My Dell Dimension 3100 would not boot up this morning and I have an orange flashing light at the front of the machine,the fan is not working,I have checked could this be what is preventing the computer from booting uo
  • 2 more comments
  • sig5 Jul 18, 2008
    I have already cleaned out the dust from the machine after removing the side panel and as I stated previously the fan is not working.I have tried rebooting the machine however it will not boot up.
  • sig5 Jul 18, 2008
    I have not been offered a workable solution to my problem
  • sig5 Jul 18, 2008
    Hi WV,
    the machine is not in hibernation,it will not power up
  • sig5 Jul 18, 2008
    For the attention of WV
    The PC is not in hibernation mode,it will not power up and as I have reported earlier thre is an orange flashing light on the front of the console.This light is usually gren and it does not flash
  • 4,889 Answers
I would put my money on the Graphics card.. If you have an old Graphics card or your pal has one then try installing it and see if it resolves the issue. Otherwise there's a problem with the motherboard as many other experts have suggested.. Postback if you need more help.
Regards,
Sai.
Posted on Jul 20, 2008
    Genius:
  • 1,665 Answers
See link below for Laptop spares
http://www.sparepartswarehouse.com/
Posted on Jul 18, 2008
  • 19,396 Answers
Disconnect all external devices (usb etc) from your machine and see if starts.
You need to open your machine, If the CPU fan if not running try unplugging and plugging it back. If it did not help replace CPU fan, the fan starts even with faulty MB then is either CPU fan or Motherboard.
If CPU is fine try doing the same with RAM.
If it did not help disconnect all internal devices (disks etc) and start machine only with mother board, cpu, fan and RAM, check it it does boot.
Check warranty terms, Dell gives you always one year guaranty.
  • 2,071 Answers
Click Start, Settings, Control Panel, Power Options, Power Schemes.
> Change all of the settings to "Never". Power off, and restart.
> See if that fixes it.
    Sergeant:
    Champion:
  • 347 Answers
Hello sig,
if a light comes on, that means it is reciving electricity.
The orange light you mention, is turned on the whole time, or only when you try turn on your computer?
Have you recently added a new hardware to your computer? like a new graphic card, or extra RAM memory?
Please answer me the following question to further help you.
Dahaka
  • Santiago Vallejo
    Santiago Vallejo Jul 18, 2008
    votit, he cant even turn it on, how is he going to do what u say?
    Sig, can you please answer me above questions, in order for me to help you?
    Genius:
  • 1,226 Answers
If the the fan is not working, surely there is no power input to output the pc and boot.
Please check the power supply if it working.
melnavz
  • Emelio Navaja
    Emelio Navaja Jul 18, 2008
    Please check also the memory sometimes due to memory dumps preventing the unit not to start. please remove the memory and clean and fix it again.
    If the system still power in the monitor and in the board most likely the processor need to be check.
    first check the memory, then the motherboard. if the fan is not working in the motherboard then u have to check the board.
    melnavz
    Brigadier General:
  • 6,966 Answers
If the unit is still under warranty, ask for service or replacement.
If not and you are considering a DIY (do-it-yourself), then open the unit and give special attention to the motherboard. look for any sign of corrosion, bulged or leaking capacitor or anything out of the ordinary. Another are to check closely would be the front USB ports.
Incidentally, Dell has posted a service manual here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
  • Louie  Role
    Louie Role Jul 19, 2008
    It is either the motherboard (most likely) or the processor (possibly) or both.
    Guru:
  • 859 Answers
Sounds like your machine is in hibernation. Normally, the mouse being moved or pressing any key should wake it up but that doesn't always work.
At the back should be a rocker switch. Turn the PC off from there and wait a minute, then turn the rocker panel on again and press Power to start if it doesn't start on its own.
If this doesn't do it for you post back using the ocmment box below and use my initials (WV) to address my solution. Same with others
Regards,
Worldvet
  • 813 Answers
Your smps has been daed change it try to on
  • sandip panchal
    sandip panchal Jul 18, 2008
    remove the ram & clean it & put it back try to on SMPS fan is working see behind the cpu if not working then your SMPS has been dead u have to riper it with a good electronic technision or u have to change the SMPS
    Novelist:
    Scholar:
  • 160 Answers
Could be an overheating problem.
Power it off & disconnect the power. Open up the case, and use a vacuum cleaner, canned air, QTip, and be sure all dust is gone from the fans, vents, and other openings.
You may need to do this on a regular (monthly or so) basis, especially if you have pets, as I do. Also, consider getting the computer up off the floor if you can, and make sure it gets good airflow.
Something I've seen occasionally on Dell boxes is that they'll have problems booting up or shutting down if a USB device is attached to them (not the keyboard or mouse, but a flash drive, USB hub, or similar.)
If that applies to you, disconnect the devices to get it to boot. Then, add one device at a time, shutting down and starting up again. You might determine which is the offender, and see if there are new drivers available.
I had a Logitech device that cause a problem. I removed their drivers, and Windows loaded it's own, and the problem went away.
Hope that helps.
Dell dimension 3100 restarting
This is generally an indication of boot failure , often as a result of new hardware addition or new software installation. Try pressing the F8 key repeatedly (about once per second) while booting and boot in safe mode. If no success , try removing any hardware (especially flash drives) that was added since the last time the machine worked and try the above again
Jan 05, 2014 | Dell Dimension 3100 PC Desktop
Blinking orange light
Last two times I had that with Dell desktops, they were older machines with main board failure. Writeoff. If you don't get any fan activity or other signs of life, it may be main board problems.
Aug 13, 2013 | Dell Dimension 3100 PC Desktop
While my computer is running the light on the frount is flashing orange. I thought it was always green before. Is there a problem
i removed the connector at "J5J3 pswrd."
this is the blue thing between the battery and the card slot.
i tried everything else such as new M/B battery. remove/change ram. take out extra card, etc.
I just fixed my dell dimension 3100 by doing this.
Oct 05, 2012 | Gateway Computers & Internet
Dimension 3100 turns on the power button has a steady orange light there is also an orange light on motherboard cpu and power suplly fans working but wont bot up
Blinking amber (orange) indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this could indicate a problem with the power connections for the CPU on the system board (see "Power Problems" in your Owner's Manual).
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
I have a Dimension 3100 everytime I turn on tower an orange light comes on Please help???????
Mar 08, 2010 | Dell Dimension 3100 PC Desktop
Flashing Orange light, computer wont boot
Below is the link to the NoPower, No POST, No Video troubleshooting.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?c=us&l=en&s=gen&journalid=&treeid=011360B8243248349C306481A954B356&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=en&toggle=&dl=falseFollow all the steps without skipping any and if there is no hardware failure,this should definitely resolve your issue.
Hope this helps. Please rateyour feedback!
Thanks,
VJ
Mar 26, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell precision 3100 machine will not boot up
Hi there
The beep codes indicate that there is a problem with the system memory, it may have to be changed.
Thanks for using fixya!!!
Feb 02, 2009 | Dell Dimension 3100 PC Desktop
Dell Dimension 3100
Hope that helps.
Jul 18, 2008 | Dell Dimension 3100 PC Desktop
Computers & Internet Logo
81 people viewed this question
David Payne
David Payne
