Question about Video Game Consoles & Games
We bought a xbox 360 game and it wont work on our console. we are in australia and the game was bought from japan, when we put the disc in, it says it is not in our region. what does this mean and can we change a setting to play the game????
    Master:
  • 726 Answers
On a xbox 360 there is no setting for a region game code
Posted on Jul 18, 2008
Well i bought a game called 2k8 basketball here in philippines, but i bought my xbox on australia, then i tryed my game and it said, ( The disc's region code is incorrect for this consol ) so how can i...
Sorry you can't fix it. Most games are Region specific meaning that they are playable only on Xbox 360 systems from the specific region that you have. If you bought your Xbox 360 in Australia then it is likely PAL system and can only play Pal games.
"Determine whether the game disc is from the same region as the region where you purchased the Xbox console. To determine the region, view the back of the game package. Look for one of the following codes:
* NTSC: North America and South America (United States, Canada, Mexico, Chile, and Brazil)
* NTSC-J: Asia (Hong Kong, Japan, Korea, Singapore, and Taiwan)
* PAL: Europe, South Africa, India, Australia, and New Zealand"
If the game you have doesn't match with your Xbox 360 Region then you won't be able to play it. (but a few games are playable on multiple regions, check list below)
Check out this site prior to buying games to help identify which games that aren't PAL might be still playable on your system.: http://www.play-asia.com/paOS-00-3-xbox360_compatibility_guide-49-en-84-t.html
Notice that NBA 2K8 US version is not compatible with PAL system. If you had bought the US version of NBA 2K9 then it would have worked.
Aug 06, 2011 | Video Game Consoles & Games
FABLE 3 IS UNREADABLE ON MY XBOX 360 BUT ABLE TO PLAY OTHER GAMES coz i update my 360
Check the format. I bought a Game off of ebay, and when it came, the Xbox 360 wouldn't read the disc. I examined the disc more to realize it was formatted for the Japan region...
Nov 09, 2010 | Microsoft Xbox 360 Console
Xbox 360 - Please put disc into an xbox 360 console to play
Try getting a disc drive cleaner. (Maxwell).
www.walmart.com is and example retailer.
May 24, 2010 | Microsoft Xbox 360 Console
The disc's region is incorrect. what is mean by this????
Region codes is a built-in feature of the DVD system designed to control where discs are viewed and distributed. All DVD hardware and software is coded using one of six numbers ( DVDs Regions 0 , 7 and 8 are special cases - see below ). The U.S. and Canada use Region 1. Region 2 discs are used in the U.K. , Europe and Japan . While Australia and the Caribbean use Region 4. These codes determine where the discs can be played.
Your console must match the discs region code.
This is not the case so you wont be able to play with this game.
Hope it helped.
Nov 20, 2009 | Microsoft Xbox 360 Console
X-box 360 screen says " to play this disc put in xbox 360 console"
That might be something related to your Xbox 360 console itself or the disc you are trying to play on, so first have a look on the Xbox 360 game disc itself and check whether there is any kind of scratches or flaws on it.
If you find a scratch or a flaw on the disc that seems to be the reason and just to check it you can put any other game in your Xbox 360 console and try it once more, if the other game is working fine that definitely assures that it's a fault with the game disc & check on the scratched discs page on our web site for more information about the reason for this issue to occur.
In case there is no scratch or a flaw on the game disc try the following steps:
1- With no discs in the disc tray, go to the System section on the dashboard.
2- Select Console Settings.
3- Select Start Up.
4- Make sure it is set to Disc not dashboard.
If it is set to dashboard, select Disc and try the game again. It should work.
If is already set to disc or you tried setting it to Disc and still not working try the following steps:
1. Just clean the disc & put it back in your Xbox 360 console and see whether it's going to work again or not.
2. If it's still not working try also another discs to know whether it's an issue with the actual Xbox 360 console then or not.
3. If the other discs work fine you can try it then without the hard drive because it might also be something related to the hard drive.
4. If it is still not working so this game disc would be for sure faulty and you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "To play this disc, put it in an Xbox 360 console" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
Aug 29, 2009 | Microsoft Xbox 360 Console
Wrong region code this disc region code is incorrect for this console.i got this game from oversea, on ebay, it is band new, but does not work, can you hepl
for now, there is 3 disc region codes,
ntsc for north america and south america, (united states,canada,mexico,chile and Brazi)
ntsc-j for Asia, (hongkong Japan, Korea, Singapore and Taiwan)
pal for Europe, South africa, India Australia, and new zeland
if your console was bought in us, you should be able to use game discs with ntsc region code, this is shown on the cd itself and the case of the cd...
Jun 28, 2009 | Microsoft Xbox 360 Pro System Console
Zone code
    1. Determine whether the game disc is from the same region as the region where you purchased the Xbox console. To determine the region, view the back of the game package. Look for one of the following codes:
    2. NTSC: North America and South America (United States, Canada, Mexico, Chile, and Brazil)
    • NTSC-J: Asia (Hong Kong, Japan, Korea, Singapore, and Taiwan)
    • PAL: Europe, South Africa, India, Australia, and New Zealand
    1. If this symptom occurs with only one or two discs, search the Microsoft Knowledge Base (http://support.microsoft.com/search/?adv=1 (http://support.microsoft.com/search/?adv=1) ) for the specific game title or titles. If you find a known problem, follow the instructions in that article.
    2. If the game disc worked in the past, the disc might now be dirty or damaged. Clean or replace the disc to see if this resolves the problem.
    3. If this behavior occurs with only one or two discs and no known problem exists, return the disc or discs to the retail store where you made the purchase.
    4. Turn off and unplug your console, remove the Xbox Hard Disk Drive (HDD) and any attached memory units (MUs), and then reconnect your console. Try the disc again. If this procedure seems to resolve the problem, turn off and disconnect your console, reattach the HDD and any MUs, and then delete any saved games for the game with which you had problems.. Note If you can do this, move the saved games to a different memory unit.
    5. If you have this problem only with original Xbox games (games that are designed for original Xbox, not Xbox 360), the original Xbox backward compatibility update may be missing from the HDD. To resolve this problem, download and burn a copy of the backward compatibility update to a disc, and then install the update to your console
    Sep 25, 2008 | Microsoft Xbox 360 Console
    Disc wont read
    Hi
    Are you using a modded Xbox 360 console?, if not then the disc you are trying to play is probably a copied Xbox 360 disc which would not work on an original Xbox 360
    Regards
    KreativeGeek
    http://gamingbox.wordpress.com
    Aug 30, 2008 | Microsoft Xbox 360 Console
    360 GAME
    If the disc is not scratched and doesn't have any flaws on it, cleaning the disc and trying it once more may solve the issue, if that doesn't work try to check it by putting other discs in your Xbox 360 console, if they all work that would be definitely a fault with the disc itself and in a case like this you have the right to exchange it from the retailer you bought it from as it's not scratched.
    In all cases if other game discs are giving you the same error message "This disc is unreadable" OR "Unplayable disc" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
    Nov 28, 2007 | Microsoft Xbox 360 Console
    Video Game Consoles & Games Logo
    Top Video Game Consoles & Games Experts
    James Wishart
    Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
