Question about Canon PIXMA MP470 All-in-One Printer
MP470, Won't print B&W only
I can use configuration settings to tell the printer to print grayscale and to use the B&W cartridge only, but once I select any type of photo paper it insists that it must use the color cartridge. I do not want it to.
How do I print B&W photos using only the B&W cart?
  • lmerrick0 Sep 28, 2008
    My Pixma Mp 460 will not run with only one inkjet. I want it use black and white only. I am tired of paying for color ink which I do not want. I just want the black ink to print. Although I have a color inkjet it is "not recognized" "error U051." My black inkjet is new but it is no longer recognized either? ARGGGG.
  • thebartyone Oct 06, 2008
    I have a macbook and there aren't any printer options which allow me to choose between printing in color or in black and white. Color ink is expensive so it seems as if my printer is forcing me to waste money. Are there any sort of driver support etc. for this issue?
I have the same problem. Did you ever find a solution?
Posted on Oct 18, 2011
    Sergeant:
    Champion:
  • 246 Answers
If you use gray scale they definitely use the color caritridge
When you printing a photo they normaly use the color cartridge
Try to set the printer to black& white and try to do it
Posted on Aug 04, 2008
My Epson printer R32o won't print color . All cartridge all new . Please help ! .
Hi
Have you checked the settings if they are set to Grayscale only or use black cartridge only. Options in printer settings? try to restore all to default settings and this will solve your problem.
Take care
Jul 16, 2011 | Epson Office Equipment & Supplies
Is there any way to get my printer to print only black copies without having to buy the new color print cartridge
Go to the printer settings - Preferences- color tab - and select Grayscale in the color selection.
Once this is done, try print a color text and see if it comes in a gray scale. This will work.
To give you a tip on this.... understand that this printer has a black ink cartridge and a tri-color cartridge. When we select grayscale, only black cartridge would be used.
Good Luck.
Mar 15, 2010 | HP PhotoSmart C4180 All-in-One Color...
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Color Cartridge out of ink - override/print in grayscale?
Printer will not print if any color is out. Just won't. They are set up like that.
May 28, 2017 | HP Photosmart C6180 All-In-One InkJet...
USUALLY there is a setting in the printer setup or propperties that you can specify gray scale right before printing. It normally is on the same screen that print preview is offered. Search the menu items for it.
Sep 24, 2009 | HP PSC 1315 All-In-One InkJet Printer
Can not get my Cannon MP470 printer to print in color again _
TRY GOING INTO YOUR INK SETTINGS AND TELLING THE PRINTER THAT BOTH CARTRIDGES ARE FULL IF THAT DOESN'T HELP GO INTO YOUR PRINTER VIA CONTROL PANEL AND MAKE SURE ALL SETTINS ARE BACK TO DEFAULT .
May 07, 2009 | Canon PIXMA MP470 All-in-One Printer
Printer problems
This will sound stupid, but if you are trying to print a document in B&W with this particular model, you have to force it to print ONLY using the black ink cartridge, if you are out of color ink, otherwise, it will try to use the color cartridge by default. A highlighted word is not recognized as a black image with a colored background, it is recognized as a multi-colored image, s-o-o-o try going into your solutions menu, click on "Change settings" then click on "Printer settings" Then click on "Maintenance" tab, click on the "Ink Cartridge settings" button. From the drop-down menu, select "Black Only". Click on okay. THEN when you go to print the document go to your printer settings and click on the "grayscale printing" checkbox. Then Select "Plain paper" Of course, you have to do this each time you want to print. The MP470 is primarily a photo printer, with text and graphics abilities. It wasn't designed as an all-purpose printer... I found that out the hard way! :-) Unfortunately, this only works (so far as I've seen) if you are out of color ink... it tries to use color by default to 'create' black... I hope this helps out!
Apr 12, 2009 | Canon PIXMA MP470 All-in-One Printer
Halftone printing
do you mean grayscale printing?just configure your printer setting to print in grayscale using the black ink only..HP D2460 is capable of printing using only one (1) installed cartridge..
Jul 01, 2008 | HP Deskjet 2460 InkJet Printer
Won't print
Try the following steps:
Check for and remove any grayscale settings. Use the following steps to check this setting.
  1. In the program, click File and then click Print . The Print dialog box opens.
  2. Select the correct product and then click Properties . The Properties dialog box opens.
  3. Click the Color tab.
  4. Check the Print in Grayscale setting. If necessary, unselect the setting.
  5. Click OK to save the settings.
If this doesnot work:
    1. Open the Printer Toolbox .
    2. Open HP Solution Center .
    3. Click Settings .
    4. Click Print Settings .
    5. Click Printer Toolbox .
    Now Click the Estimated Ink Levels tab. This will tell u that the cartridge might be running out of ink even if the graphic shows that there is ink remaining in the cartridge.Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • If this doesnot work:
  • If the Print in grayscale option is not the problem and the print cartridges are not low on ink, print and evaluate a self-test page to determine if the cartridges or printer is causing the problem.
    1. Load the input tray with unused plain white paper.
    2. Press and hold the Cancel button and then press the Start Copy Color button.
    3. Release both buttons. The self-test page prints.
    This will definitely work for u.
    Thank u.
    May 27, 2008 | HP DeskJet F380 All-In-One Printer
    Canon PIXMA MP470 All-in-One Printer Logo
    130 people viewed this question
    old marine
    old marine
