There can be only two problems with this issue either the blue and green guns are out which leaves the red gun on or if it has a color wheel it stuck on the red reflector
If the model is a 50v500 the real question should be does the set have a red oval area in the middle of the screen (entire screen not red)---if the entire screen is red you have a chance---it has a red oval area and it needs a new optical light engine----you will have options also but limited if that is the case.
two possible solutions----either a problem on the small circuit board that is connected to the RED picture tube OR the red screen control is turned up too high. These sets have a small square block with RED,Green, Blue screen controls(same place also has red, green, blue Focus controls) if you remove the speaker grill you will find an inspection plate made of masionite---the focus/screen block is visable behind it----get a flashlight and look carefully at the block---one row of 3 plastic shafts is Focus(don't touch those) the other 3 are Screens(you should see R, G, B marked) go to a blank video input(one with nothing attached) and turn the RED SCREEN CONTROL JUST SLIGHTLY TO THE LEFT UNTIL the red goes away.
These are retrace lines. The screen on the red tube is turned up too high. Inside the set there are 6 knobs. 3 for focus & 3 for screen. Turn down the red screen until lines are gone. These knobs are usually found by pulling of the front panel.
IF THE SCREEN IS ALL RED WITH VIDEO VISIBLE AND RETRACE LINES. ADJUST SCREEN CONTROL IN THE FRONT FOR THE RED TUBE ONLY. TURN CONTROL COUNTER CLOCKWISE. IF THAT DOESNT DO IT THE TUBE CAN BE REJUVINATED.
1. red colour on the screen , or redcolour missing. redpatchs on the screen. tell me.
(1). in case red colour on the screen red colour missing.change the vga male connector.
2. red patches on the screen external digosing use.
I will assume from you description that this is a rear projection crt(picture tube) tv. if this is true I have good news/bad news.
faint red horizontal bowed lines in the picture indicate the screen(G2) voltage for the red tube is too high.Slight lowering of the G2 adjustment will eliminate these lines. I stress SLIGHT because too much adjustment will mess up the gray scale .
The bad news the red crt made be bad. if the adjustment works but in the future the problem reappears then suspect the red crt.red crt replacement is probably not economical to repair.
Remove front speaker grill and access panel...... Turn red screen control down a little... Cause may be bad CRT.......................................T.
