Question about Panasonic PV-V4021 S-VHS VCR
Toshiba M-782 Best VHS ever. No problems 10 years. suddenly the picture rolls most of the time. Replaced the heads [expensive!] and it is still the same. No changes in VCR set up. When I use the playX2 mode the picture is fine. I really want to get this working again as it was unbeatable. Thanks, Rick
    Novelist:
    Champion:
  • 275 Answers
If pictures are rolling during normal playback, just check one thing first. Open the Cassette flap and see the condition of the tape. Is it chewed and stretched at the bottom? If yes, the problem is a worn Capstan / Pinch roller in the VCR. It is cheweing up the lower edge of the tape, and therefore the VCR is not able to process the 'Control Track.
All you need to do is replace the Capstan / Pinch roller.It is a big (approximately 1 inch high by 1/2 inch wide Black Rubber roller inside the VCR. REPLACE. Problem will be solved.
Posted on Jul 20, 2008
No picture on my TV/vcr combo when playing VHS tape.
I suspect either the playback head is very dirty and needs cleaning, or it's malfunctioning and needs to be replaced.
Aug 20, 2016 | Toshiba MV20FK3 20 in. TV/VCR Combo
No picture but has sound in VHS, Both work in DVD play
The main cause of this is a dirty video head. You can get a head cleaning tape that will clean the head. Or you can do it manually. But you have to take off the top cover and spray the video head with Servisol Video 40. Allow it to dry and test the machine. If it doesn't do it the first time or the picture is breaking up, clean again.
Mar 07, 2015 | Panasonic DMR-ES40VS VHS / DVD Recorder...
Vcr picture rolls
bad head or dirty try head cleaner
Jan 16, 2012 | JVC Televison & Video
I Can't C U
You might just need to clean the head, Servisol Video 40 is best.
Apr 16, 2010 | JVC HR-J461MS VHS VCR
LG RC195 dvd/vhs combo
Do you just get a snowy screen when you playback? I think the first thing to try is to clean the video heads. Either try a head cleaning tape, but these are not always the best thing, better still is to remove the lid & carefully using a head cleaning fluid (isopropal alcohol) & a thin piece of card or head cleaning stick (NOT a cloth), carefully & gently wipe the heads which are on the round silver drum. Do not use too much pressure or you will damage the heads, give it time to dry (couple of minutes) & then try playback.
Jul 20, 2009 | LG Televison & Video
After recording a program using the Toshiba W522, the picture rolls and jumps up and down, while in playback mode. I have no problem with recording, its just when its time to actually watch the program,...
If the tapes are old or cheap, they may simply be no good. However, I found that the automatic tracking is the best thing to ensure perfect quality picture and sound.
Jun 22, 2009 | Toshiba W522 VHS VCR
Rolling picture
Not likely. They probably just need to be cleaned and re-alligned. Rates vary, but our shop charges $20 to do that.
Sep 24, 2007 | Zenith XBV442 DVD Player/VCR
This model is the W528 VCR, but my manual includes both models
Does it do this with other television sets? If so, then it indicates the problem resides in the VCR. Rolling as you describe suggests either the VCR isn't producing a clean enough vertical sync pulse in the video signal, or the TV circuitry isn't processing the pulse properly. First, try cleaning the heads (not just the video head, but also the audio/control head which is to the right of the rotating video head. If this doesn't fix the problem, an electronic problem is likely. Unless this is a high dollar unit, repair is not recommended, as VCRs of the last 10 years or so are essentially disposable. I've done some looking on the 'net regarding copy protection, and it doesn't look like this is an issue here.
May 02, 2007 | Toshiba W522 VHS VCR
Panasonic PV-V4021 S-VHS VCR Logo
138 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
