Question about Smeg 18 in. DWI410 Built-in Dishwasher
SMEG DWI410 TRIPS CIRCUIT LATE IN WASHING CYCLE
MY BUILT-IN SMEG DWI 410 BUILT-IN DISHWASHER TRIPS THE RCD WHICH PROTECTS THE CIRCUIT THAT IT'S ON, LATE IN THE WASHING CYCLE. (THE RCD OPERATES AT 30 ma). THE MACHINE WORKS PERFECTLY FOR ABOUT AN HOUR THEN THERE IS A PHUT FROM THE MACHINE AND THE RCD TRIPS THE CIRCUIT THAT THE DISHWASHER (AND OTHER KITCHEN SOCKETS) ARE ON. THERE IS ALSO BRIEFLY A BRIEF AND FAINT SMELL OF BURNING FROM THE MACHINE. I'VE HAD THE MACHINE APART AND THERE'S NO OBVIOUS SIGNS OF LEAKS OR BURNING. THE RCD RESETS WITHOUT A PROBLEM. AS THE MACHINE WORKS FINE IN THE RINSE ONLY PROGRAMME, I'M THINKING THAT ESCAPING HOT STEAM IN THE LATER STAGES OF THE WASHING PROGRAMMES MAY BE GETTING INTO THE ELECTRICS. THE MACHINE IS 3 YEARS OLD. DOES ANYBODY HAVE ANY OTHER THOUGHTS AS TO WHAT COULD BE CAUSING THE PROBLEM?
  • scorpiouk Sep 06, 2008
    Mike, I had the same problem. Turns out it was a chip on the main board, just under the buttons. It evenualy burnt out.
    I hope this helps you... And If I could ask you I really need your help.. I need to know the order of the wires connected to the dispencer door..
    I think i have the, wrong.. would really appresiate if u could photo it or describe it.
    President:
  • 1,462 Answers
Just possibly
take the kick panel off. On some smeg, there is a small suppressor capacitor on the lhs tucked in the wiring. this breaks down. snip it off - no need to replace
Posted on Jul 18, 2008
Dishwasher trips out after running for a while
When you say "trips out" do you mean the circuit breaker trips? If so the breaker in the electrical box may be bad. Also do you have anything on that circuit pulling high amps when the dishwasher is running? Also when does it "trip out" during a pump cycle or when the heating element cycle starts?
If the pump does not work at all then the pump may have went out. If it happens when the heating element cycle starts then it may be the circuit is overloading or the breaker is bad.
Oct 14, 2014 | Smeg Dishwashers
My Smeg dishwasher model DW1 410 is not drawing the water any more.
More than likely water inlet valve is bad. Maybe replaceable.
Nov 04, 2009 | Smeg CSU2001 Built-in Dishwasher
Dirty dishes
check manual,your water hardness and salt/detergent quantities can make a big difference,theres usually some switches you can adjust for salt/detergent,if not check for partial blockage in pump etc,may be not enough water comming through.
Nov 02, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Need Dial
go to http://au.mouser.com/Electromechanical/Knobs-Dials/_/N-5g22/
There should be something the same or very close to what you want.
Apr 15, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
DWI410
there will be a capacitor. usually attached to the motor but sometimes mounted at the back. it is a cylindrical object about 3-4 ins long and about 11/2 ins diameter
smeg tech should be able to find the problem but will be expensive
Jul 19, 2008 | Smeg 18 in. DWI410 Built-in Dishwasher
DI 67 Diswasher trips RCD fusebox
either the element is faulty or poss the electrical filter.
Nov 14, 2007 | Indesit 24 in. DI67 Free-standing...
Smeg Dishwasher
This is usually the heating element - corrosion lets small amounts of water through the element jacket, making the mineral insulation inside slightly damp. When the machine applies power to the element, enough current leaks from live to earth to trip the RCD. In the absence of a proper electrician's insulation tester (a DVM in ohms mode doesn't test at a high enough voltage to give a meaningful result) the best way to prove this fault is to (carefully, and with the power off!) disconnect and tie back the wires that go to the element, then run the machine and see if it gets any further in the cycle. A.
May 17, 2007 | Smeg CSU2001 Built-in Dishwasher
Dishwasher trips RCD electrics
fault is probably heating element but you need a megga to test it. other disconnect element, tape up wires then check on wash cycle. be carefull!!
Mar 20, 2007 | Electrolux 23 in. ESL624 Built-in...
Open Questions:
See all Smeg 18 in. DWI410 Built-in Dishwasher Questions
Smeg 18 in. DWI410 Built-in Dishwasher Logo
1,071 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
