Question about ASUS P5VD2-MX Motherboard
Asus p5vd2 mx MB has 2 IDE ports.I'm planning to use Sata port for HARD DRIVE & IDE for CD rom.Do I need to install additional Sata drivers? Or much better of Using conventional IDE port for both HARD & CD rom.Which do you recommend most? Thank you Experts&more power araw
  • Anonymous Jan 03, 2009
    I have Windows XP SP2 installed. But the BIOS doesn't even detect the SATA. Is there any drivers that I should know about?
    President:
  • ASUS Master
  • 1,314 Answers
If you are using a SP2 XP or Vista installation disk, then the SATA drivers are usually not needed as both have the drivers built in. SATA is far better to use for your hard drive. If perchance the drivers are needed, they should have come with your motherboard but I highly doubt they will be. I haven't had one yet in a new installation where the drivers were needed.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 18, 2008
Can I install a none sata ide hard drive in a Asus Cm1630-06
lilpolak
Most motherboards have one IDE port on this that you can run 2 IDE devices off of. Note the main reason for this IDE port is not all ROM drives are SATA yet but you can run hard drives off this port as well.
Let me know if you have any more questions or problems
Issken
http://www.fixya.com/users/issken
Sep 29, 2011 | ASUS Essentio Desktop / AMD Athlon II X2...
I too have a Asus CM5570 I love the machine; yet I have another SATA drive that I was very interested in installing in myself as a slave drive and a another CD drive to copy some music in the internal DVD...
If it's like the CMM570-AP002 I've seen, your system has enough spare SATA ports and power connectors for two additional drives. With SATA you don't have to worry about master/slave drives like you did with IDE; just plug each drive into a separate SATA port.
Installation is pretty simple and straightforward, and you can use the existing drives as guides. If it stops booting after installation, check the BIOS and make sure it's still trying to boot from the right hard drive. If you haven't done it before, consider looking up dedicated guides to drive installation and BIOS editing.
Feb 27, 2011 | ASUS Essentio Desktop with Intel Core 2...
Can Vantec CB-IS100 IDE to SATA converter works to convert Motherboard ide port to sata or it made only for hard drives,cd-roms and DVD rom ?
It attaches directly to the drive, whether it be IDE hard disk or CD/DVD, and is used in boxes that already have sata connectors on the MB. Connector attaches to drive, cable from connector attached to drive to sata connection on MB.
Note: Sometimes these may not work (for a variety of different reasons).
Here is a link to one seller of the converter, read through the reviews. While it works well for most, sometimes there are issues.
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232004
Dec 26, 2010 | Vantec CB-IS100 IDE to SATA converter IDE...
Computer reboots whenever I try to use my dvd/cd driver. same sometimes happens when using my 3G modem.
test your PSU power supply unit
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Sep 15, 2010 | ASUS P5VD2-MX Motherboard
I need to hook up a CD drive to my computer. I have a P5GC MX/133 mother board, two 256 gig hard drives and 3 1/2 disk drive. I would preferr not to diconnect any of the ubove
Hi kbrotzel,
You didn't indicate if your Hard drive is a SATA or PATA. So, I'm going to assume the problem your having is that the drive is a PATA, and your trying to install another PATA drive, when the board only comes with one IDE slot for PATA style drives. What you need to do is to exchange the CD ROM drive for a SATA drive, so you can put it in one fo the SATA ports. If they are both SATA, then just plug it into one of the SATA ports.
Good Luck
Mark
Nov 22, 2009 | ASUS Computers & Internet
IDE Ports not working on ASUS P5LD2-VM Mobo
Good Day sir, hi, Have you tried to enable the IDE on BIOS setup. If the Bios setup did not solve the IDE problem, check the IDE port of the HARD drive, check if there are bent pins.
If still wont work, you can buy a PCI to IDE/SATA card, this is an expansion card in PCI format with IDE and SATA port.We use this card incase the IDE or SATA on the motherboard gets bad. Connect it on the available PCI slot. Then connect the IDE cable of the Hard disk to this card. Thats it.
Nov 10, 2009 | ASUS P5LD2-VM Motherboard
Msi 848p neo v motherboard problems.
Once you reset the bios everything goes to manufactures default settings. You will need to make some changes within the bios. You'll need the help of the manual. See page 3-20.
If your operating system is loaded on to the ATA IDE drive make sure you set bios settings as follows:
Connect the ATA IDE to MB primary master IDE port.
Connect the ATA SATA drive to the MB's first SATA port.
ATA Configuration
Set as, [P-ATA+S-ATA]
S-ATA Keep [Enabled] Set to [Yes] This enables the SATA controller.
P-ATA Keep [Enabled] Set to [Yes] This enables the IDE controller.
On-chip IDE configuration, "ATA Configuration = [P-ATA+S-ATA]".
Next go to Boot menu. Make sure the ATA IDE drive is chosen as boot device three.
First boot device [Floppy] (If you have a floppy disk drive connected.)
Second boot device would be [DVD/CD-ROM] drive. This should be connected to the MB's secondary IDE port & the DVD/CD-ROM drives Master/Slave jumper, set to Master.
Third boot device [ATA IDE drive]
If your boot drive is the SATA drive than set: third boot device to the SATA drive.
(Hard disk drive with operating system loaded on it).
Save your changes & exit the bios.
Keep in mind all ATA SATA drives are seen as Master drives. SATA drives are seen by the SATA controller & in order by their connection to the SATA port number.
Save & exit the bios. The system will auto restart. Windows should start.
Jul 25, 2009 | MSI Computers & Internet
I have a asus K8S-MX i want to connect SATA HDD
To enable sata port press Delete Key when computer Starts. U will get BIOS menu. On there the Main settings window the second last option is to enable sata option. If u want to install widows OS (XP,2000, Server edition) **** Driver CD and go to RAID folder there u get a driver ( shown as Floppy drive Image). Incerte Floppy in drive and click that icon. And click Extract. Then incert the OS CD. On starting of instalition u will get a option press F6 to install Raid Disk. Press F6. On Bitween instalition u will get a option to install this Raid. ( With out this RAID u cant install XP or Other vartions of windows in ur sata hard drive)
Mar 31, 2009 | ASUS K8S-MX Motherboard
HDD Installation
Hi gravni,
The bios (MUST see the drive). If the bios does not see the drive neither will windows!
The down below port (as you mentioned) is for IDE devices. IDE1 by name. Use your ATA IDE port for the slower IDE drives or cd-rom drives. (This board does not have a second IDE port).
If the WD drive is a SATA drive connect it to the SATA 2 port. See your manual. Go to page 1-4.
As show in this pic below.
2711d19.jpg Is the WD 500Gb drive SATA or IDE?
It's suggested when adding a new drive into a working system, the user should setup the drive by using the manufactures guide. Click on this link & download WD's pdf file:
http://www.wdc.com/en/library/sata/2079-001042.pdf
You mentioned the drive is hot. This only means it is running.
Include in this post the model number of your WD drive? So I can check the specs.
Mike
Oct 28, 2008 | MSI P965 Platinum Motherboard
I need Help
Hi Banyar, lets check the main menu & the boot order in you're bios. Start up the PC, as soon as you see any display on the monitor press the delete key every 2 seconds until the bios main menu loads. This is also where you can see the time & date. List on the left is;
Primary IDE Master
Primary IDE Slave
Secondary IDE Master
Secondary IDE Slave
Across from these on the right is the matching device. If you have one hard drive the bios will show its model number on the right.
Ex: ST150322A. (You're drive will be different). If you have more than one hard drive the second drive, (Should be listed as Primary IDE Slave). CD-ROM drives would be listed as, Secondary IDE Master & Secondary IDE Slave. Write down the model name of the Primary IDE Master on paper. Now go to the title, "Boot" in the bios. Use you're manual & go to page 2-25. High-light, Boot Device Priority & press enter. Set the order as shown in the manual. Make sure the 3rd boot device is set to the correct hard drive listed from the main menu. The model you wrote down. Once set save & exit the bios. The PC will restart. You should no longer receive the error message & windows should boot normally. If windows does not load normally than it is possible that the Primary IDE master drive is not the drive with windows installed on it. You must find the correct drive with windows loaded on it. Connect that drive to the Primary IDE master port.
You may need to reset the drive’s pin settings so it is seen as the primary drive.
Than change the 3rd device in the bios boot priority list with the correct drive. Windows demands that the operating system be located on the, Primary IDE master port. Please read pages 2-12 & the top of 2-13 in you're manual.
More questions? Post them here.
Good Luck!
Mike
Jun 21, 2008 | ASUS P5VD2-MX SE Motherboard
ASUS P5VD2-MX Motherboard Logo
193 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
