Question about Medion Computers & Internet
Recovery of xp
My friends notebook boots through the first XP screen to the light blue screen and then stops.....how do i do a "restore" of the setup without being able to get into the windows.?.....
Will also not work through the F8 "safe mode"
Medion MIM2120 Notebook Pc
XP home edition installed.
  • 45 Answers
The safemode may not be accessable probably because you have the Other Gadgets connected to the comp.
Turn Comp off...
Remove every thing(except Keyboard,mouse,monitor& power.)
Then Keep Tapping F8 to enter "advanced screen options menu".
***If the safemode would not enter then enter the safemode with command Prompt.
***Log on to your computer with an administrator account or with an account that has administrator credentials.
*** Type the following command at a command prompt, and then press ENTER:
%systemroot%\system32\restore\rstrui.exe
if all this do not work and the OS is an OEM then the manufacturer of this computer should have a to Recovery the OS by formatting the comuter.
Posted on Jul 18, 2008
How can i restore a toshiba equium l20-197 back to factory settings
System restore will not do what your asking.
However there is a way but you will need a Installation cd Assume you have Windows XP
Then you need to borrow or buy a Windows XP Home Edition or Pro
You can buy one used from Ebay.
There are two options !.Repair install this will save all files/data on your hard drive.
Follow these instructions to Repair install.
Boot the computer using the XP CD.
You may need to change the boot order in the system BIOS so the CD boots before the hard drive.
Check your system documentation for steps to access the BIOS and change the boot order.
When you see the "Welcome To Setup" screen, you will see the options below
This portion of the Setup program prepares Microsoft
Windows XP to run on your computer:
To setup Windows XP now, press ENTER.
To repair a Windows XP installation using Recovery Console, press R.
To quit Setup without installing Windows XP, press F3.
Press Enter to start the Windows Setup.
Do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console).
I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
Accept the License Agreement and Windows will search for existing Windows installations.
Select the XP installation you want to repair from the list and press R to start the repair.
If Repair is not one of the options, END setup.
After the reboot
Setup will copy the necessary files to the hard drive and reboot.
Do not press any key to boot from CD when the message appears.
Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
2. If you want to do a clean install that will completely wipe your hard drive clean then follow the instructions from this site http://www.winsupersite.com/showcase/win...
You will then need to reload all Microsoft Windows Updates and find all other drivers and software from http://uk.computers.toshiba-europe.com/c...
Then wham bam you should be back in business.
hope this helps
Sep 27, 2012 | Toshiba Equium Computers & Internet
While trying to restore system it stops at 19% and than says says error code 0xf0000005. than when it restarts it says missing NTLDR what is that and what can i do if anything
Use Recovery Console:
When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the folder containing the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
Use system utility software like RegInOut after restarting windows.
Aug 05, 2011 | Acer Aspire One Netbook 8.9" Notebook
Can I do a factory restore on my laptop without the CD?
Hi annick_s,
You can do a factory restore without using your CD as long as you haven't deleted the Recovery partition. Follow the steps below to do a factory restore;
1) Turn on the computer.
2) When the initial blue HP screen appears, press the F10> key repeatedly until a recovery menu appears.
3) When the Recovery screen appears, click Next, and then click Yes to perform a normal, non-destructive recovery. To perform a destructive recovery, click Advanced, and then click Yes.
CAUTION: A destructive recovery will format the hard drive. This will delete all the information on the hard drive and reinstall Windows XP and the original software that came with the computer.
4) After the System Recovery is complete, the computer restarts and continues into Windows setup. Complete the setup screens and wait until the computer finishes the setup.
If this information was helpful, please rate it.
Thank you for using fixya,
Arun Zac
Dec 05, 2010 | Compaq Presario Notebook
Corrupted user32.dll. boots to a blue screen,
You can try to do a system restore using the system recovery.
There are different ways for doing a system recovery on XP computers and on Vista or Windows 7 computer.
Assuming you are using Windows Vista
On boot press the F11 key repeatedly, When you reach the Recovery manager screen select Advance options.
Select the option do restore the computer to an earlier time.
It will show you the restore points
Select the best restore point and try to do a restore
If system restore does not work then you will have to follow the same steps to perform a system recovery by selecting the option to restore the computer to its original factory condition.
Jul 21, 2010 | HP Compaq nc6220 Notebook
Hi my everex computer is getting a screen saying windows could not start following file js missing or corrupt:..windiwssystem32configsystem............How do i repair without loosing my downloaded pictures...
Hi, Assuming the OS as XP. Plz follow the below steps.
Yes, you can repair your system,
1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
2. When you see the "Welcome To Setup" screen, you will see the options below
3. Press Enter to start the Windows Setup.
do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
4. Accept the License Agreement and Windows will search for existing Windows installations.
5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup. After the reboot read Warning#2!
6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
May 23, 2010 | Everex StepNote NC1500 Notebook
My friend has a toshiba satellite a120 and it has a error message saying nltdr is corrupt the system cannot boot any help?
If you have a windows CD, you can boot into the 'Recovery Console' - this is a command line type program on the CD that lets you perform Repairs on system files, and other things as well.
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
1. Watch for a Press any key to boot from CD... message similar to the one shown above.
2. Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, simply reboot and try to boot to the Windows XP CD again.
Hopefully you have seen or will see a blue screen loading many files across the bottom. it will also offer you to press a function key for specific boot options. ignore all this until you get to the Setup Window
When the Windows XP Professional/Home Setup screen appears, press R to enter the Recovery Console.
The Recovery Console is now loading but needs to know which Windows installation to access. Most users only have a single Windows XP installation so the choice is usually clear.
To the Which Windows installation would you like to log onto question, press 1 and then Enter.
The Recovery Console now needs to know the administrator password for this Windows XP installation.
To the Type the Administrator password request, enter the password and press Enter.
Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
When you reach the command prompt, type the following two commands, pressing Enter after each one:
copy d:\i386\ntldr c:\
copy d:\i386\ntdetect.com c:\
In the command listed above, d represents the drive letter assigned to the optical drive that your Windows XP CD is currently in. While this is most often d, your system could assign a different letter. Also, c:\ represents the root folder of the partition that Windows XP is currently installed on. Again, this is most often the case but your system could be different.
If you're prompted to overwrite either of the two files, press Y.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that missing or corrupt versions of the NTLDR and/or Ntdetect.com files were your only issues, Windows XP should now start normally.
Sep 22, 2009 | Toshiba Satellite A100-S8111TD Notebook
Cannot start up
Do you have a copy of your OS disk:
Try This:
insert your Windows XP Setup CD, and restart your computer. 1.
When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
2.
Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.
Do not choose the option to press R to use the Recovery Console.
4.
In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.
Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.
Follow the instructions on the screen to complete Setup.
Feb 16, 2009 | Toshiba Satellite A35-S159 Notebook
Stop error
okay
first of all heck yout
RAM is fixed properly in its slot then checksystem if u get same erros again.
then u need to bootable win xp recovery or source setup disk.
if u hve then simply boot your system with c d rom in firt boot devic then follow te steps.
then go to recovry console.then typein command prompt 'chkdsk /r'
then it rstrt then if u need to repir os then pres r then folow again ame procedure but this time pres enter and u have to go to repair win xp option.
Oct 12, 2008 | Dell Latitude D600 Notebook
Assist with an Operating System start issue? PC is a Gateway GT5228
the following will re-install windows without destroying your stuff but you must follow it exactly !!!!!!!
  2. When you see the "Welcome To Setup" screen, you will see the options below This portion of the Setup program prepares Microsoft
  3. Press Enter to start the Windows Setup. To Repair Install, press ENTER
    \r\n'); FP_changeProp(/*id*/'layer1',0,'style.borderStyle','double','style.borderWidth','3px','style.padding','5px','style.backgroundColor','#F9F4D5','style.backgroundImage','url(\'edgbkgnd4.gif\')'); FP_changeProp(/*id*/'layer1',0,'style.visibility','visible')" onclick="FP_changeProp(/*id*/'layer1',0,'style.visibility','hidden')" height="21" alt="To setup Windows XP now and Repair Install , press ENTER." src="http://www.michaelstevenstech.com/note.gif" width="15" border="0" /> do not choose "To repair a Windows XP installation using the Recovery Console, press R", (you Do Not want to load Recovery Console). I repeat, do not choose "To repair a Windows XP installation using the Recovery Console, press R".
  7. good luck beergut707
Oct 09, 2008 | Computers & Internet
Zd8000 wont boot up
try to get into SAFE mode... tap F8 repeatedly when you first power on. You should get a safe mode boot menu, select last known good profile and press enter.
If this does not work reboot go into SAFE mode and select Safe Mode from menu and see if it will boot up.
You may get a pop up to use system restore, say yes, select restore to an earlier date (or similar) then use the calander to select a restore date that is PRIOR to the problem starting.
If this does not work boot to safe mode again and say NO (cancel) to use system restore and see if you can get to the desktop
post back results for further troubleshooting
Jul 16, 2008 | HP Pavilion zd8000 Notebook
Computers & Internet Logo
227 people viewed this question
Top Medion Computers & Internet Experts
John Anderson
John Anderson
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
