PC not booting up
When I tried to boot up my PC this morning it would not run,there is a flasing orange light on the front panel and the fan does not work,is this preventing the PC from booting up?,if so how do I diagognose how to fix it
  • 813 Answers
Open your system remove the ram from the mtherbord clean it put it back your problem will solvs
Posted on Jul 18, 2008
Alarm beeps and orange light flashes when power is switched on.
If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
Feb 15, 2014 | HP Pavilion Computers & Internet
Compaq presario doesnt boot upon powering up
boot into the bios or if bios support diagnostics boot into that (typically F1 of F10 on power up) If that is not an option boot off the CD recovery disk and run diagnostics on the HD. Let me know we can take it from there.
Jan 30, 2010 | HP Compaq Presario SR1830NX PC Desktop
I have a Dimension 4700 and it will not boot more than half the time. So I did a clean OS install and drivers, updated everything and it was working great. Tried to turn it on this morning and the same...
If you have a Dell, then do this the next time.
As soon as you see your system creating problems again, turn to the back of the computer. There are 4 LED lights. See the status of those lights, I mean, green, orange etc. Check it on support.dell.com and see if you find something useful.
Nov 02, 2009 | Dell Dimension 4700 PC Desktop
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Flashing Orange light, computer wont boot
Below is the link to the NoPower, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=falseFollow all the steps without skipping any and if there is no hardware failure,this should definitely resolve your issue.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Aug 04, 2008 | Dell OptiPlex GX520 PC Desktop
Dell Dimension 3100
Could be an overheating problem.
Power it off & disconnect the power. Open up the case, and use a vacuum cleaner, canned air, QTip, and be sure all dust is gone from the fans, vents, and other openings.
You may need to do this on a regular (monthly or so) basis, especially if you have pets, as I do. Also, consider getting the computer up off the floor if you can, and make sure it gets good airflow.
Something I've seen occasionally on Dell boxes is that they'll have problems booting up or shutting down if a USB device is attached to them (not the keyboard or mouse, but a flash drive, USB hub, or similar.)
If that applies to you, disconnect the devices to get it to boot. Then, add one device at a time, shutting down and starting up again. You might determine which is the offender, and see if there are new drivers available.
I had a Logitech device that cause a problem. I removed their drivers, and Windows loaded it's own, and the problem went away.
Hope that helps.
Jul 18, 2008 | Dell Dimension 3100 PC Desktop
Monitor not Running(shows only orange light)
Unplug everything from the motherboard leaving only processor, fan and memory and try to boot up. It will take you to bios screen halt after looking for boot device. If it uses a video card, make sure video card is properly inserted. Then start plugging in hard drive and other devices if system comes up.
Dec 26, 2006 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Computers & Internet Logo
60 people viewed this question
David Payne
David Payne
