Question about Philips Televison & Video
New projector for LC6281WRB30341 - Philips Televison & Video
    Master:
  • 726 Answers
What do u mean by new projector can i have some more information please email chris07@live.com.au
Posted on Jul 19, 2008
What is the dmd?
Hello Anonymous,
A DMD is a chip with thousands of tiny mirrors that change angles in order to block or let light through, creating the image you are viewing. Texas Instruments has a great video and explanation here: DLP MEMS
The spots could definitely be caused by a malfunctioning DMD. As much as we would like your business, you will be better off purchasing a new projector. You can try searching ebay for a used working version of the projector so you can utilize the hours on that new lamp (there is currently one for sale for $125 on ebay). If you want to get a new projector, I recommend a website called Projector Central (Projectors Projector Reviews LCD Projectors Home Theater DLP Projectors...) for research on finding the right match for your needs.
In the future, if you have any repair or lamp needs, Mentronix repairs and stocks lamps for over 30 brands of projectors.
Mendtronix Inc AV Services LCD DLP Projector Repair Multimedia...
Jun 05, 2014 | InFocus IN2102EP Projector
Red warning light
follow this steps and fix it. God bless you
  • Secure the lamp cover and the air filter cover of the projector body if the projector does not power on. Ensure that the power cable is firmly connected to the projector and an active power plug. If the projector was turned off and then on quickly--let it sit for 90 seconds before trying to turn it on.
  • 2
    Replace the projection lamp if the projector will not power on or if the lamp indicator is flashing. Turn off the projector and let it sit for at least 30 minutes. Locate the lamp cover and remove or loosen the lamp cover with a screwdriver. Carefully remove the projection lamp from the projector housing using the handle, if available.
  • 3
    Place the new projection lamp into the projector housing and secure it to the projector. Replace the lamp cover and reset the lamp timer. Power on the projector to ensure the new lamp is working correctly.
  • 4
    Remove the projector from the enclosed area to allow air circulation if it constantly overheats. Place the projector into an open area and make sure there is no blockage for the ventilation holes. Unplug the projector for at least 45 minutes to allow it to soft reset.
  • 5
    Clean the air filter to allow the projector better air circulation. Turn off the projector and unplug it from the outlet. Remove the air filter cover and use a vacuum to remove dust from the area. If the filter is unable to be cleaned correctly or is damaged, then replace it. Pull the air filter from the projector and place the new one in the now empty slot. Close and secure the air filter cover.
Oct 29, 2013 | Sanyo PLCXU355 LCD Projector
Dull image on projector
This is an old projector which was released in May 2005. Projector image degrades over time as the lamp dims, and other internal factors affect brightness. The original rating is 1600 lumens which is not bright compared to a modern projector.
You can check to status which may give you lamp information by pressing ENTER on remote or projector and going to HELP.
You may find that replacing the lamp helps, however older lamps are expensive and could replace the whole projector with new one of higher specification, complete with 3 year warranty if you spend double as much. A new lamp will not restore a projector to its new state either. Here's a link to the lamp (for the UK), it's over £200 + VAT + delivery, and that's not even for a genuien HP lamp
http://www.every-projector-lamp.co.uk/projector-lamps.php?&brand=HEWLETT+PACKARD&model=VP6310
As I say, you can get projectors with a better spec for as little as £372 + vat + delivery. This one is similar to yours, in that it is a 4x3 business projector. It has an XGA resolution. (Yours is VGA). It is 2000 lumen brightness and it has a 3 year warranty.
http://www.ivojo.co.uk/projector-spec.php?pid=Samsung_SP-L201
Hope this helps...
Feb 21, 2011 | HP VP6310 Multimedia Projector
Bulb won't work
If you are sure that you installed the new bulb correctly , then I recommend that you reset your projector . Some projectors don't realize that you changed the bulb physically until you reset them .
please rate !
Apr 14, 2010 | Eiki LC X986 Multimedia Projector
I just installed a new bulb, but the projector
Is there a fuse in the inside back where the cord inters the projector. It might need to be replaced.
Aug 22, 2009 | Sharp XR-10X Multimedia Projector
On screen resolution issues
Bought a new XGA projector.../
It appears from researching that the native res for the Benq is too low 800x600 so I will never get a good picture even though most of the images I install are at least 10meg originals. Also the new projector will work in a bright room the Benq will not.
May 07, 2009 | BenQ PB6110 Multimedia Projector
No light projects.
Try resetting the projector by pressing and hold the two Keystone buttons, then turn ON projector. Hold down the two Keystone buttons for 15 seconds, then turn OFF projector.
Turn ON projector, the new lamp should strike.
Mar 11, 2009 | InFocus ScreenPlay 4805 Multimedia...
Projector question
RTFM - you are supposed to reset the bulb replacement indicator in the menu.
Jul 11, 2008 | Sanyo PLV-Z4 Multimedia Projectors
Sanyo plc xu 40 lcd projector problem
not only reset the timer is good enough
u must use serive cable to disable the shut off function
and technically reset the system
Jul 09, 2008 | Office Equipment & Supplies
Sync issues with Direct TV HD recievers
Hi Michello
I'm afraid it is indeed new Projector time.
Mar 23, 2008 | SharpVision XV-DW100U Multimedia Projector
Televison & Video Logo
20 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
