Hello, problem could be power supply. But in certain cases it could be other components as well. Can you give more detail regarding this problem, like for example if you hear beeps when you switch on PC or if power supply fan starts up for a second and stops again. Also check if RAM and VGA card are slotted correctly in the PCI connectors. Reseat again if necessary.
SET/UP EXIT
Hit the "+" quite a few
times until you get to "MEDIA POWERUP"
Hit SELECT
Use the +/- keys to
enter the password (1234)
Hit SELECT - you should
see a small - and + button on the screen
on either side of MEDIA POWERUP (if not,
repeat previous steps)
Hit the + sign until
you get to NO MOTION
Hit SELECT to exit
MEDIA POWERUP
Hit the + button to go
to the next item HEAD CLOSE
Hit SET/UP EXIT to save
changes (permanently)
Open and close the printhead to check to see if it worked!!!
I have the same problem, I have a green light on the back near the top that is flashing and clicking/beeping repeatedly in the same patter. I went to bed, got up at 9AM and then I push the button and nothing happens!
all I did was add more ram and I get nothing no lights fans nothing
I added more ram know I get nothing at all no power lights or fans
Won't power up
power cord is good
oulet in wll good
no lights or fan
Laser Jet 3050 HP
