Kidde Nighthawk Combo Gas/co Detector Logo
Posted on Jan 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My alarm suddenly started beeping. Just one beep about every 30 seconds with the letters Err displaying. What's up?
Anonymous
Level 3:
Brigadier General:
  • Master 4,736 Answers
  • Posted on Jan 26, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
4736
Questions
0
Helped
2104032
Points
14643
According to the Owners Manual it is malfunctioning. That's assuming you haven't recently changed the battery. For more info click on the link below for a copy of your Owners Manual in pdf format.
http://www.detectorsandalarms.com/images/pdf/Manual_KN-COEG-3_900-0113en.pdf
If the link doesn't work when you click on it, simply copy and paste the link into your web browser.
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
3helpful
My unit keeps chirping every 30 seconds even after replacing the batteries. The unit is over 5 years old.
The manufacturer has written this in their manual for your unit...
"Err" displayed -battery icon may show any state of battery capacity. One quick beep every 30 seconds. Unit is Error condition
Replace batteries. If "Err" (or blank display) continues, unit has malfunctioned. Replace immediately.
Link to manual...
http://portalgb.knowledgebase.net/utility/downloadArticle.aspx?aid=294720
1helpful
Nighthawk carbon monoxide alarm model number KN-COPP-3 err beeping every 25-30 seconds, I replaced battery they still beep. They say to seek users guide, which can't be found. It seems to have started...
1. Change batteries.
2. Clean it.
3. Swap it with another location if you can.
If it still does not work properly consult the local fire dept. for free.
You may have to take it in repairs if all fails.
3answers
What does an err code E03 mean?
the sense is bad, unfoturally the unit need to be replaced.
9helpful
4answers
Nighthawk carbon monoxide alarm model kn-copp-b
Here is a link to the manual, or you can call the consumer hotline at 1-800-880-6788
1helpful
Help me!!!!!!!!!!!!!
Ok the washer is telling you we have a problem. I will tell you how to retrieve the code and then ill tell you what that code means
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and HOLD the Start/Pause and Cancel
buttons simultaneously. As long as the buttons are
held, the failure code will appear in the display as an
E followed by two numbers, a number and a letter or
two letters. The controlwill beep and the Door Lock,
Wash, Rinse,
and Final Spin indicator lights will
flash.
Top Kidde Home Security Experts
 Mikey
Mikey
Are you a Kidde Home Security Expert? Answer questions, earn points and help others
