Question about Olympus Cameras
Olympus Camedia E-20p suddenly not switching on at all. batteries r new nd fully charged also tried with nd without AC main charger. pls help if possible through emailing: mdaslam@mail.com
  • rogeriko Mar 13, 2009
    Same here wont turn on at all
    Genius:
  • 2,985 Answers
No E-mail. all repsonse through forum - to help others
Take battery out and clean contacts within the battery chamber- eraser on end of pencil.
Make sure the compartment door is fully closes and making contact with battery- hold it in whilst trying.
If still no joy joy try an other battery or the existing battery inanother deivce.
If the camera is less than one year old return to supplier.
Posted on Jul 19, 2008
My lenovo G550 appears not to charge when the charger is plugged in despite turning the mains power on and off to see if power is getting though and the blue neon light showing on the mains...
Hi m529,
I see you are having issues with you G550 charging.
You mentioned that the light on the charger is lit up but then it suddenly switches Off, and you also mentioned that the charge still has a light but the power is somewhat low despite of a fully lit up charger Light.
Have you tried draining the power from the system?
  • Remove the battery and the Charger or AC Adapter as well call it from the G550 then press and hold down the power button for 10-15 seconds to drain power from the system motherboard.
  • Once drained connect the AC adapter but do not connect the battery yet, then turn the Laptop ON to see if the system will power ON using the AC adapter/Charger if it powers up then there is no problem with the AC adapter/charger.
  • After testing the AC adapter if it is working power down the Laptop doing a normal shut down.
  • Once shut down or turned Off insert the Battery back in the Laptop then turn the Laptop ON using the battery only without the AC adapter/charger see if the system will turn ON using the Battery only.
  • If the Laptop powers On using the battery alone with out the AC adapter then the battery is most likely working as well on the issue.
  • Now power down the Laptop then connect the AC adapter to the Laptop with the Battery in the Laptop as well then turn the system ON again see if the problem will Occur again having the battery and the AC adapter/charger if the Problem happens with both Battery and AC adapter on the Laptop then the problem is the Motherboard, most probably the motherboard is having issues relaying power from the AC adapter to the battery and may be sent to the Depot for repairs.
I suggest that you call Lenovo for further information about your system, if you still have warranty and is still in the one year period then your system will be covered for any repairs needed - you can call @ 1 877 453 6686 for troubleshooting, you will be asked for a serial number Located underneath the Laptop on a small white sticker that states s/n meaning serial number.
I hope that this Helps.
Have a nice day,
mvincentc
Jun 18, 2011 | Lenovo G550 PC Notebook
Do the red lights on the charger change color or
User manual of Olympus Camedia C-720 does not mention about overcharging.
But a small part of manual gives the below knowledge.
c8c2fe5.jpg This is not a solution you demand. But may be a little will help your battery question.
Feb 24, 2010 | Olympus Camedia C-720 Ultra Zoom Digital...
Charging problems
The AC adapter is only used as an alternate power source for the camera. It is not intended to charge the battery for the camera in any way. In order to charge the camera's lithium battery you will need the charger that is designed for that battery.
Apr 11, 2009 | Olympus Stylus 600 Digital Camera
Olympus Camedia C-2020 Zoom - always reads low battery and then "dies"
Safe way - Try using brand new and fully charged NiMh.
Not for novice - Battery contact points may need cleaning. Use contact cleaner with a cotton swab.
Do not try - Spraying contact cleaner or WD-40 in battery compartment.
Last option - Service center.
Mar 08, 2008 | Olympus Camedia C-2020 Zoom Digital Camera
Zooming causes shutdown
I think your battery is weak, not holding current or not enough.
Before buying a new camera's battery, try to discharge the battery because most batteries have memory problems.
Find a small light that is rated up to the battery voltage.
Connects two wires to battery and then to light.
When the light goes out, battery is fully discharged.
Now, charge up the battery with the camera's charger
Try it on the camera.
Alexander
atdlee@netzero.com
Dec 17, 2007 | Olympus Camedia C-755 Ultra Zoom Digital...
Camera will not turn on.
it need to be opened by an specialist... it is sure there is nothing you can do for it without open it.
Sep 05, 2007 | Olympus Camedia D-360L Digital Camera
Battery
I have the Maha c204f charger and two sets of 1600mA Powerex Batteries. Over the past two months I have found that this is a perfect set up for my use of my Oly 2040. The batteries fully charge in under 3 hours, don't have a "memory effect", can be left in the charger without damage, and will take over 100 pictures with liberal use of flash, LCD, reviewing, etc. The whole set-up will cost you about $50 from
Sep 07, 2005 | Olympus Camedia C-3040 Zoom Digital Camera
Cameras Logo
90 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
