Question about Epson Office Equipment & Supplies
How to solve this problem
The ink is all full but when i try to copy from it i get horizontal lines through the words and i can't understand what is written on the paper .
what can i do ?
  • 20 Answers
What is the model of the printer please. You may need to clean the printheads and / or you have foreign objects between paper being printed and printhead.
Posted on Jul 18, 2008
When making a copy, be it A4R or A4 Lines cross horizotally from left to rigth
Good Day Lucamoses!
Maybe it is time for you to clean the scanner glass and or the ADF platen glass.
Remember a small dirt, usually a dried ink in the scanner glass or platen glass will leave a horizontal black lines in your copied paper.
I hope the problem you have Lucamoses is just as simple as cleaning the glass to solve it.
Good Luck!
Jun 10, 2011 | Computers & Internet
Poor copy quality - ink is full
Need to download to the printer software
May 31, 2010 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon MP980 prints horizontal pink lines across
try to change the color ink. horizontal banding (the pink or other color lines appearing means horizontal banding) when there is a problem on one of the heating element of the printer head. since almost all canon printers have head built in the inks, replacing the faulty ink will solve the problem. if not then the controller of printhead on the carriage and mainboard needs to be checked.
Feb 12, 2010 | Canon PIXMA MP980 All-In-One InkJet...
Some lines are missing when receiving faxes
Horizontal or vertical? Or do you mean lines of text?
Did you try to copy a document? If the copy is fine, then the fault is on the sending side, or there are severe transmission errors.
If the copy exhibits the same faults as the received faxes, then something is wrong with the printing part of your fax, and solving the problem will depend on the printing technology used (inkjet - clogged heads, need cleaning, or empty ink, needs replacing etc.)
Feb 10, 2010 | Office Equipment & Supplies
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Oct 01, 2009 | Lexmark Z705 Inkjet Printer
Horizontal white lines
Go to the maintenance link for your printer (in properties) and clean your nozzles. It could be this, bad or low ink or needs alignment.
Dec 16, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Horizontal line from the feeder when making copy
your printer recycler is full from ink and may streteches on your drum
Feb 06, 2008 | Lexmark C510 Laser Printer
Canon Lines in picture and colored word doc
you should check whether the color ink is out or not. If so replace it with a new one. Otherwise just cleaning the print head will solve your problem. To clean the head Go to control panel > open printers and faxes > right click printer icon > Click properties > Find the option "Clean print head" or somthing sismilar. Use it and your problem could be solved. Note: Some printers have seperate software utilities to clean the print head.
Sep 11, 2007 | Canon Pixma iP6600D InkJet Photo Printer
48 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
