Question about Mitsubishi WS-65513 65" Rear Projection HDTV
My misubishi i also got the problem that my tv set will turn on for about 2 min then shut off i can turn it off then turn it back on and it will stay on longer or shorter period of time.....the pic goes away but i get a lot of fuzzy lines through the screen like static......can u help with that..
  • stradj Jul 20, 2008
    My tv turned off tonight.  It turns off after pushing the power button after a couple of seconds.  I did the "green light test", by holding down menu and input and the green light flashed in 2 blink sequences for a total of 10 times (20 blinks).  Any idea what the problem is and what the repair cost could run?
  • 927 Answers
Good day, fidel509; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) Good luck, I hope this will get you started in the right direction, big IRISH.
Posted on Jul 19, 2008
  • MICHAEL MULLINS Jul 21, 2008
    Good Day,
    Did the codes help? Do you need more advice?
    Let me know, big IRISH.
Mitsubishi VS-50707 50 in....
of might want to remove the back panel, and see if all the connections are still secure..
Mar 21, 2008 | Mitsubishi VS-50707 50" Rear Projection...
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
Monitor shuts off after approx 2 min when i start. i turn monitor switch off and turn on again and stays on approx 2 min and shuts off again
Go to control panel > Power options and check the power settings there. Are the settings for "Turn off monitor" set to 2 minutes? Increase the time and see if there is any changes.
If the above does not solve it, it's quite likely that your monitor's power supply is giving problems. Turn it in for warranty/repair.
Mar 07, 2011 | HP 2009M Monitor
Green light flashes several times. Then TV turn off.
look for 1 of 2 lights in front of the tv. after the tv shuts down completley mine would turn back on for another 30-45 min after a good cleaning it will stay off and give a "power light" not Lamp light 2 flashes. I'm waiting on some help myself. But if it's the lamp light you'll need to replace the lamp....approximitly $600 from what i've read so far.
Jan 11, 2011 | Panasonic PT-61LCZ70 Television
When I turn the tv on, either manually or by remote, the power stays on for just seconds then shuts itself off.
hello my is rico, check your lamp, lamp cover, fans. second power on the tv when it shuts off itself hold buttons menu and input or device, it will start blinking , it will blink 1 or 2 and then its gone pause for a second andthen will start blinking again count the blinks like, 2,3 -2,2 it means code 23 or 22 and then needs call misubishi for the codes means. if you need more feel free to call at 602-810-7149 at anytime i live in mesa az
Dec 30, 2010 | Mitsubishi WD-57733 57" HDTV
Turns on stays on for about 5-10 min then shuts off will turn back on in about 2 min 52" rca projection
For have two bad electrolytic capacitors. If you change them now you may be able to save this TV from a bigger problem. Like a new flyback and a retrace cap. If you can..look inside the back cover and look for two bulging caps. I'm telling you what I've heard other TV techs discuss.
Dec 23, 2009 | RCA D52W23 52" HDTV CRT TV
TV stays on for few mins and then turns off
IF its the lamp for Lcd. Hi,it sounds like your lamp is going bad,its symptoms are : will shut off and on,led indicators.The lamp on your set last 6000-8000 hrs 2--3 yrs and its made by Philips .Part # is xl-2200 found it here: God bless you!
Nov 17, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
My panasonic viera plasma tv is shutting off on its own
Jan 27, 2009 | Panasonic Viera TH-46PZ85U Plasma TV
Mine does the same thing try a new lamp I am with what I have read this is the best solution. I have had green screen two fans replaced and now this. The picture was great but with all the problems i would never but a sony product ever again for anyone out there you should tell them sony sucks and send them to this web site for clues. Good luck.
Dec 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
