Question about Maxtor Hard Drive
MAXTOR 2B020H1 I tried to make a disk from image on main disk, using ghost32, it was set to slave (E:\), everything was going but suddenly ghost32 is asking for destination disk??, after that i cant see anymore slave, but the BIOS see it on boot. Does anybody tell me how to restablish it Thxs
  • 2,794 Answers
Usually with a Ghost restore you have to create a CD or DVD to boot it up. That boot CD should tell you to go to e. to read the information created from the backup file.
Posted on Jul 18, 2008
When I run the maxtor 93073u6 as a slave - it kills my cd drive and When I remove it the cd drive comes back I have tried everything I can. Help!
Run the Hard drive using one cable with duel main and slave capability and the CDROM drive give it its own cable ising the second IDE cable as the master for the CDROM drive. Isolate them. Making sure one is master and set to accept a slave drive using one cable for both hard drives and one for the CDROM drive. Try that and see if this assisted you. Do not forget to vote John
Feb 06, 2011 | Maxtor Hard Drive
How do I make use of a Maxtor Hard Drive. Should it have a disc to instal?
Dear shirley403
Yes, you need an operating system disk if you use the Maxtor hard disk as the main patision to your computer.
but, if you only use it to backup drive, set the jumper to slave.
If you are using external cassing, jumper settings depending on the situation, try to enter the master jumper setting,
if it fails in effect, put to slave or cable select
hopefully this can help...
TQ
Oct 31, 2010 | Maxtor Hard Drive
DiamondMax 21 80-GB ATA/100 Hard Drive didn't get recognized as 1st drive or 2,3. do i need any software.
Use a partition manager to see if the drive is recognized. If it is not recognized, you may not have the jumper setting correct. If it is a master drive, set the jumper for master drive. same for slave or cable select
May 05, 2009 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
Jumpers guide Maxtor 2B020H1 20Gb Slim IDE 3.5'' Hard Drive
Maxtor jumper as follow:
looking at the connector top row 5 pins, buttom row 4 pins.
the single pin on the top row is index pin.
master jumper is located between top 2nd pin and 1st buttom, counting from the left.
slave has no jumper on any of the pins.
cable select jumper is located between top 4th and buttom 3rd pin. counting from the left.
Apr 24, 2009 | Computers & Internet
Maxtor 20gb slave probs
on the IDE or "Connector" Side Of The hard disk there should be little peices of plastic with metal cenectors in them that close a circut between two pins there are two well used ways to set up a slave.. the main way that the manufactures say is the easiest is to set to cable select or "CS" the other way is to set to "SLAVE" or "SL" and that will allow you to use the second hard disk.. by the way make sure not to connect it to the same cable as the cd ,dvd or other wise known as the optical drive's cables... it will greatly decreasy that hard drives performance.
Jan 09, 2009 | Maxtor DiamondMax Plus 6800 (92049U6) 20.4...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Slave pin settings
hi frined
remove your hard disk jumper & u r hard will be slave
Apr 12, 2008 | Maxtor 20.4GB 7200rpm ATA-100 HDD p/n...
Dear noggin
is the jumpers set correctly . to slave or try cable select
Mar 02, 2008 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
Pin settings
There are four Jumper settings on a Maxtor:
(got it from http://www.techspot.com/vb/all/windows/t-32378-Windows-XP-Home--No-boot-device-help.html)
posted by by mr.smit:
"The 2nd row, is for DS(Master): only 1 drive in PC, or the drive that you want to boot up from.
The 3rd row, is CS Enabled: Cable select, the computer desides wich harddisk is master and wich one is slave
The 4th is cap limit: windows cannot run on harddisks that are to big, like 300gb, so putting jumper on cap limit (capacity limit) makes it smaller for windows to use it.
The 5th row has no use, or i don't know what it does, either of that 2."
I would like to add about the DS (Slave) setting. It is used if there is another drive present on the system which you want to boot from. It will become a spare Hard Disk.
Here is a picture of a maxtor drive indicating where to find model number and jumper settings.
http://xboxdrives.x-pec.com/images/maxtor-drive-model.jpg
Nov 19, 2007 | Maxtor Hard Drive
Maxtor Hard Drive Logo
103 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
