Question about Amana ACS3350 Gas Kitchen Range
Oven door won't unlock - Amana ACS3350 Gas Kitchen Range
  • 1 more comment
  • Anonymous Apr 11, 2009
    my kenmore elite oven door won't open
  • leo20004 Apr 19, 2009
    I locked the door for the oven to self clean. Ater cleaning and the door light went out before turning the clean knobs off, I tried to unlock the door but it will not unlock.
  • Anonymous Apr 26, 2009
    the STUPID door wont opennnnnnnn
    can anyyy111111111 helpppppppppppppppppp???????????????????????????????????
    its annoyinggggg...
I asked for help with an Amana F9 code problem earlier today .I had set self clean oven on and then after 2 hours cancelled it. After 1/2 hr it began to beep and displaideda F9 code and I couldn't get it to unlock. Tried manual tip to turn off circuit breaker for 3 minuetes then turn back on. Did this 3 times to no avail.Tried 20 minutes also zip.Contacted Amana and all they would tell was to call a service rep. I gave her apiece of my mind that I wouln't do that because I wasn't going be paying for such an issue.
Your site was my salvation.( STP685) Suggested I push bake and once I did the oven started to heat and unlocked itself.! Thank you,thank you,thank you.
Posted on Jun 04, 2009
    New Friend:
My solution was to reset the breaker, set it to 'clean' and cancel the clean immediately. It blinked "locked" on the display for less than a minute and then unlocked itself.
Posted on Oct 04, 2013
I have kenmore stove oven door won't unlockk
Posted on Apr 11, 2009
Oven door won unlock
I HAVE A 10 YEAR OLD OVEN RANGE. SELF CLEANING IS IN THE LOCKED POSITION. I UNPLUG THE RANGE FOR 30 MIN THE DOOR IS STILL LOCKED
Jan 08, 2014 | Electrolux 30" Self-Cleaning Freestanding...
Model number FGEF3032KWB frigidaire oven door won't unlock
Unplug, or turn the household circuit breaker off to the unit for about 15 minutes. If the door does not unlock itself then, contact Frigidaire for a service call. The door latch and/or control board will need to be replaced.
Aug 02, 2012 | Frigidaire FEF336BC Electric Kitchen Range
Ge gas oven ran self clean door won't unlock door locked flashing lock motor running continuously
if your motor is running continuously, the door is locking and unlocking. catch it when unlocked, and unplug the range. then disconnect the power wires from the lock motor. this will allow you to use the oven while you get a new lock assembly and replace the one you have. should be fine after that.
Feb 04, 2012 | GE 25 in. GSC3200GWW Free-standing...
Tried to clean it. Door has locked and won't cycle open again. Help!
Hello.
To close an oven door when it's in the locked position andthe door is open, press and hold the oven door light switch while followingthese simple steps:
  • Program the oven to self-clean.
  • Wait 20 seconds.
  • Cancel self-clean.
  • Wait 20 seconds.
To self-clean your wall oven, follow these simple steps:
  • Remove the oven racks.
  • Set your oven control to "Clean."
  • Select a cleaning time or choose a cleaning level: light, medium or heavy. For typical cleaning needs, we recommend that you select a cleaning time of three hours or choose the medium setting.
  • Select "Start." (To set a delayed start, see your Use & Care Guide.)
Note: For safety reasons, the oven door will remain locked until the oven coolsdown. When it is sufficiently cool, the door will automatically unlock Thanks for using fixya.
Sep 06, 2011 | Ovens
The oven door won't unlock even though self-cleaning has been cancelled
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Aug 10, 2011 | Frigidaire FEB27T5D Electric Double Oven
How do i reset the locked oven door to unlock it?
I have had that problem once.I turned off the breaker to that oven over night and then in the morning the door opened as it should.I found a GE page that is below.It may help.
http://www.geappliances.com/search/fast/infobase/10000161.htm
Some models with oven Set and Temperature knobs must have those knobs set in the Clean position before the latch can be moved to the left. If your door won't unlock, try turning those knobs back to Clean, then slide the latch over.
May 16, 2011 | GE JTP15 Electric Single Oven
Amana ACS3350 Gas Kitchen Range Logo
1,047 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
