Question about Cambridge Audio Azur 640P Amplifier
Noise when i play my brand new cambridge 640 i get a high pitch sound similar to feed back that is noticable between tracks. It's less noticeable with dvds. I've checked speaker hookups and am using a new cambridge 640 cd player as well. I'm really frustrated since, i have checked my old cheap all in one stero and it is silent even on max. I'm using bose 301 speakers, also new and have checked the hookups several times but the problem exists with headphones plugged to the amp. It kind of sounds like a form of feed back so i double checked the plugs to make sure they are grounded well and are. Any suggestions would be welcome
  • 2,071 Answers
That is a factory defect problem,i encountered like your problem before,it is a brand new also there is a hizzing sound a like.I told him send it from it you bought, then the problem is solve...
hope may this help;
Posted on Jul 20, 2008
What is making this 08 caliber 2.0L sxt cvt have a High pitched whining sound at idle and driving?
Possible bearing in one of the drive pulleys. I have changed numerous alternators for this noise. Take the belt off and start the car. If the noise goes away you know it will be pulley related and not transmission related. If noise goes away, spin all pulleys by hand to determine the defective/noisy one
Aug 03, 2015 | 2008 Dodge Caliber
Why would a brand new fridge make strange noises already?
Good Afternoon Friend,
I understand that your Frigidaire refrigerator, model# FFSS2614QS, is making a strange humming noise. Your new, high-efficiency refrigerator may introduce unfamiliar sounds. These sounds normally indicate your refrigerator is operating correctly. Some surfaces on floors, walls, and kitchen cabinets may make these sounds more noticeable. This could possibly be the compressor that you are hearing. Modern, high-efficiency compressors run much faster than in the past. The compressor may have a high-pitched hum or pulsating sound. Hope this is helpful.
-Best Regards-
Jul 02, 2014 | Frigidaire FFSS2614QS FFSS2614QS 26 Cu....
Sound Issue
This might be of the core vibration of the backlight inverter transformers.
Dec 09, 2012 | Televison & Video
My Polaris PB4 pump has always made more noise than the main pool pump. now it makes a high pitched sound. i took the pump apart and greased the shaft but this was unsuccessful. after reinstalling i...
The motor manufacturers do not offer cut-away or parts diagrams. Parts such as bearings are purchased thru power transmission outlets locally. Parts for the pump should be found at a local pool store that sells the equipment. You will likely need a new set of 203 bearings, a flange gasket and mechanical seal. All told, the parts should be less than $40.
Jan 28, 2011 | Polaris Pb4 - 60 Booster Pump
High pitch noise on Notebook when Fan is on
the only two moving parts in a computer are the cooling fan and the hard drive.  Some fans have two speeds.
Mar 22, 2009 | HP Compaq Presario V2000 Notebook
My Flair Ari purifier makes much more noise
Sounds like Motor or bearing is failing.
You could order parts but you will find it less expensive to replace unit. Than trying to repair.
Please rate. Hope this helped. If i can help you further let me know. Good luck!
Mar 09, 2009 | Ecoquest Flair Air Purifier
High pitch sound in background
A high pitch sound while connected in the house is either a problem with the reciever or you are picking up interference from somewhere. However, the high pitched noise when using the unit in a car (especially through an aux. connection), is caused by the alternator of the car. This can be eliminated by connecting a filter in-line with the aux wire (much like filters are installed on the radio power line). The filter is essentially a low pass filter that filters out noise above a certain frequency. You may have to get creative and modify your aux. input cable (i.e. - splice it into the aux cable) in order for this to work, or you can just turn the volume down a bit - it should be less noticeable at lower volumes.
Nov 26, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
TV won't turn on, makes high-pitched clicking noise
Its a real good chance that the HOT (horizontal output tranistor) transistor is shorted if so the flyback trasformer may be bad also. the transformer will make a tick tick sound if it is trying to start.
Mar 30, 2007 | Philips Magnavox MT1905B 19" TV
TV makes high pitched noise
In 1080i the horizontal frequency more than doubles from 480i. This means that possibly the high voltage transformer or a linearity coil is occilating at that lower frequency.
Jan 26, 2007 | Samsung TXN3271HF 32" TV
Cambridge Audio Azur 640P Amplifier Logo
207 people viewed this question
Top Cambridge Audio Audio Players & Recorders Experts
Are you a Cambridge Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
