Connecting an Equalizer to a Receiver
Before beginning, purchase RCA cables. In order to run the signal from a
stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the
receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the
amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the
receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
not able to connect a pioneer sg-540 graphic equalizer to a amp sa-940
