Question about Philips Televison & Video
Phillips pet 706/05 dvd player wont dvd-r-rw - Philips Televison & Video
    Habit-Forming:
  • 131 Answers
  • Disc not loaded. Load a disc into the player, close the door and press PLAY.
  • The disc used may be defective. The disc used may be defective, try another disc.
  • The disc is placed improperly in the tray. Make sure the disc is properly placed and centered in the tray and if the disc has a label on one side, make sure the label is facing up.
  • The disc is dirty. Use a soft cloth to clean the disc by wiping in a straight line from the center of the disc to the outside edge.
  • Use of DualDisc or Flip Disc which does not meet the Compact Disc Digital Audio Standard. Some music labels have recently introduced the DualDisc for pre-recorded audio and video content. The DualDisc bonds DVD content on one side 'back-to-back' with digital audio content on the other side. However, the digital audio side does not meet the technical specifications specified in the Compact Disc Digital Audio Standard. For this Reason, DualDisc is not permitted to carry the CD logo. Philips DVD and CD players and disc drives fully comply with the CD specifications and therefore may not recognize the DualDisc. Attempting to use DualDisc may lead to playback problems or jamming in the slot loader or drive.
    The DVD video content on the DVD side of the DualDisc should play on Philips DVD players and DVD drives. However, Philips DVD players and drives do not support DVD Audio, and will not play any DVD Audio content present on the DVD side of a DualDisc. Philips will further investigate DualDisc and update this notice accordingly.
Posted on Jul 18, 2008
Can I change the region on our phillips PET714 portable dvd player that my inlaws gave my kids? It says "wrong region" for most of their dvds. It is 2nd hand and didnt come with any instructions.
  1. Open the disc tray
  2. Press SETUP
  3. Go to "Preferences"
  4. Press OK
  5. Press 212225
  6. Press LEFT, DOWN
  7. Enter region (0 = codefree)
  8. Press SETUP
  9. Close the disc tray
May 01, 2011 | Philips Portable DVD Player PET-805
Phillips PET 706 portable DVD player. Won't play DVD's.
1. The pin, right side in the back of the dvd-tray-lid, which triggers the switch on the motherboard of the dvd player is broken.
2. Not impossible, but unlikely: the proper switch on the motherboard is broken, corroded or just full of dust and does not close the circuit.
Solution to 1.: you need a new lid with intact pin, or glue an improvised pin on place of the broken one.
Solution to 2.: take the whole player apart (not difficult at all), while not disconnecting any cables, so you can now test the trigger switch (momentary switch) manually and see if something happens (on screen appears loading)
ATTENTION: BEFORE pressing the SWITCH: cover the laser lens with a piece of paper - do not look into it - it can damage your eyes!!!
If nothing happens by manually triggering, try to spray some electronic cleaner (fat and oil free) into that switch, while pressing it continously. If still nothing happens, disconnect battery, DC, de-solder that switch and look at mouser.com or any other electronic parts dealer to get a MOMENTARY switch with exact identical dimensions, etc.
Solder it in, everything should be perfect now.
Good Luck
Apr 05, 2010 | Philips PET741 Portable DVD Player
What video formats are playable on the Phillips DVP 3120?
DVP3120 can play all DVD, VCD,MP3 and Audio CD and Support the below formats
Audio Video format NTSC & PAL
DVP3120 will play CD, CD-R/CD-RW, Video CD/SVCD, DVD, DVD-R/-RW, DVD+R/+RW, DVD-Video Discs as well as MP3-CD, MP3-DVD, WMA-CD discs and MP3, WMA and JPEG Files.
Let me know if this helps
Nov 27, 2009 | Televison & Video
Hi I haev a problem with A Philips DVDR3380/05
Use Phillips own media this unit was designed with DVD+R/RW in mind, it will work with DVD-R/RW discs but Philips invented the + format.
If you are using the DVDR 3380 is recorded video to then upload to your PC the best program is TMPGEnc v4.0 Xpress it has its own function to scan source media from a DVDR, if you use +R or + RW media you don't even have to finalise it. This is only required if you want to play a DVD-R on another standalone
I have never had any problems with SONY and PHILLIPS media, generally speaking cheap unbranded media will have a higher failure rate , but you do get what you pay for when optical media is concerned.
Hope this helps, join www.windowstipsclub.co.uk for more tips and tricks concerning DVD's
Aug 18, 2009 | Philips DVDR3380/05 DVD Recorder
Playing recorded DVDs on PC or other DVD player
Hi
This is problem exactly with finalizing for finalizing after disk burning You need to press stop button and finalising menu will appear in your display at that time you need to press Record button top finalize it will take a little time for finalizing then your DVD will play fine in all DVD players
Thanks
T.Boopathy
Aug 23, 2008 | Philips DVDR3455H/37B
D VD
The problem you are having is the DVD player. Not all DVD players will play a burned DVD. Some set top DVD players are know for being very picky about what type of DVD's they will play, and Phillips is very bad about this.
If you have the owners manual for the DVD player, look inside and see what type of disc's are playable. if it should play them DVD-R, DVD-RW, DVD+R. DVD+RW should all be listed.
Right now about 80% of DVD players do not play burned DVD's
In time they all will play them, but for some unknownn reason, some are still made without this ability.
Also, not all DVD-R's are created equal.
The best quality of DVD's to buy for burning are Taiyo Yuden. But Sony, memorex, and Maxell are also pretty good.
One way to be certain about the quality of the burned DVD's is to take one to a friends house or anybody you know who has a set top DVD player and see if it plays in their DVD player.
That will at least tell you if the DVD's you are burning are at fault or not. But my guess is that you r Phillips is the culprit here.
I hope this was helpful to you, if so a good rating would really be appreciated.
I have been buring DVD's since they started selling them for the PC. compatibility has been the only problem I have had.
My sony DVD player plays everything I throw at it.
Jun 21, 2008 | Compaq Presario 5000 PC Desktop
Recordings from your DVD recorder should play on other DVD players as long as you finalize the recording on your recorder.
A PC should recognise an un-finalized, but only in a DVD writer drive.
There is a firmware upgrade available for this model. Follow this link and select your particular country version DVDR3320/XX
http://www.support.philips.com/support/html/index_gb_en.html#../~scripts/xsltransformsearch.asp?url=http://www.sms.philips.com/catalogue/list?sid=SMS||type=CONSUMER||locale=gb_en||mode=prod_text||item=dvdr3320v||page=1||show=50&xsl=search_result.xsl
Select Software & Drivers and click on the link to the zip file.
Follow the on-screen instructions.
Mar 02, 2008 | Philips DVDR3320 DVD Recorder/VCR
Samsung portable dvd player
those kinda players wont play DVD rom disks and certain ones that are made up. DVD-RAM or ROM wont work. Try blowing inside the player for any dust. if it still doesnt work its the maufacters problem. The player will play CD-G audio only, not graphics The ability to play back DVD-R, DVD-RW, DVD+R, DVD+RW, CD-R, CD-RW, and CD-Jpeg discs may depend on recording conditions.
Jun 25, 2006 | Verbatim (94562) Media
Televison & Video Logo
187 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
