Question about Whirlpool Washing Machines
Have just got new whirlpool aqua steam washing machine and it keeps stopping with the code f 23
  • 725 Answers
F23 codes indicates an electronics communication problem with the washerThe following list of codes indicates an electronics communication problem with the washer. To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, then call for service
Posted on Jul 21, 2008
  • beverley morris
    beverley morris Mar 06, 2015
    franklin thank you so much washing again
    Champion:
  • 210 Answers
F-23 code means heater failure in the sport duet washer.
Posted on Aug 07, 2008
  • 487 Answers
Please register and forward this question to them
WHIRLPOOL
If this does not help you than Email direct whirlpool_customerexperience@whirlpool.com
If it is codes 32 it will be the pressure switch which is not working right
Posted on Jul 20, 2008
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
F-35 code My washing machine Whirlpool duet steam machine keeps going into the F-35 Code and stops washing.  I don't have the book.  Please, if anyone knows what this means or how to fix it, my email is...
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Sep 12, 2008 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Aqua stop hose allows water through when disconnected from Whirlpool dishwasher but stops water when dishwasher demands water
looks to me like as if the direction of the hose is incorrect. Check to see if there is a direction of flow arrow on the hose and point that arrow away from the tap towards the machine.
Jan 15, 2014 | Whirlpool ADG175 Builtin Dishwasher
Fisher and paykel toploader washing machine fault 49 water valves all show 60 ohms next step?
Fault code 49 is water valves, But the Aqua-Smart board is outputting the wrong code here, The Smart pump has blown the water valves fuse on it's overload, A common thing in Aqua-Smart Machines i always keep seeing,
The Smart pump has jammed with lint and caused over current to the board and taken out parts on the board that drive the pump.
Best to get a new/recondition board for your machine.
Nov 26, 2012 | Fisher and Paykel Washing Machines
Whirl pool top load washing machine directly goes to aqua save mode and disable all other functions?
This is just a setting error. For troubleshooting of this error, just enter in diagnostic mode. Keep pressing Program button and then also press Water Level button. Now release both buttons. Now machine will auto run for wash-rinse-spin. After it finishes, Keep program on Normal, Keep water level low and now Start the machine. It will now work normally as before.
Nov 17, 2012 | Whirlpool Washing Machines
Whirlpool aqua steam 6 door won't open tried resetting, cleaned out filter can you help ?
We had the same problem. Mechanic had to come and replace the lock. Took him less then three minutes to open the door, remove the old lock and put a new one in.
Jun 30, 2012 | Whirlpool AQUASTEAM 9559 WASHER FOR 220...
Whirlpool Aqua Steam dishwasher, coming up for 3 years old, starts cycle but gets stuck with fault code F4. Have cleaned it out and persisted and it did drain but once again went to F4
You have actually posted your Dishwasher problem onto the (garment) Washing machine forum!
However I have checked my Whirlpool list for dishwashers and for some models 'F4' stands for 'drainage' (as you have checked) but for others it mentions (quote) 'no heat, relay, NTC (thermostat), connections, underfilling are all possible'(unquote).
When there is an NTC problem with washing machines we often suggest pouring the contents of a couple of boiling kettles into the washer as it sometimes kicks the NTC into life! Might be worth doing that with your dishwasher before calling for service ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 19, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Aqua stop activated
A simple problem can disable a washing machine: if water runs back into a washing machine from the drainage hose, then the aqua-stop engages. This can happen due to a defective water pump.
In this case it could help to tilt the washing machine so that the water drains and the aqua-stop is deactivated. (Of course you’ll have to fix the cause of the problem beforehand).
Thank you for contacting Fixya.com
Aug 06, 2009 | Bosch Washing Machines
Problems with Briel Espresso Maker
First all of your water drips out and then steam comes out the brewhead. (usually only when you select steam to froth milk) This leaves a very limited amount of steam to froth milk with and makes a mess. While it may be too late to help you, I have three machines that are doing the same thing. There is a checkball and spring assembly in the boiler section called the "aqua stop" that is leaking by. (it gets gunked up with minerals) I pulled one machine apart and had to destroy it to get the "aqua stop" assembly apart. It may be easier to buy a new boiler for $80 (cheaper than new) but I cannot remember the website I found to buy the boiler. A good clean and soak with vinegar (possibly more than once) may work to dissolve the mineral buildup. Good luck.
Barrie
Oct 12, 2007 | Briel Chamonix ES-35 Espresso Machine
Washing Machines Logo
772 people viewed this question
Dan Webster
Dan Webster
Sal De
