Question about Microsoft Windows Vista Ultimate Edition
Refill cartridge i refilled my dell ink cartridge , but wen i reinstalled te cartridge in the printer te dell lap top does not recognise and says i cant use this cartridge i never ad tis problem wen i had xp but wit vista its comming up with this error message surely there must be a sloution .
  • Microsoft Master
  • 2,794 Answers
Make sure that youre not using the same printer drivers that you were when you were using XP. Uninstall them. Go to Dell.com and get the Vista drivers for your printer. Intermittent problems have been reported with most of their printers if the drivers haven't been replaced.
Posted on Jul 18, 2008
Can you refill dell series 21 ink cartridges?
Any ink or toner cartridge is refillable, For ink cartridge, check for the small pin hole at the top of the cartridge to inject the ink refill. But remember that the ink should be compatible with your ink cartridge model. Good luck
Jan 05, 2011 | Office Equipment & Supplies
I filled in a Dell 924 cartridge and now the printer does not recognize it and does not print
if the cartridge is chipped, it will still be recognised as empty, since the cartridge uses a backwards counter to estimate the amount of left-over ink. there are tools to reset the chip on an ink cartridge to refill it, which you can normally buy in the shop where you bought the refill-kit (if not already included). please note that the cartridge may not warn you again about being empty. when print quality deteriorates, refill. if print quality stays bad (even after a refill), replace the cartridge with a new (original) one.
Jan 18, 2010 | Dell 924 All-in-One InkJet Printer
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
Refill instructions for a Dell Series 5 ink
Cartridge World stores can refill these cartridges for you.
Oct 23, 2009 | Dell 924 All-in-One InkJet Printer
Dell a940 error code 50c
From doing my research, I have found that the 50C Error message comes from the cartridge, usually if it has been refilled. If this cartridge is new, please return it to the place of purchase for a new one or a refund.
Here's what happens when you refill the Dell Series 2 ink cartridges. There is a sensor in them that cannot be reset.
Dell ink cartridges can only be purchased at Staples, Walmart or Dell's website.
Dell ink cartridges have a sensor that reports the ink level as low once it reaches a certain level. The sensor can not be reset. If you refill an ink cartridge that previously reported low ink, it may print fine, but the sensor will always report low ink. Buying or replacing ink cartridges with new Dell cartridges will resolve the low ink message.
Dell discourages ink refills. Refilling ink may lead to print quality problems, and even eventual hardware problems.
if u have not refilled ur cartridge and u still get this error i suggest u buy a new cartridge.....
good luck
have a nice day
Jul 08, 2009 | Dell Office Equipment & Supplies
I just refilled black ink of my new printer Lexmark x5495. Does not recognise the black cartilage and keeps on asking for alignment. When it prints alignment page it does not use the refilled black ink....
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Refilled cartridge dell 924 wont recognize
can someone direct me on how to put ink in my printer
Feb 03, 2009 | Dell 924 All-in-One InkJet Printer
Printer cartridges not recognised
Sometimes even when an ink cartridge has been refilled to capacity, your printer still registers it as empty. This is because your printer remembers that the cartridge was previously installed and it can only remember it as being empty. Part of this is due to technology put in place by printer manufacturers so that you will always have to buy new cartridges. Part of it is also that print catridges are clogged if not used for sometime after its empty even after refilling this is because the contact was already clogged due to the dryness of the old ink inside it before refilling so in that case you will clean/soak the contacts with solvent before refilling .
again since there is no “official” way to fix this problem, you have to basically clear the printer’s memory to make it recognize that you are installing a full cartridge. If you have tried to install the refilled cartridge and you have done all you can to convince your printer that the cartridge isn’t still empty, then basically you just have to unplug your printer for a minute and then trying reinstalling again. but it should fix this problem and it can potentially fix other annoying things your printer is doing.
Sep 06, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Problem with Dell ink jet refill....
Are you using the Dell software to replace the cartridge?
If you where just replacing without running the software then it wont know you have replaced the cartridge.
Let me know.
Zod
Apr 24, 2008 | Dell 924 All-in-One InkJet Printer
Dell 926 Printer ink refill instructions
Go to this webpage: http://www.ldproducts.com/Dell-Ink,Photo-all-in-one,926,Ink-Cartridge,3234,printer.html Click on the links for InTec Refill Kit for Dell MW175 Black and InTec Refill Kit for Dell MW174 Color. Scroll down to Specifications and click on the Instruction Video link for each. That should help some.
Feb 25, 2008 | Dell 962 Photo All-In-One InkJet Printer
Microsoft Windows Vista Ultimate Edition Logo
65 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
