Question about Bosch Washing Machines
I've got a plumber trying to change the seal on a Bosch washing machine number WFD2471, and she's struggling to get the seal out. Does the whole machine need to be opened up to do this?
    President:
  • 1,462 Answers
I guess you mean the door seal
job can be done from the front with
Posted on Jul 18, 2008
Replace door seal loader washing
This video will show you how to change the door seal on your bosch
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2013 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Hello I've got a Bosch classic 1200 wfo246 washing
Bosch classic 1200 wfo246 This video will show you how to change the pump washing machine
And don't forget to like us on facebook
Nov 26, 2011 | Bosch Washing Machines
My Bosch washing machine is leaking from the bottom of the right hand side of machine when not in use.
g'day, sounds like the leak is coming from the hose - this is because the leak is occurring when its off. Check seals on hose at the back of machine. You can always find old sets of hoses as well (or buy them), so you can try swapping them over. Keep in mind, with washing machine hoses (like gardening hoses), the seal is at the rubber washers not the thread on the tap... so plumbers tap will not stop a leak, it will hinder the seal.
An alternative solution is simply turn tap's off between washes...
Aug 07, 2011 | GE WWSR3090TWW
Want to buy a new door seal for my bosch wvt 1260 washine machine. can you advise where? thanks
Bosch Exxcel WVT 2850 Front Load Washer / Dryer
how to change a door seal.
This video will show you how to change a door seal on this Bosch front loader washing machine and where to get a new door seal!
we have all
bosch repairs in our channel
Mar 14, 2011 | Bosch Exxcel WVT 2850 Front Load Washer /...
Bosch Classixx - Rubber Door Seal - I heard the easiest way to get the inner ring back on is to remove the whole front panel - How do I do this?
Not recommended, tilt washer backwards, and work spring on with your fingers, slowly going round the inner lip of the seal, it helps if you can get someone to help by holding the spring in place as you work your round the seal.
Please rate my solution.
Thanks.
Aug 27, 2009 | Bosch Classixx WFL 2066 Front Load Washer
BOSCH: How to replace rubber seal (boot) of front loading washer
remove soap draw take screw out lower right.
remove boottom panel screw in filter flap push to the right panel comes off undo 2 x screw,take front lip off door seal off 2 screw from door interlock then front panel will come off you will beable to whole seal and spring cilp
slightly longer but easy you can see what you are doing.
Jun 30, 2009 | Washing Machines
Front Door Seal
Call the Customer Service number located in your manual. Discribe to them what you have said here and they will send one to you for FREE! This is a problem that should NOT happen.
Moving forward, once you get it spray it down with Lysol Mold and Mildew Prevention and let it dry a couple of days before you install it.
May 13, 2008 | Washing Machines
BOSCH Washing Machine -Door Seal
1) remove the tension ring under the rim of the seal at the front
2) flip the whole seal into the drum so that you can get at the inside of the seal
3) remove the tension ring hold the seal to the outer tub
4) reverse of the process to put in the new seal
Its as simple as that.
Mar 09, 2008 | Washing Machines
Washing Machines Logo
75 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
