Question about Sunbeam 2346 Heritage MixMaster Series Stand Mixer
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
  • 2 more comments
  • Anonymous Nov 30, 2008
    My beaters crash into each other
  • Anonymous Jan 28, 2009
    sunbeam mixmaster mm 300-N front circular panel where the sunbeam logo is popped out and I cannot push it back in. Not sure if it is broken.
  • Anonymous Feb 08, 2009
    My wife has a 2346 model where one of the beaters is stuck. We are willing to sell it for parts. What is is worth ?
    feel free to email us at jharb36@hotmail.com
  • Anonymous Mar 18, 2014
    beaters no longer turn it is 2 years old
  • 4 Answers
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Posted on Dec 16, 2008
Worn out beater gears
Soft plastic gears inside the machine from what I've read around the web, sorry but you'll need a complete new mixer.
I've had one apart to see just how fixable it might be, and it took me about 30 minutes to get the motor and gearbox into a position where they could be looked at. The gearbox had 2 stainless steel clips holding the top cover on and I didn't want to pry at those in case the cover snapped.
Not a lot gained from looking inside it sadly.
Apr 12, 2013 | Sunbeam 2346 Heritage MixMaster Series...
Got spatula stuck between beaters striped gears
The gears are readily available. Just open the micer and replace them. You will have to pop the buttons out of the front and rear to get to some of the screws. Once you remove the gears, also remove ALL the grease. It has broken pieces in it. Use light lithium grease to refill the gear area HALF FULL. Make sure when you put the gears in, they you line up the marks on them with the motor shaft. One will be straight in line and one will be at a 45 degree angle. This is so the beaters don't hit.
Dec 18, 2012 | Sunbeam 2346 Heritage MixMaster Series...
Beaters won't turn bowl still does turn
I just took mine apart for this same issue. What i found was the plastic beater drive gears have been stripped by the motor worm gear. I am currently looking for these parts to replace them.
Dec 28, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
My mothermixmaster's beaters need replacement it was a wedding gift in 1955 - where do I find spare parts?
Hello. Thanks for choosing Fixya! Actually, Sunbeam hasn't changed their beaters since 1936 for most models. I believe your best bet is to order from a Sunbeam Factory Service Center. Here is the link that will get you there. http://www.householdappliance.com/sunbeam_oster_beaters.html
Good luck with it. Regards, J.
Nov 16, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Have one that does not work and want to know how to open it- can see no clear idea how to and want to avoid damage. regards, Peter
The mixer is not designed to be disassembled or serviced. When it breaks (and it will) Sunbeam will replace it under warranty if you are lucky or you toss it in the trash.
That said, start by prying out the beater release button. There are two small screws under it and one between the beater inserts to remove the chrome front cover. The large black dial at the rear can be pulled straight off, revealing more screws. The motor and drive assembly in the top cannot be removed without disconnecting wiring from the circuit board in the base.
Jul 27, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam 2346 Heritage MixMaster Series Stand Mixer Logo
1,625 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
