Question about Akai Televison & Video
Door doesn't open on Akai RW 120 video recorder
    Brigadier General:
  • 6,966 Answers
If the unit is still under warranty, perhaps your best bet would be to seek the services of their authorized service personnel as warranty may be void if you would venture opening the unit.
If for some reason you would opt for user performed action, then pls try:
1. reset, unplug from the mains for at least an hour and try again;
2. check if there is a slide switch of some sort at the rear of the unit;
3. check if there may be a pinhole somewhere along the bottom of the loading tray where a blunted point safety pin maybe inserted;
4. open the top cover and manually eject the tray;
5. check internally if there is a mechanical problem such as a slipping/cut belt, gears that do not mesh correctly;
6. if the unit has been in use for some time, it may simply need cleaning and re-application of lubricant in the mechanical assembly.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jul 18, 2008
    Habit-Forming:
  • 118 Answers
Make sure it is connected well and powered on.
Check your socket if it is set to on.
Check the power supply cables.
Make sure the power signal is on.
If okay then
Press the Eject button or use the remote control.If it still persists, then you might have to call a technician to open it up.It may be a very small mechanical fault.
I hope this helps.
  • 2,071 Answers
Your DVD/CD player where the disc gets stuck inside of the unit. This could be as described earlier, but there’s also what’s called a drawer/disc tray opener and closer mechanism to contend with. On many models, old and new alike, there’s a small belt that goes bad and won’t let the tray open. You can usually put your ear very close to the front of the unit and, if this is happening, hear the motor spinning when you press the eject button. Another cause is the nylon gears, which can get jammed up with dirt and dust. Also, in other cases, you could have a motor problem, or the driver IC could be at fault. If you suspect that the motor is at fault, simply measure the voltage on the tray motor while pressing on the eject button. If the voltage comes up between 6 to 12 volts, depending on the manufacturer, then the motor needs to be replaced.
  • LORETO LACARON
    LORETO LACARON Jul 18, 2008
    The slider mechanism, depending on
    the age of the unit and , consists of the small chrome rail, a
    drive motor, a small gear assembly, and (in some units) a small belt that
    drives the slider unit via the motor. This small belt causes all sorts of
    problems. If the belt is broken or slipping, it can cause skipping, dropouts,
    or simply no start up at all. Also, if the belt breaks in the middle of the
    disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the
    pick-up assembly doesn’t return to the start position (called home), the unit
    will (99% of the time) refuse to release the disc, causing it to become stuck
    inside the unit. There’s a little micro or leaf type switch located at home
    position that sometimes gets dirty or breaks and, causing this problem also.
  • LORETO LACARON
    LORETO LACARON Aug 25, 2008
    The slider mechanism, depending on the age of the unit and , consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
AKAI REEL TO REAL MODEL 1700 OPERATOR'S MANUAL
Here you are Andrew. That is a blast from the past!!
Service Manual and Owner's Manual!
Akai 1700 Manual Stereo Tape Recorder HiFi Engine
Jan 23, 2016 | Computers & Internet
I have a Magnavox ZC320MW8 DVD recorder. I am having a devil of a time gettng it to finalize DVDs. What do I need to do?
This I believe will come down to software. The DVDs are all copy protected but by no means is it high security. I would check into some firmware update or additional software to download on to the recorder to open and finalize.
Jan 21, 2013 | Magnavox ZC320MW8 Multi-Format...
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
I have an AKAI DVD RECORDER DVDRW 120... 3565-1546/ My problem is that the tray is stuck and will not open. I do not want to pry it open and am hoping that you have a solution that can help me.I have...
This is a common problem. There might be a cd stuck inside (they ussually get stuck on top spindle) plug out and open cover and manually release cd
May 12, 2011 | Akai DVDRW120 DVD Recorder
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Dvd-r or dvd-rw discs not recognised
my computer not reconocing tha sofware of my camera, not open fails.disk of sofware is error help me please
Aug 12, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
LG dvd video recorder
sounds like the belt is slipping.
is there a little hole in the unit? you can take a paper clip and straighten it out and poke it in there to force the door open.
Dec 12, 2007 | Zio Corporation (DM-3000) CD-RW Burner
Akai DVD recorder tray will not open
I am pursuing the exact problem above. I have found a not so hi tech solution. I firmly rap on the top above the disc drawer. This is while Close is being displayed and the drawer is in. If you hear some spinning and load displays it should now work. It may be back to cycling again on the next ejection though.
Technically I figure it may be a sticky magnetic reed switch or what ever they use to detect the drawer position. Mine displays either open or close when it starts to cycle.
Aug 08, 2006 | Akai DVDRW120 DVD Recorder
Televison & Video Logo
149 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
