and connect the printer to the computer when it asks. (with most drivers installs just double click to run, read and follow the instructions, mostly it's a case of just pressing "next" until it starts installing.
Remember when you connect the printer to turn it on (button at the front that glows green when you turn the printer on) - you'd be suprised how many people forget that part!
Feb 28, 2011 | HP PSC 1410v All-in-One Printer
We have a HP LaserJet P2014 that is installed via a USB cable to a Windows XP Professtional Service Pack 3 PC. The printer is shared so that 2 other people can connect to it over the network. However, the...
it sounds as if your network connections are "going to sleep".
This is a "on by default" to save power.
In device manager on each PC right click the network inface card and disable power saving.
If you require step by step instrcutions please ask and state your version of windows on each PC
Oct 06, 2010 | HP LaserJet P2014 Printer
After I installed my Epson SX415 printer my PC reboots repestedly
it happens sometimes.--this means there is a conflict between the files supported by your printer.try removing the drivers then reboot the system and then make a fresh installation of printer drivers.this will solve the problem.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Dec 28, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Printer printing from PC W/2000 but not with XP
Hi Kmcnew,
This issue could occur if the connections are not proper.
If the printer is connected using USB cable then you need to make sure that the printer is installed on DOT 4 port.
We need to also make sure that the driver for this printer is installed and listed under printers and faxes.
May 14, 2009 | Zebra 105Se Thermal Printer
Connect Kyocera Mita FS-1010 to Macbook (OS X 10.5)
in FS1010 printer usb port avilable u can connect the printer through usb port .
please delet ur printer driver and reconfigure it . use a usb cable to connect the printer it will work.one more u can put ur printer in network
Dec 23, 2008 | Kyocera Mita FS 1010 Laser Printer
NEW HP Photosmart C6280 All-in-One on Vista - Error Printing
Whats the error message and can you try the printer directly connected into your computer?
Also check what your computer says in the printer status -> start -> printers and faxes -> your printer.
Jul 05, 2008 | HP Photosmart C6280 Printer
Printer does not respond when trying to print documents and have to keep installing the program
open the printer folder and right click on it then cilck on use printer online n ur done.
if u r using windows, click on start then on printers and faxes u'll see list of printers there. right click on the printer u r using then click on use printer online
thank u
May 26, 2008 | HP Computers & Internet
Printing is very slow
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
WOW
LPT_Timeout
WARNING: Using REGEDT32 can cause serious damage to your operating system. Make sure to follow these steps exactly.
  1. On the Windows 2000 or Windows XP machine where the printer is connected, click Start -> Run and type REGEDT32
  2. Bring up HKEY_LOCAL_MACHINE on Local Machine
  3. In the header, click View and make sure to check "Tree and data"
  4. In the left hand pane, expand System -> CurrentControlSet -> Control -> WOW
  5. In the right pane should be a key "LPT_timeout". Double click this key
  6. A prompt for a string with a default of "15" (seconds) will appear. Change this to 3 and click OK.
Then restart Pc
Nov 06, 2007 | HP Photosmart 3310 Printer
Zebra Eltron LP 2824 Thermal Printer Logo
81 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
