Only have a green colour for all tv and dvd pictures on Samsung Tantus Rear Projector TV (Model # SP-43J8PF). Is this the globes or is it stuffed?
    Master:
  • 726 Answers
Ok hi there now inside a rear projection tv is 3 globes i big mirrior
and all the wires are under now it sounds like you do need to replace the globes but to be sure the others are ruined you can pull it apart take the screen off
so now u can see inside u will see three bulbs full of liquid
make sure none is leaking as they can
then turn on your tv (its all safe) put on a channel and look at the bulbs to see if one or any aint workin
if there are working turn tv off and get a lint free cloth or tissue and wipe the top of the bulbs do not turn them adjust them at all
need any more help im chris07551
Posted on Jul 18, 2008
Hello tv has warped bottom and top screen on a rear projector samsung and blurred vision with red,green blue colurs not aligned tried to tune to no avail Samsung rear projector tantus sp42w4/42w5
The colors tell me of a convergence IC issue, warped bottom and top tell of another.
see this page on reparing the convergence problem yourself
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
also compair the before and after pictures to see if this is the other problem your having.
Then you have another fault, which im not completely sure of right now. I will look into it.
Oct 27, 2008 | Televison & Video
I have an LG Rear projection TV Model No. MW-60SZ12, it has patches of blue tinge through the bottom of the screen, i have replaced the globe and the picture has improved but i still have these blue...
your optic engine is stuffed! the blue ,green & red optics are glued into place instead of screwed.after time this glue fails and the colours fade onto the screen. very common problem with this model.
Jul 20, 2010 | LG Televison & Video
Samsung Tantus (SP-43J8PF) Has Green Tinge - Easy fix?
You may try to get into the service menu and adjust screens/drives level(procedure below). But first turn the color off completely and adjust you brightness to mid-range, what you`ll want to do is a grey raster or bring it as black and white as you can while adjusting the red/green /blue guns or tubes. Also get a piece of paper and pen because you`ll want to record the original values of the items you may change. You want to go into the adjustment menu. Hope this will help Good luck
In quick sequence on the remote press:
MUTE - 1 - 8 - 2 - POWER buttons.
The TV will turn On with the Service Menu displayed.
ADJUSTMENT - TEST PATTERN - SET OPTION BYTE - FACTORY RESET
Select the function and use the VOL+ button to enter.
Save settings and exit by pushing MUTE twice then POWER .
Nov 19, 2009 | Samsung PLH403W 40" Rear Projection...
Samsung Tantus 119cm 100Hz Rear Projection Problem
i have a samsung hdtv and direct tv is attached to it. and i can't get a better picture than 480 i when the tv is capable of 1080i. ? when i change the cable box higher its just blurry. what do i do?
Oct 14, 2008 | Zenith E44W46LCD 44" Rear Projection...
Purple and green scrolling lines
This may be a mechanical or electronic problem that is dealing with the sync of the colour wheel. There is basicly no colour lock. This may be the replacement of the associated circuit board, or the motor assembly or the colour wheel.
The link below is describing about how DLP technology works. They are relating to a front projection type. With the rear screen type, the basic technology is very much the same for decoding the pictures from the TV signal.
http://www.hometheaterhifi.com/volume_9_1/plus-piano-projector-3-2002.html
Jerry G.
May 02, 2008 | Samsung DLP HL-P5663W 56" TV
Tv comes on and flick off in one minute
need to know the make and model number of the TV in order to help you.
Mar 13, 2008 | Televison & Video
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
